Thanks for the info, and does anyone know if there are any S54 pumps to stay away from? In searching S54 pumps I came across the bearing recall notice from BMW and it said they were replacing the oil pumps on the early ones along with the bearings. Anyone know the story?? Thanks in advance - Brien
Ya the one I got. I bought a s54 pan/pump kit from bimmerworld. They use new BMW parts in their kits. A keyway broke inside the pump and it seized. One in a million and I got the bad one.
Bimmerworld is working with BMW trying to get me some money for the damages thier defective pump caused.
Sorry to hear that. Do you know if the VAC pump upgrade kit would have prevented that issue or does it just deal with the nut coming loose? If it does I might have to go for the $200 -Thanks Brien.
1+ I'm wondering the same thing? How much are you guys filling up the motorsport pans to when changing the oil? I was told more than normal
edit: I have cooler and lines and won't be draining those with the pan, but still kind of confused. As of now I have two gallons sitting here with me for the job
I run my oil over the high mark just up into the upper spreader
whatchu got
Someone with more knowledge can chime in here but I don't see the point of overfilling if you have a dual sump/pickup setup. The point of overfilling is to make sure that the pick up is always submerged. With the dual setup you eliminate the possibility that the pick up will not be submerged in the pan.Originally Posted by Compactive
That said I always ran my S52/s54 pump setup filled to the top of the fill mark on the dip stick.
Sent from my iPhone using BF.com
Sure, if you don't use search...Originally Posted by Compactive
whatchu got
I get my info from Epic Motorsports. They have all the knowledge I needOriginally Posted by uconnr
whatchu got
LOL I did search, that's how I found this thread (and a few others). So now I'm here where the info is just trying to confirm some stuff, I found some conflicting info else where
play nice
thanks, you're very helpful. You must've had your coffee. I think I'm going to go ahead and just change the pump/pan oil, and save the cooler and lines for later in the year. Minus the cooler and lines, I've read we refill to 5.5 liters**? I understand how some of the other guys get confused with how its said to be 5.5 quarts in the pan, ~8 for the entire system, and what to refill each with when changing the oil.
That's vague to the recent poster. The dipstick is our reference for filling, what do you consider "overfilling" ?
Sorry, was still getting my coffee level up. Just hit me weird someone congratulating themselves on getting information (for themselves) from a good thread.
whatchu got
Fill it to the rim . . . with Brim.
Seriously, fill it to the "full" mark on the stick. If you have to fill it much higher than that to avoid low OP or lifter noise, you might want to go back in and adjust pick-up height and check for other issues.
Garrett
I can add, on the technical side, that in the process of re-installing an OBD controlled S52 and switching the S54 oiling over from my old M50, I was glad I saved the AN barb to pipe thread fitting that goes into the top of the oilpan from the oil recouperator. With the M50 intake it just goes back in to the intake boot. The S52 dipstick had a port for it, with the S54 you can just push the hose onto the AN barb fitting and you're good to go.
I mentioned this deep into earlier pages of this thread but it's worth mentioning again. The S54 pump bracket attach to 2 of the main bearing caps (S52 uses only one). These are factory stretch bolts (22nm + 50deg IIRC) and should be replaced after removing them. Reusing once after visually inspecting the threads - maybe, twice - no way IMostO
whatchu got
I am currently in the process of putting a new pan in and I really dont track the car at all, but I do take some hard corners along with some spirited driving from time to time. Is this something I should be considering doing since im down there and im buying a new pan anyway? I was looking into gettting a baffle from VAC, but I dont know if I should go this route. Keep in mind the car is Gt35r turbo, with 8:5:1 Wiseco Pistons, Arrow Rods, currently running about 15LBs, but soon to have a new tune somewhere around 21LBs. Looking to protect all of the $$ I have spent.
Considering the mods you have I don't see why not, but I consider this pan to be a true motorsport pan, for some serious cornering constantly through seasons. The baffle just doesn't do enough compared to the pan
So should I still do a baffle or not even that? I am atleast going to secure the oil pump nut.
True thanks for all of your help... I think this is the route I am going to go. The only issue is I scrapped the old pan because the drain plug was stripped only to find out that the other pan I had readily available was an S52 pan and I have a s50 dipstick. I think I am going to buy a extra large Oring in order to accomodate the S50 Dipstick in the S52 Pan along with some Black Gasket maker
To be honest...you really don't need the dual sump setup on a street car. You're never going to generate the g-forces necessary on a consistent basis to cause the oil starvation issues the dual sump setup is aimed to remedy.
You're better off saving the money and spending it on something else. Best of luck!
