Just a heads up to everybody on the forums that I have a contact to get AP Racing brakes. I myself have ordered a 14" kit w/ 6 piston calipers. The calipers can be done any color you want and can even be color matched to your car. The bell housings or "hats" as there better known are also available in various colors (black,blue,silver,red,gold). My kit will have red powdercoated calipers w/ black AP Racing writing and gold hats w/ cross-drilled rotors. Please contact me through this post or through e-mail with your specs and I'll get you a price on everything. Later
Jared Sedacca
can you get a slotted rotor that will work with the Big Red Porsche kit? I don't really need the hat, just a slotted rotor that can mount up to it. I think it's a 322x32mm.
Justin Power
1988 BMW ///M3
Henna Red / Black
1990 BMW ///M3 race car
Diamond Black / Black
1998 BMW ///M3 Sedan
Alpine White III / Mulberry
hemm they have them for e30 4 lug set ups
Cars sold now
#150 WC emra
andrew vovou
U can buy that from a lot of brake rotor makers. You'll need to know what bolt pattern you have on your hat, and if it's fixed or floating design, if floating, what type of floating design.Originally posted by Justin(OKC)
Too many toys, too little garage space....
wow, you're planning to run 6pots upfront? Careful....you may find that the 6pots are too much for the rear brakes.
But otherwise, APs are a great choice.
96 M3 Evo 3.2(Euro) 321 bhp,6 Spd. You name the mod, I probably have it this side of forced induction.
Hey vodomagoo, I will check about the E30 4 lug setups for you. And about the 6pots it doesnt throw off your balance, you just have to learn a new braking technique which is totally different. Since most people are still use to there stock brakes they'll get into the ABS a lot quicker. Pedal modulation takes care of it all. We run 6pots on our BMWCCA race car with stock brakes in the back and have had no problems at all. Later
Piston size determines whether your AP Calipers are compatible with the master cylinder and rear brakes. I have had a AP kit for a while now and I don't have any problems. More clamping force does not mean, your ABS will always come on under heavy braking. Anybody can get an AP caliper and make a Big Brake Kit, but you must get the correct caliper. They have more than one style of 6 piston calipers.
please PM me with the price on this kit...thanks.
Sunir
M3 LTW
#22 HP
m3ltw98
Can you please PM me with the prices.
Rick
(Sold!!) 95 325is-3.2L OBDI, AA CAI, Euro AFM, AA Software, Eibach Pro System Plus, Lightweight Flywheel, X-brace, Stage 3 Port-n-Polish head w/5angle valve job, Schrick Cams, 24lbs injectors, 3.38LSD, Euro 6spd
(Sold!!)89 325ix-ESS Supercharger, Weicher Sport Stress Bar, B+G Lowering Springs, M-Tech Body Kit, 17in Rims
08 MB GL450 Wifey's Ride
07 VW GTI Daily Beater
