Does anyone know of a cheap place to buy rotors and pads for e36's???? I desperately need to do this as cheap as possible because I'm turning in my lease and I don't want to keep the car! I'm hoping to upgrade to an M3! Also, do I need to get a special key or tool for the change the pads and rotors?
-George
'99 328is Avus Blue
bimmerparts.com
thanks!
-George
Off the top of my head:
6mm Hex key
7mm Hex key
16mm wrench
17mm wrench
18mm wrench (maybe)
6" C-clamp (to push the caliper piston in)
Jack
Jackstands
Brake cleaner spray
Big screwdriver (to pry off the retaining spring)
Torque wrench (to put the wheels back on. 75ft-lb...very important)
That should cover it.
I got my parts at Zygmunt ( http://www.bimmerparts.com ). Good prices, good parts. I went with Pagid pads. Chris will take care of you.
Good luck,
Bernman
