11.75 @ 131 6262 2.8l TRM Tuning e36 m3 - 2011 http://dragtimes.com/BMW-M3-Timeslip-23541.html
Glad to see you back Dan
Good luck findin a car sir! I'm glad to see you back in the game.
I like the sig pic!
Good luck finding a suitable car for the motor. 500whp is going to be a lot of fun.
I would think Mr. Nick Glantzis could find a way to keep it OBD2 compliant, pass emissions in NC, and squeeze out 500rwhp. I would keep it.
twin turbo the 540?
Bump, did you find a chassis? Is it turbo yet?
Welcome back.
I miss your old thread.
You should use the cams from your S52 in your built motor instead of the 2.8L cams. Good luck in your build.
'97 M3- GC Track/School|Spraco strut bar|X-brace|UUC Swaybarbarians|w/ VMC adj End links| UUC systemU|SouthBend stg5 clutch|Powerflex RTAB/LCAB|UUC Red Tranny mounts|M50mani|Greddy EBC|Innovate LC-1M52 Crank, Cams, Pistons, Rods:
Check out John's dynos, S52 cams are better period.
The S52 cams will help with making power, more power is always better right?
Very good comparison between his 2 dynos. http://forums.bimmerforums.com/forum...54&postcount=1
It's really all up to you.
wow man miss my old car already, looks like it's in the right hands now with someone that knows what they're doing and has a lot of support from the forum crew. good luck with everything, i hope my old car does you well and you get to the power point you're looking for, very excited to see how she turns out. engine bay looks a lot better by the way!
guess i should take this pic down and post up my new car soon, haha. "2002 e46 m3 imolarot red". koni coils, carbon fiber front lip splitters, black inserts all around, in dash nav. black leather interior. headers no cats shark injector soon. Thanks Dan for making it possible. Good guy.
What manifold?
Nice, I really like all the powder coated stuff. I may do the same thing, thanks for the S52 cams btw.
| 1997 Estoril M3 - TURBO - || GT35R | 8.5:1 forged internals | ARP stuffs | SS Oring Block w/ elring | Fully balanced & blueprinted 3.3L S52 | Nick G Tuning || 46mm Precision gate| 62# injectors | Dual Walbro's |Goal: 600+ whp pump gas reliable 10 second car.
-2007 335i Sport Package
who did your powder coating?
the shop near mpowered auto?
looks good
2010 - BMW 335i M-Sport - Lemans Blue Metallic
BMW PPK2, JB4 with NLS, Backend Flash, BMW PP Exhaust, Misc Appearance Mods, Boost Addictions Diff Brace, BMS DCIs, BMS Clutch Stop, VRSF Catless DPs
Previous:
1995 M3
1998 323is
Wow!
I am really like this build! YES!
-painted engine bay.
-powdercoated parts.
-top mount OBX t4.
-pt6262 0.68 a/r
I am sooo excited to see you using a sick turbo with the OBX top mount manifold. Wahooo! A proper testing right thur!
Waiting for more pics.
I did that for a long time with my tec 3R setup. I simply had to go with the coils needed due to the valve cover I used. I went from OBDI valve cover to OBDII when I switched to the vanos m52 head, but the OBDII one I had was plastic and started melting on the edges = no bueno. So I went back to OBDI valve cover and had to change back to OBDI coils, yet was using the OBDII engine harness the entire time.
No idea regarding stock DME though.
Hey I see your ground/sanded the powder off the lid. Did you sand the bolt area out? If so, I did the same thing, and it leaked. My suggestion would be to get a new lid and not touch the area where the sealing washer goes. I thought I was awesome for using a dremel w/ sanding disc since it fit in there perfectly... but apparently that wasn't flat and it leaked like a turd.
How else would you get powdercoating off of it?
It just looks shinier than if it were taped but whichever!!! Good luckz!
Subscribed just to see how that manifold does... power and reliability wise.
~Ken~ '99 M coupe THE "original" TT Stage 3 - HTA3586R; 701 whp 672 wtq @ 26.5 psi ; NeverSell - CoupeCartel
Interested in the mani too. May try to use it for my e36 build once i get some cash freed up. Nice to see someone else near Raleigh! Im in wilmington for school, but parents are in Raleigh.
