Page 2 of 2 FirstFirst 12
Results 26 to 42 of 42
Thread: crankshaft bolt removal HELP
  1. #26
    Nov 2013
    Hanover, MD
    '97 328ic, '03 330i 6spd
    Thanks for all the input fellas. I'll get the guides before cracking into this. I changed to a single flywheel when I did the clutch, but I'd be willing to try pliers and the locking pin, still.
    But I'm going to go with Rajicase's method that I hadn't heard of yet but makes sense. Thank you sir....sounds like it'll save time and money!
  2. #27
    Mar 2011
    Redmond, WA
    02 330xi i || 01 X5
    Quote Originally Posted by flyfishvt View Post
    I have to disagree. Looking at where that locking pin inserts into a dual mass flywheel I just don't see how it's possible to warp that flywheel.
    You're probably right but I just did the timing chain guides on my buddy's 740 and didn't want to risk breaking something else
    Yoy.
  3. #28
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by SergeK View Post
    You need a breaker bar and a long pipe to put onto the breaker bar. And you'll also need some BIG BIG pliers to hold the crank pulley.
    Anyone got a picture how to do this method.
    Fortunately, 5th gear and on the brakes got it, but I think the clutch (and/or brakes) might have been slipping initially.
  4. #29
    Jul 2012
    Orlando, FL, USA
    1993 BMW 325i
    Was in a pinch yesterday when my impact/compressor wasn't up to the task. Using 5th gear + ebrake (I was by myself), a breaker bar and jack handle did the trick. Excellent tip, much appreciated.
  5. #30
    Nov 2013
    Oneida, NY
    1993 318is/who to knows
    Just wondering... I have this crankshaft that.. Uh.. Somehow still has the bolt and pulley on it. And. Ugh. WTF.... Anyway. Will this crank break if I set it in a vice close to the pulley and pry the crank Bolt off? Don't ask me how... All's I know is it's a 3.0l crankshaft from a trade.
    -Oakdizzle
  6. #31
    Jul 2017
    San Francisco
    540i
    The witch is dead
    It's left lousy, I just removed that Mug from my 99 540
    I applied a heavy amont of penatrate to outside of bolt on Wednesday. On Saturday i put the flywheel pin in hole and used a 3/4 breaker with 27mm socket and 4ft lead pipe. It put up a slight fight but started releasing after a 1/2 turn.
  7. #32
    Apr 2019
    Utah
    850i, 325i
    Regular thread. MUST have cheater pipe on breaker bar with about 4' of leverage. I wedged a cold chisel on a tooth on the balancer (850i) and still had to pull hard on pipe to break it loose.
  8. #33
    May 2019
    Wichita Falls, Texas, USA
    2001 BMW 740IL M-Sport
    You can take this bolt off in 5 minutes with the right tools.
    3/4 in Breaker Bar (Ratchet)
    27mm Socket for the 3/4 in Breaker Bar (Cannot use a 3/4 in to 1/2 in adapter I broke one trying)
    Flywheel Pin (less than $10 online)
    And 4’+ of metal pipe to put on the Breaker bar and use as leverage
    You must note my model required the steering wheel to be turned all the way to one side so the flywheel pin could be inserted.
    Used this method for a 2001 BMW 740il
  9. #34
    Jan 2002
    outta SoCal, now CO
    '98 M3 Alpine White
    Easiest way is a torque multiplier.
    See ya later,
    tony
    '98 M3, '92 Dinan3, '05 R1100S BCR, '07 R1200S, Aprilia T
  10. #35
    Feb 2016
    tempe, az
    1998 Z3M, 2006 330i
    What has worked for me a few times is the method of putting a long breaker bar/socket onto the bolt, getting it firm on the frame or the ground, then hitting the starter for one second. I always put a piece of plywood between the bolt and the radiator, for protection.
  11. #36
    NW suburban Chicago
    hiss by my window
    Quote Originally Posted by kryatov123 View Post
    you do know you need to twist it the other way? not like any other bolts,
    NO, it is right hand thread like everything else. Righty tighty, lefty loosey.
    Given the force needed to break one loose someone so misinformed would perhaps snap off the bolt or do other damage trying to undo in the wrong direction.
    with the engine in situ a long bar can be leaned on the left side frame rail and the starter employed to turn the engine. You need to be very careful, have anything in harms way out of the way, including yourself. With a bit of a gap between the bar and frame the starter has a chance to build inertia.
    Crude but effective, for me anyway.
  12. #37
    NW suburban Chicago
    hiss by my window
    You need a breaker bar and a long pipe to put onto the breaker bar. And youll also need some BIG BIG pliars to hold the crank pully. I do this atleast once a week at work. ive got it mastered.
    A pliers?
    I want to see the guy who is going to grip that, with a stinking pliers, against a long cheater bar.
    Show me please
  13. #38
    Feb 2016
    tempe, az
    1998 Z3M, 2006 330i
    A word of caution: loosening via the starter works, but does not provide a way to properly torque the bolt down at re-assembly. THIS IS MANDATORY! I once lost a whole engine because I didn't do this. The crankshaft pulley got loose and destroyed the crankshaft. I think if I ever to that job again, I'll safety-wire it.
  14. #39
    Jul 2016
    Pico Rivera California
    2009 X5 SUV
    Good mechanic story:
    I have 2009 BMW X5 is leaking oil from an engine seal (crankshaft). In order to removed the O ring seal I have to remove the “Jesus Bolt” (so they call it )
    On my First try I broke the 27 mm socket. See pic
    Second try I broke an 18” Breaker bar. With No luck see pic
    I used a flame torch to light up Jesus, again no luck.( according to physics if you heat up metal it will get soft)
    Guess what? Lighting JESUS did not help either.
    I exchanged the breaker bar and socket which they have life time warranty ( lucky me, I saved some money here)
    Again, I tried with the new breaker bar with no luck. But I managed to break the breaker bar again. See pic.
    When I took the breaker bar to get it exchanged... again ...they asked me why am I keep breaking the bar, I told them that Jesus is punishing me.
    Now I am running out of options.
    JESUS please help!!!!
    By the way, I made a tool to help me get the Jesus bolt out with no luck. FullSizeRender.jpg
  15. #40
    Jan 2002
    outta SoCal, now CO
    '98 M3 Alpine White
    See post #34. AND, use an impact socket - they're thicker and not as prone to cracking or shattering.
    I've also used a 1" impact tool but I don't advise that for fear of damaging the case hardening on the crankshaft nose.
    See ya later,
    tony
  16. #41
    Jul 2016
    2009 X5 SUV
    Hi Tjm3
    It is actually what I used, black impact socket but it was the long socket the one I broke. I am using the the short black impact socket one now. It looks like my last option is to grind the front lip of the hub where the bolt sits and replaced the hub and bolt. I have tried to removed this bolt for a whole week. Wish me luck. Thank you for your advice
  17. #42
    Jan 2002
    outta SoCal, now CO
    '98 M3 Alpine White
    I'd check with a couple tool rental places to see if they have one of the torque multipliers for rent. They work very well for this function.
    See ya later,
    tony
