Just wondering if I need to go and buy the OEM stuff?
Also, as a temp measure can I run just tap water in there? I failed to put the cap on right so a lot of the fluid steamed out of there and I need to get home...no BMW dealers around.
mike
Yes, run tap fluid but do a complete drain when you get the proper fluid. I purchase only OEM fluid because extra 2 bucks is worth saving the possible extra wear on the engine. Just my opinion and I am sure someone is close by to correct!
As long as it is phosphate/nitrate free you will be fine. I used some generic o'reilly stuff. I don't loose sleep over it and I'm pretty anal when it comes to my car maintenance. It's better than the old stuff that was in it before.
Just make sure you use distilled water. I picked up filtered drinking water, but luckily I figured out it was the wrong stuff before I did it and used the correct water.
distilled water only!!!! not tap(unless its an emergency)
-Dr. Seuss
distiled water and bmw coolant... i will never run anything else in my cars... even on my dads ford truck.. distilled water and ford coolant... its just me being anal
Zerex G-05 works too, I've read. It's what I run.
And it's only $10 a gallon from Napa (not mixed).
To get it home, a generic phosphate free coolant and tap water will be alright if it's the best you can do.
Find some distilled water (local grocery store?) if you can make it happen.
If it were my car, once it was home, it'd all get drained out for a proper fill of BMW coolant and distilled water as quickly as I could get my hands on the goods.
Cosmos on Black '98.5 M3 Coupe 5MT
I just used Zerex G-05 too, though it was more than $10.
I wouldn't use tap water because there is no way you will be able to flush the system bone dry.
-Dr. Seuss
^How can you just drain the tap water, or any water, fluid from the system?
Why would you go through all that trouble anyhow so you can put tap water in?
distilled/bmw blue coolant.
Suspect you've already done what you need to to to get home. If you did indeed put tap water in... and you intend on draining the system, PLEEEEEEZ follow the proper bleeding procedure when you refill. If you don't have a Bentley manual, do a search on this forum, BimmerDIY.com, or Pelican.
Otherwise... your next post will look something like this:
"THE DEALER WANTS TO CHARGE ME A ZILLION DOLLARS FOR A NEW HEAD GASKET... WTF?!"
Thanks for the info. I posted the question when I got to school. When I leave (around 9PM) the local auto parts stores will be closed. There is a gas station here...so I'll look for 50/50 antifreeze/distilled water. If they have it great...if not I'll put tap water in it, then get the OEM liquids tomorrow from the dealer and go straight to my mechanic.
When I did my cooling system overhaul I made the trek to the stealer for the coolant and grocery store for the distilled.
Anyway, I had my Jeep into a local radiator only shop regarding, well doesnt matter.... But we got on the topic of distilled vs tap (I had used distilled in my Jeep too) and he said it doesnt make any difference in any car. I inquired if this was the same for BMW's and he just laughed and said that BMW's dont need it either. We started talking about antifreeze and I mentioned that I used BMW OEM coolant and he just laughed again and said BMW recommends it because it costs more....
He's been in the radiator business for 35+ years and basically said that I wouldnt know any better since radiator work is not something I do everyday, in a nice way.
I will still use distilled water and OEM coolant, but I thought it was an interesting conversation.
I don't really think OEM HAS to be used for anything.
As long as it's similar and serves the same purpose with the same contents, it will work.
I assume you don't use the BMW Dealer oil for oil changes right?
I did my first oil change. Boy, that was expensive.
Distilled water and Prestone phosphate free coolant or equivalent at any auto parts store will work fine.
Use Honda coolant if you cant get OEM or want to pay less, it is premixed already and its also blue. I have been using it always in all of my cars since I'm a Honda tech and I get that stuff for free. I also believe that Honda coolant is just as good if not the same thing as BMW OEM.
Walk a mile in my shoes and you are a mile away in someone else's shoes.
Goodridge*UUC sways* Black TME's and mounts( switched from Red)* x-brace*brembo rotors*Zimmerman rear*Pagid*Riken Raptors* Roja Formula 7's (Bronze)* Stromung*Powdercoated AA DSB* OMP strut bar*GC RSM's* M3 alum/leather knob*JTD underpanel *Traffic PRO (sold) *Black hella Ellipsoids w/celis rings * ACS Pedals*ACS handbrake*RE Octane SSK*Wheelskins Eurotones S/ Wheel Cover( tossed-replaced with new one)* Totally Covers Front seat velour covers with custom styling *Rieger roof spoiler-lost it on fwy Stock A/B*URI CP (ditched years ago)*540 HFM (sold) Stock HFM (BeckArnley)*FMS 24 lb inj*Alum rad and some other stuff*Konis w/adj rr's*Vogtland springs ** Passport 8500(sold)*Passpprt 7500 (sold V1-1.8 with POP) No detectors at all.
Coming...nada
BMWCCA-303681
i used 50/50 oem coolant and distilled water. Then added a bottle of redline water wetter. The oem coolant is clear and is almost the consitency of syrup ha.
~Nick
'97 Arctic on Black ///M3
This wouldn't bother me if our cooling system was like any other car's and didn't need to be overhauled every 80K miles. Since that is the case, I will use only BMW coolent and distilled water/water wetter for my baby so I don't become a member of the yearly cooling system overhaul club. BTW I just realize my contradictory statement above with the watter wetter. Hypocrite, though I may be, that's the way I will do it till she's gone by-da#%!
Check this out: http://www.geocities.com/dtmcbride/h...ntifreeze.html
Use BMW coolant. The difference will be less than five dollars. Ten if you consider the gas to get to the dealer. Or, go online and buy more parts to get free shipping.
Along what Gresham1 said earlier, my dads a mechanic, and he told me that all his life, he's used regular antifreeze and tap water, and not a single engine has had problems because of it. We keep alot of our cars upwards of 15 years, so I'd think they would show some ill effects in that time period.
