I just purchased an 02 M coupe and got the eep2 code. The guages and instrument cluster wouldn't work when starting the car, then after shutting off and restarting it would work again.......but the speedo has been off quite a bit, at 70mph it reads 90.......at 45mph it reads 60.
Any thoughts or suggestions? I did just purchase the car and had it shipped from Los Angeles to Michigan, wondering if the cold weather is effecting it.
Going to have the speed sensor cleaned off and the cluster software reset using this method. Hope it works.
http://forums.bimmerforums.com/forum...es-in-your-car!
I have experienced the same. It is definitely temperature related, once the weather warms up I no longer have any problems. I have not found any solutions other than having the cluster replaced. Maybe others have found a simpler fix.
Pani
2001 Laguna Seca Blue M Coupe
Definitely affected by temperature but it's an indicator of a coming permanent failure. After much frustration and dead ends I just replaced the cluster. Also - let the dealer do it unless you have a contact that can encode eeproms or whatever other voodoo goes on in there (this is coming from someone who refuses to let anyone do anything on his car).
If anyone has an EEP failed cluster they would like to donate for dissection, PM me.
So i called a company in FL that repairs clusters, he told me often that the cluster is fine and that there is a problem elsewhere in the car.....i.e. bad ground, short or bad sensor somewhere.
So it hasn't happened since your cluster was replaced?
What did the dealer charge you for labor and cluster?
Previous car in order: 98' M3 sedan, 97' ITR, 03' EVO 8, 06' EVO RS, 06' S2000
I had the EEP_2 where the tach and all gauges were dead, tried everything I could find on the net with no results. Had to bite the bullet and take it to the dealer where they replaced the entire cluster and reflashed it (21,000 miles), cost $1,700.
That sounds steep. The labor is 1.5 hours ($150) and my cluster cost $700 from bimmerzone.com
Reviving an old thread and copying another. I'm hoping there's a solution between the two threads.
02' 3.0i with 156K on the clock, right outside of DC. I'm trying to resolve the EEP_2 error that I receive every time I start the car with temps anywhere below 45-50 degrees F. Only the speedo works at the start, but it's inaccurate by about 15-20 mph. Once she warms up and I restart the gauges all come back on, but the speedo is still inaccurate. I drive about 30 min into work and park in a garage for 8-9 hours; at the end of the day the gauges are usually all working again.
Based on this thread, I think I'll try replacing the oil level sensor first (https://www.bimmerforums.com/forum/s...trical-problem). It would make sense that if that sensor is faulty, it is possible that cold mornings have a bigger impact on it than if the temp is higher or if the oil is warm. Considering the low cost and ease of installation, it's worth a shot to have someone finally confirm a solution to the EEP_2 problem.
If that doesn't work, I have a cluster from a '99 2.3 that I'm hoping will work as a replacement.
Cooper
'00 Alpine III M Roadster (2017-Present)
'02 Topaz 3.0 (2009-2020)
'97 Montreal 1.9 (2005-2009)
AFAIK in most cases the issue is caused by cold solder joint inside the cluster. Depending on temperature it can loose contact causing error, and when it's warm, metal expands and contacts are good again. Resoldering cluster usually helps, sometimes it needs to be recoded (reset) after resoldering if error still stays here.
This problem sounds very similar to the odd electrical problems on the 850. Given the z3 is a few years younger, stands to reason we could be starting to see similar failures. In the case of the 850, many of the issues are traced back to the "General Module". The culprit inside the box were 6 capacitors. These capacitors are little cans of foil, paper and oil. When they dry out, they present problems when cold. If the cluster or the module driving the cluster has similar capacitors on the circuit board, I suspect this may be your problem. The capacitor types I am referring to are the can type, not the little disks that look like an Advil pill. In the case of the 850, it was under 20 bucks in parts, incl shipping and a Saturday morning with a soldering iron and a big ass magnify glass for these old eye. After I completed, all the oddities with the systems on the 850, there are many, stopped and the car runs and acts normal.
Dan "PbFut" Rose
I replaced the oil level sensor yesterday and checked this morning once all was cold and it did not fix the problem, So new cluster is it for me now, I bought 2 of them new at the dealer 3 years ago and 1 has failed already with about 1500 miles since it was installed.
I got eep'd today... Still no known fixes?
May just have a non-M cluster converted to S54 and rock that. Maybe ill open the cluster and take a little peek first
I jumped the car after sitting and the battery going dead. Eep_2... Pulled over, restarted... All good. Ok cool. Driving to work 3 days later... Tach shuts off, coolant shoots to the moon but no red light and EML (but no EML related issues...?).
PRICE CUT on ALL FABRICS
I wonder if it's caused by severe weather fluctuations, but that's not very common in your area.
-Abel
- 2000 Z3: Many Mods.
- 1999 S52 Estoril M Coupe
- 2016 Mini Cooper S
Probably. I was eep'd before, at the tail end of last summer. But restarted and it was fine. Its been stored in a garage all of this summer until that first drive a few days ago and its been outside since
I am troubleshooting the cluster in a 2002 Z3M with the EEP_2 error as well. My oil level sending unit is also bad on the car, I will replace that later.
Other codes within the cluster were:
8C Power supply Term. R
C7 Fuel tank sensor 1 (fuel pump side)
The main issue is if the cluster is receiving power or not, and if so, why the 8C error? Further testing will be performed this weekend, I will post results
Regards,
Brian
Cave Creek, AZ
UPDATE - My Z3M cluster with the "EEP_2" has been fixed.
Very high quality of work is performed here: https://www.msportparts.com/collecti...repair-service
Brett did an amazing job in repairing my cluster and restoring it to better than factory new.
Before:
After:
Regards,
Brian
Cave Creek, AZ
Nice find. Followed your link. I see lots of old Electrolytic capacitors coming out in those pics. Those wreak all sorts of havoc in old electronics as they dry up and go out of spec.
Yes thanks. I bookmarked the site in case I ever need it.
