Page 7 of 9 FirstFirst 123456789 LastLast
Results 151 to 175 of 201
Thread: E39 Touring Rear Subframe Bushing replacement
  1. #151
    Meadowlands, NJ
    03 525iT 05 330Ci Cab
    Quote Originally Posted by av8r4aa View Post
    Just did it with Jason's special tool. He speaketh the gospel.
    And the verdict is.........
    Worth every penny?
  2. #152
    Nov 2001
    Atlanta, GA
    R12GS 535xiT 98 M3 ZHP
    I replaced the bushings in our 2000 528iT with Jason's tool back in 0ct 2012. Huge different, not so much in how it handled but in hitting bumps and going over speed bumps. With bad bushings, it almost feels like a huge shock wave going through the car from the rear. With new bushings, it feels like a normal car.
    Anyone care to share how their replacements are holding up? 2 yrs and 35k miles later, it feels like it needs new bushings. We are moving on to a E61 535xi T but the E39 is staying in the family so I will need to replace the bushings at some point later in the year, hopefully to the Meyle HD versions.
  3. #153
    Jun 2014
    alexandria, va
    E39/E90
    can someone advise which is the tool from harbor freight that they used?
    the link for the people who rent it is no longer working and their home page just talks about special coatings for guns
    i can only find this one:
    http://www.harborfreight.com/bushing...set-68971.html
    edit: also found this one at amazon, will it work?
    thanks
    http://www.amazon.com/Mercedes-Insta...r+bushing+tool
  4. #154
    Falls Church, VA
    '90 325iX, '00 528iT spo
    Fredvent:
    I am < 10 miles from you and have the touring subframe bushing tool for rent.
    Let me know if you want to rent it and we can arrange a drop-off / pickup.
    Easy-peasy lemon squeezy.
    PM me or email: Jase007 at aol dot com.
    Cheers!
    Jason
    '90 325iX 5M, '00 528iT 5M Sport (mfg. 5/1999)
    BMW CCA member #130075
    JScott Racing
  5. #155
    San Diego, CA
    98 M3, 03 540it M-Sport
    question, do you guys use the retaining bolts? I can't seem to find anyone that sells the M12x1.5 bolt. Even rods to trim down to size are hard to come by. Do you have to use them or do they make the job THAT much easier?
    '98 M3 5spd - '03 540it 6spd M-Sport
  6. #156
    San Diego, CA
    my $0.02 after my install:
    You can use dish soap with water instead of the lube. It'll dry a lot faster. But yes, using that tool made it a 4 hour job. And you HAVE to disconnect the Self Leveling Sensors if you have them. When you drop the subframe, the wires aren't long enough and you'll break one of them.
    I didn't use the replacement dow rods because I couldn't find any. I used my floor jack under the diff. Completely remove all 4 of the rods that go through the bushings and replace the rear two bushings first. Only drop the diff enough to get the tool on top of the bushing. Otherwise you'll be putting extra weight on the exhaust hanger and you don't want that to break.
    After the rear two bushings are replaced, put back in the two rear bolts but only 1-2 turns. This way when you drop the diff more to get to the front bushings, you don't put that extra weight on the exhaust.
    Last advice, clean the ever-loving schyt out of the bushing recepticle. I used #0000 steel wool and really get all the crud out. It makes all the difference when putting the bushings back in.
  7. #157
    Dec 2002
    Brighton, MI
    '00 323Ci
    Reviving...is Jason still doing this rental thing? Time for me to do these bushings. Any other rental options if Jason is out of it? Thanks.
    Jack $
    "The original M3 is utterly brilliant in ways the people at M have either forgotten about or choose to ignore."
  8. #158
    Falls Church, VA
    Still here.
    Jason
    JScott Racing
  9. #159
    Jan 2005
    Central NJ
    02 540 Touring, 2010 650
    Time to do my subframe bushings, they are so noisy feels like the rear end is fall off at times. Anyone in the NJ area with experience replacing these?
  10. #160
    Dec 2014
    Australia
    2002 530i Touring MSport
    Hi Folks,
    Putting together an order with Pelican for a preventative fuel pump swap and was going to add some likely other maintenance items. My touring is harsh in the back end when going over sharp bumps at highway speeds, it is still quite planted and stable so I think the shocks are basically ok but reading around I think these bushes likely need replacement.
    Pelican have 3 options, Febi @$39.75, Lemforder at $72.25 and Genuine at $114.75. They indicate Lemforder is the OEM. Reading through this thread I get the impression they don't last long, so I wonder does that mean we should buy the best quality possible, or does it mean they don't last long anyhow so why not save some coin if it needs doing every 3-4 years anyhow. I assume the Lemforder is as good as Genuine, but what about Febi? Anyone used them? Good or bad experiences?
    Uber
  11. #161
    Nov 2007
    Justin Texas
    2003 525it 2003 X5 4.6is
    I used Jason subframe kit.
    Worked fantastic. I included a ratchet wrench I had a duplicate of. The touring subframe bushings are good for 60-100K miles.
  12. #162
    Aug 2015
    Peoria, IL
    2002 525it
    Jason,
    Do you have contact information to rent the tool? I sent PM, wondering if you got that. I am based in Peoria, IL.
    Thanks,
  13. #163
    Jan 2005
    Central NJ
  14. #164
    California
    540iT & ITR #605
    Yes, I second disconnecting the SLS connector if you have one. One thing I noticed was after the install, I am getting a knocking noise at a very low speed around 5 to 10 mph. Only when moving. My install wasn't so pleasant. After unscrewing all the bolts but not removing them completely, without supporting the differential, all 4 bolts were forced out. I'm guessing because of the differential weight. I was able to install everything back, but may have switched the mount bolts and stoppers plate. Do you guys think this might be the culprit of the knocking sound. I never had the knocking sound before the install.
  15. #165
    Jul 2016
    Sheffield UK
    E39 530d sport touring
    What an awsome post wish there was some one in the uk renting the bush tool as mine are in dire need.
  16. #166
    Nov 2008
    Sacramento, CA
    540it-318ti-318ic-Z3
    Many thanks! Glad it helped!
    1999 540it - Schwartz II/Sand Beige, style 5 rims, Conti DWS 235/45 tires, Billy HD/Sports, Stoptech S/S BL, F1 Pinacle 35% tint, Zionsville Cooling kit
    1998 318ti Cali Sport - Schwartz II/Schwartz Anthratz, staggered style 23
    1997 318ti Sport - Schwartz II/Schwartz Anthratz, staggered style 68 ,
    1995 318ti Active - Alpineweib III/Schwartz, squared style 32
    1994 325i - Bostongrau/Tan, Billy Sports, H&R springs
    1991 318ic - Schwarz/Anthratz Stoff, Bilstien HD, Z4 3.0 SS, Magnaflow, S/S Stress bar, x-brace, M20 FW, Elipsoid/HID, K&N
    BMWCCA# 160411
    1995 318ti Sport Schwartz II/Schwartz Anthratz - Sold
    1985 635CSI - Schwartz\Sand - Sold
    1984 533i "Max" - Schwarz/Schwarz, - Sold
    1984 318i - Champagne/Tan, Stock - Sold
  17. #167
    Jun 2016
    savoy, il
    2003 525iT
    Thank you all for you the helpful DIY and tips. I did this on my 2003 525iT yesterday in 3.75 hours. After searching around to buy the Franklin tool (AFT47) and considering getting in line to rent Jase's, I stumbled across this special made tool from Kommen Tools
    http://www.kommentools.com/collectio...shing-tool-set
    It worked like a champ! I used the Rein bushings available at ECStuning.com. My wagon is much more stable and the harsh shudder that was occurring every time I went over a seam in the pavement is gone!
    I know several of you asked for an alternative to waiting to rent Jase's Franklin tool. I won't need mine for the next 100k so it's available to rent for $100 + $100 deposit. Just message me and we'll work it through Paypal. When I receive the tool back in undamaged condition I'll return your $100 deposit.
  18. #168
    Oct 2008
    Campbell, CA
    2000 528iT MT
    Hi All,
    Not sure if this thread is very active these days, but I've got an e39 touring with 112k on it and in need of this repair. I just bought the 4 bushings. Anyone in the Bay Area have the tool, or anyone care to rent it to me?
    Thanks!
  19. #169
    Jul 2012
    mitten
    525it,02 525it,73 2002
    Quote Originally Posted by evilrho View Post
    Hi All,
    Thanks!
    Better off in the e39 touring thread. Talk to M5 Jed he rents one and someone else iirc.
    https://www.bimmerforums.com/forum/s...Touring/page15
  20. #170
    Cincinnati, OH
    '01 E39 525iT, '04 E53
    Quote Originally Posted by danger525iT View Post
    +1 to this tool! if you use enough emulsion fluid, the harbor freight jack will also work to install the new bushings in record time
    '01 E39 525iT (Manual!)
    Suspension goodies in a grocery getter!
    '04 E53 X5 3.0 (Family Hauler)
    Mostly stock, 192,000 miles and counting!
    '09 E82 (Sold)
    '89 944 Turbo (Sold)
    '86 944 NA (Sold)
  21. #171
    France
    Euro M3 E36 3.0
    Hi, just did mine yesterday.
    A friend made the tool for me, and done the job in about 4 hours.
    I chose to put poly bushings, let's see how long they last...
    Didn't use the retaining bolts.
    In addition to WD40, you can heat up a little bit just before removing the old bushing, it makes the thing a lot easier. (like 2min at 600°c).
  22. #172
    Mar 2011
    Long Island, NY
    '91 325iX E30, '93 525iT
    BLACKBMWs - Would you be able to get the pics back up for this job? It will be very much appreciated!
  23. #173
    Oct 2017
    NorCal
    1999 540iT
    Thumbs up
    To resurrect...
    I'm getting ready for the bushings job now. I've reached out to Jase007 and M5Jed to rent the tool, are both still active? Is the tool floating around somewhere?
    Thanks everyone.
  24. #174
    Nov 2018
    miami, fl usa
    E39 540 iT Sport
    I have not logged in here on site in a while. However, after digging through my file , I see I replaced 4 original rear sub-frame mounts in the spring of 2013 with MEYLE HD # 33 31 1 094 036 (mfg# 300 333 1111/HD)....and I rented Jase's Franklin tool to do that. 2013 equates to < 100K mi. I seem to remember +- 90K and the old bushings had cracks. That mileage comes to mind as I always write the replacement part(s) install date big and where I can see it. Underneath the car looks like a calendar, lol. Those rear SACHS shocks are long gone and replaced now with BILSTIEN touring/ oem/ 19-106649 in Feb. 2018. These are steel bodied shocks compatible the (S227A) rears and I feel no difference from the SACHS aftermarket spec shocks. I recall 6 yrs ago being under the car R&R those bushings...man, used the foot to break a bolt or 4, cranking and cranking...sore body parts. It definitely made a difference in firmness and handling along with new rear shocks then. However, I still question the replacement with the MEYLE HD bushings. At about 153,500 mi. now they sure are hanging in there but, honestly, the rear end road feel, noise is not the same as my car when I got it at just > 20K mi.....and I have done a completer rear Lemforder rear arms ball joints, links replacement. The above mentioned ride quality is mostly apparent with a light load (fuel and otherwise) in the rear. Would I pull these solid rubber sub-frame bushings and put in Lemforder/ fluid filled now? Maybe if someone else did it for me...I don't know. last I did the front suspension arms, I used all Meyle and specifically for the thrust arm bushings. I think the Meyle HD sway bar links are better that the Lemforders I removed. Same as with the rear SF bushings, the FT. solid Meyle's have a different ride than stock OE/OEM. The E39 chassis is just real sensitive to outside road inputs (even the 540's with different steering). If you are going to rent a tool to do your touring's SF bushings, just remember to send it to the next user as clean as you would want it arriving to you....and read all these posts and elsewhere if need be. Ask questions.
  25. #175
    Sep 2019
    NE PA
    2000 528iT
    Jason
    Can I get on the list for tool rental. I'm in Eastern PA, north of Allentown.
    Fritz
    570 778-9945
    fritzs@ptd.net
