I did some research and found out that miller pricing is pritty fair, just the new sensor alone if you were to get it yourself in a store would cost you $170US.
We do plan on doing a low octane tune. The best way to get that would be with the WAR Chip when it comes out. It isn't needed for the MAF Conversion, but the WAR Chip will be a special chip that has the ability to select between three tunes and if the user wants to, can tune themselves.
They can be any three tunes. For people like yourself, a low octane tune, a high octane tune and vallet mode etc. With the flick of a switch, you can have the cheap gas for daily use, or premium gas for some weekend fun.
Of course the MAF will work on an Auto. We only have GenIII software developed for the 173 ECU and newer (380, 525 etc) so if you have a 153 ecu, you will have to wait.will the MAF + Chip setup work on an auto? what sort of money would be on shipping to ireland/the UK?
Shipping to Ireland is around 45 dollars, and it is sent through the post.
Thanks for letting people know you got the kit installed! Let me know if there is anything else you need, we may have a cold start update for the 19# injectors soon.
The WAR chip with three tunes would be awesome. That's Perfect for when gas prices go sky high and you're doing lots of highway and don't want to spend on premium. I'll just keep my eyes open for the chip release, but do you have any round about guess for a price on the MAF and WAR with low and high octane tune? Would it be more economical to get them together if you guys plan to offer some sort of package deal with WAR release or something, or will they be separate either way so it wouldn't matter if I got the MAF now? If you're not sure that's fine. I couldn't rationalize (probably putting ~$400 into the car in the next week already) getting the MAF for a few months anyway.
How is the WAR chip coming along?
waiting on war chip
There is another way of having a Motronic 1.3 emulator. It is called Ostrich2.0 with TunerproRT software and 173 ecu definition file you can tune your E30 the same way as the WAR chip and it is already available for free. You would need Ostrich2.0 emulator cost $180. Tunerpro will come out with "map trace" so you can see what part of map ECU is reading. I already got this.
You can tune almost everything in real time even tune for different air mass meter.
You can get the definition file at ecuproject.com, software at tunerpro.net and hardware at moates.net
Would it be possible to swap in an "I" ecu into an eta and then use WAR chip to tune it so it would work right?
So is there any reason why it wouldn't work? What if I swapped the whole fuel system+i computer into the eta?
Here's a link to the E30tech thread about the Check Engine Light problems with the MAF install. http://www.e30tech.com/forum/showthread.php?t=112717
I did the MAF Install with the WAR chip and the check engine light is on about 50% of the time. It's ridiculous and effects the credibility of this product.
Sorry to resurrect this thread, but...
Is Miller still in business? The phone # on their website is not in service. I've had no response via their website questions form. Their Facebook doesn't have a post in forever.
I ask (as per my active thread) I bought an '89 325i with the Miller MAF conversion (with the 173 chip) and I think my MAF is failing. I can't figure out what the replacement MAF is.
I think I need a new MAF and don't know how to figure out a replacement.
Surely others have been here before?
TIA!!!!
Dan Perez | 2002 E39 530i | caretaker 1989 E30 325i 4 door
I seem to recall some folks saying that they weren't getting responses from Miller so not sure. I know that I was able to trace the MAF from my miller set up to a certain MAF used on Ford trucks, but I don't recall the details. Yours could be different anyway. If you haven't already, try googling any number/code you can find on the MAF, often times you will get hits from parts sites then you can trace the part back up to its vehicle applications. Then you can buy a new one or head to the salvage yard to find one.
Sorry for broadcasting out duplicate info on two threads, but I ordered Bosch part number 0280218032 for $70 off Amazon.
I will report back if it works.
Pull the actual sensor out of the housing and perhaps there is a p/n for the sensor that can be sourced.
if you are in vancouver or bc they will respond as that is local to them. i'm pretty sure they are ending the e30 stuff in favour of newer platforms. they will do a custom tune if you can take the car to the shop in abbotsford.
edit : called their local line direct and it is also disconnected. at this point i'm leaning to they have either shut down completely, or are trying to restructure after covid wiped them out. i'm trying to see if i can contact anyone out there to go past the shop.
It's not a "gimmick", I bought mine a couple of years ago, and even got support via email (turned out I had the wrong injectors), and it has operated flawlessly and breathed a lot more life into the engine (no pun intended). Entire race series have adopted and approved the Miller MAF because it was becoming too expensive to find and repair old AFMs for a grid full of e30s. Far better technology than the antiquated AFM "barn door". Problems with the company doesn't make the product bad.
