Originally Posted by
kgeorge81980
I have a 7/02 e39 525i. It was litterally a barn buy. However during the year the rats had destroyed several wire harnesses under the hood. Which i have re attached and soildered back together. All i could find any how It has a bad abs module pump as diagnoised by shop for previous owner. I have cut and spliced both front and rear brake ware sensors together. It has no cruise control not even the indicator lamp on dash. The windshield washer wont work. There is no power at the motor when tester but the fuses are good there is power at fuses 2 and 4 (i believe are their locations). It has a red brake light on cluster beside the ebrake light(which only comes on with initial key turn regardless of ebrake position) the yellow circle with triangle is always on. DSC button has no function or atleast there is no indication lamp when pushed, held, etc.it has the gauge cluster console with read outs of errors not the diagram of car. I have been searching these and other bimmer forums for a couple months now and have not found any cure for these issues. Thanks for considerations
