Quick update, thank you to everyone that offered to help! I found a great car and am willing to pull the trigger however their is a lot of noise coming from the transfer case. Is there anyone in the area that has replaced the chain before on a 2001 e53? OR know of any shops with great rates and turnaround time?
Try A&L autobody in Palatine.
- Goin' H.A.M. Mobile
Folk's,
97 M3 set off a cel whenst maf to im finally cracked in the 100oF heat
That's fixed but I would like to get the light turned off.
(I know I should buy the Peake too but... maybe next time.)
Anyone in NW suburbs or maybe in the city could do this for a six pack?
Thank ya much!
Hi all,
I'm looking for a great, independent shop with good experience with E36 and E36/8 cars (S52 motors, etc.). I'm located in the Lakeview neighborhood, so the closer, the better. Also, the sooner the better. I have a bent differential tab that needs to be straightened out... Or, if you have a lift and a 2lb sledgehammer I can borrow, that would work too. ;-)
BTW - I just moved here from the DC area and I'm excited to be here!
2000 Z3M Coupe, Cosmos Black, Supercharged: Randy Forbes' magic subframe kit, Vortech/Dinan Supercharger, TCKlien DA front and rear suspension, TCKlien Camber Plates, H&R front sway, Clutchmasters FX300 w/LW steel FW, UUC tranny mount brace, UUC SS clutch line with CDV delete, Turner Shorty Headers, B&B TriFlo exhaust, SS brake lines, dual-ear E36 M3 diff, IE subframe bushings, Whalen Shift Machine and E-brake handle, PLX DM100 gauge+sensors, aftermarket audio, Apex wheel studs, and even a Euro glovebox/driver's side knee panel swap"BMW - Designed by Germans, driven by tossers." --Jeremy Clarkson
SOLD 2006 Z4M Coupe, Sepang Bronze: Stromung exhaust, DFK Section 1 w/resonators, RPI ram air intake, and Whalen Shift Machine.
BMW CCA #375064
hey man, how's it goin? I'm in the west loop and just a few blocks away is a shop called rn Bavarian motors. all they work on are bmws, that's it. if you check it out, tell them alain Milotti sent you. won't do anything for you, but at least they know where the love is coming from. do a google search and you'll find em.
I found WizardWerks and have been very happy with their service so far. Straightforward, upfront and cool to work with. They took care of my custom diff tabs (I have a custom dual-ear diff) and are currently replacing my clutch. Thanks for the reply though!
BMW CCA #375064
I found this while perusing autotrader for a 3 series touring with msnual trans:
m.autotrader.com/vdp.html?id=322869901
It's a 2000 323 Touring with an M3 conversion; drivetrain, suspension, and a front bumper cover. The dealer is clueless. Anyone here know anything about it?
Thanks - Colin
Yep, that's it. I wonder how they plan to sell it without any records on it?
That VW dealer is less than 10 minutes away, I'm going to go test drive it this weekend
Does anyone know of a BMW specialty shop in the south suburbs?
Hey folks. Anyone familiar with a decent exhaust shop near Oak Park? My entire exhaust broke off just before the cat so I need someone to weld up a new section to a new muffler. Unless you're good at exhaust pipe-bending and welding and enjoy getting paid in beer for work done, of course.
Just find a Valsquez and sons, they do good work on the cheap.
Anthony the owner of iND sent me there for mine so I figured it would be fine.
Lil help!
I turned my DTC off the other day and when i got to my destination shut the car off... Do my thing and go back to my car, started it up an the DTC was still on, then it gave me a warning light ( DTC off light with a ! Right next to it) the another warning light hand brake applied (in yellow, with the ! In the center) then, on the way back home i noticed the turn signals didn't shut off automatically after i come out of the turn. Then after a while everything was back to normal... No more warning lights.
But then it happened again and now they staid on.
Any ideas?
yeah i personally dont think it had to do with the DTC being turned off, BMW uses that symbol for a lot of stuff. Check the manual for which warning that was just in case.
I read somewhere that has to do with the brake sensor being worn. But What does that had to do with my turn signals tho?
Anyone up for a Lous meat?
which location?
Anyone in the chicago area have an SRS tool? Bought my m3 with an airbag light and wanted to pull the code/reset it if it's not an actual issues.
Anyone with an E60 M5 looking for an exhaust? i have a couple for sale. Let me know. PM me
I'm in the need of a R/H headlight, non Xenon. Pm me! 07 328i
Just accepted a job in the Rolling Meadows area, and relocating from Raleigh, NC. Looking forward to being a part of the Chicagoland bimmer group!
I've got a '98 36/7 M Roady that I've dumped a lot of money and love into.
2018 X4 M40i
