Results 26 to 50 of 65
Thread: Mojo's Quick-N-Dirty™ E38 Subwoofer Installation Guide
  1. #26
    Jun 2005
    NorCal
    '00 528iT/ '12 Tacoma
    i needed the hi-low box to convert the signals into rca...but now its sittin in my trunk as I got a deck...and am runnin straight from the deck... =(
  2. #27
    Wolverhampton, England UK
    BMW 728i, VW Storm
    Smile Sub/Amp install for DSP e38 1999
    I own a 1999 E38 728i in silver with DSP, after reading the threads about obtaining a sub-out, I purchased a high/low convertot and a pack of scotch-conenctors.After studying Mojo's posted photo, attached the convertor using the connectors and installed a sub/amp, sounds great, much needed improvement on stock sound.Following this I also removed the stock subs on the rear shelf, but this made little difference.
    Keep up the good info on the forum.
    Jaz
  3. #28
    Apr 2009
    Cumming, GA (ATL area)
    e38 97 740il
    Just DON'T install the amp power line to the CAN BUS as shown, connect it directly to the battery positive. I have tons of damage from connecting it to the CAN and you could too... Just a friendly FYI.
    1994 325ic - 5spd - Dinan Stage II - CF Intake - Exhaust - Throttle Body - Software - Suspension - M Bumper and Door Trim - Smoked Lights
  4. #29
    Dec 2008
    uk
    e34,e39
    my e38 dont have DSP,have just regular stereo,its possible to install subwoofer in my car,i have subwoofer with amp ready...
    Aug 2008
    Hesperia, CA
    2001 740 i Sport
    Thanks again for the post bro everything worked like it should!!!
    [/IMG]
  6. #31
    Bay Area, CA
    Not a Ferrari
    Quote Originally Posted by subspd View Post
    I didn't connect the amp power wire to the CAN bus... The 5th wire is the remote power wire, all it does is signal the amp when to switch on. Look at the picture showing the battery.
    1995 540i/6 // Dylan Leff - www.originalplate.com
  7. #32
    Sep 2009
    Wilmington, DE
    07 GMC dmax 05 hd 1200
    i know its a bit old and im about to do this, the DSP is still usable to adjust bass and whatnot?
  8. #33
    Bay Area, CA
    Not a Ferrari
    Yes. All of the equalizer and reverb settings are still adjustable.
  9. #34
    Feb 2010
    Orlando, Fl
    2003 E46 Sedan
    can't see picks.
  10. #35
    IcemanBHE's Avatar
    IcemanBHE is offline żpǝpɹɐʇǝɹ noʎ ǝɹɐ
    Wichita,KS/FortCollins,CO
    (4x7)+8=36
    I vote Mojo repost this in the DIY forum...
    95 840Ci, Calypso Red/Silver, 83k - 99 740i, Black/Black, 185k, Alpina Mods - 01 740i, Titanium/Silver, 40k, Sport Pkg
    Complete Turnkey Diagnostic/Programming systems available...PM for details.
    http://www.8Coupe.com - Please register, spot, and help the project.
  11. #36
    Feb 2010
    USA
    2001 E38 - 2003 E53
    Yes please!!!
  12. #37
    Easton,PA,USA
    BMW's
    I'm not seeing any pics
    2006 M3 ZCP--Black/Black, NO sunroof, GruppeM Titanium exhaust.
    2001 740i--Black/Black(Sport). Mods: Angel Eyes, MKIV Nav, 750 Brakes(front)
    1995 525I (Touring)--White/Tan. Mods: M-Pars, BMW low slung springs
  13. #38
    Apr 2008
    Hudson Valley, New York
    Too many to list.
    I CANT SEE SHIT! bandwidth exceeded.
  14. #39
    Xephius's Avatar
    Xephius is offline 665 Neighbor of the Beast BMW CCA Member
    Dec 2009
    Houston, Tx
    '00 740iL, 01 325xiT
    Mojo, PM me the pics and data, I will knock together a PDF/html and host it on my site. We can see about mirroring it on e38.org too.
    X
  15. #40
    Sep 2008
    Aarhus, Denmark
    BMW 750i E38
    I want the pics too! Re-upload please
  16. #41
    Nov 2002
    York, PA
    2000 740i Sport
    I made a mirror of it on my site awhile too. I suppose now that I have a 7 again I'll finally get around to working on my e38.org mirror project again lol. One of the things that annoyed me about e38.org was it's reliance on external data.. sometimes a link will lead to a dead page or a forum post /w dead pictures. I want to make a copy of e38.org but with all data archived local so it can never vanish. Guess I outta get my butt back to it, heh.
    http://www.e38bmw.org/default.asp?a=254298311798119
  17. #42
    North Cali
    740iL/66 SS Chevy Impala
    Quote Originally Posted by mojocoggo View Post
    Honestly, the only reason you'd want to use the preamp lines is if you are running ALL of your speakers off an aftermarket amp. If you are only running subs, the factory subwoofer channel is just fine.
    Ok, I'm a bit illiterate.
    So I have a box with two woofers, I also have a rockford fosgate amp laying around somewhere.
    DO I HAVE TOOOO install ANOTHER AMP??
    WTF is the factory amp for then? can't it pump enuff juice to power a box with two 12 in it? I'm confused. I just wanted to plug and go.
    Are those wires you show coming out of the amp for subs or are those just general left and right channels? help. illustrate us more plz. I'm ignorant.
    Nevermind, I just read somewhere else that the stupid DSP amp only has 450 watts or something. So I am going to that other amp I have. Now all I wanna know is, the wires yo ushow, are they pre-amp wires or what? help. and which hi/lo converter should I get?
  18. #43
    California
    750IL
    So if I buy something like this - http://cgi.ebay.com/2-Channel-RCA-Hi...ht_1890wt_1036 - I can just connect the 4 wires that they used to this box? Cuz it looks like there are 4 wires to the hi lo box so I guess I just match the positive and negative for each side to match the box?
  19. #44
    Ireland
    2005 E66 740Li
    Either that or just connect the four cables to the high level inputs on your amplifier.
  20. #45
    Bay Area, CA
    Not a Ferrari
    I don't see why you'd ever need a hi/low converter box. I've never seen a car amplifier that didn't have a built-in HPF/LPF capability. If you are just running a sub from your amp, plug that junk straight in.
  21. #46
    Mar 2008
    Thousand Oaks, CA
    2007 Alpina B7
    ahh....maybe due to the fact e38 audio hardness doesnt come with RCA plugs..hence the hi-lo convertor....
    2000 740i Sport
  22. #47
    Oct 2008
    Bay Area
    1999 740IL
    Quote Originally Posted by cazal740i View Post
    +1, only for the RCAs
    Some amps you can hook up directly without the RCAs.
    '99 740iL "illest 7" | 16:9 NAV w/ MKIV | Bluetooth | Maintronic CP600BMW MP3 | Porn Lights | LEDs in & out | BMW Style 101 | Stanced - Hellaflush offset & slammed | AirREX Stage 3 air suspension | NEX BBK 6 pot 355mm front, 4 pot 350mm rear | custom intake & exhaust | steptronic conversion | AC Schnizter front lip & roof spoiler
  23. #48
    Murda1591's Avatar
    Murda1591 is offline Mr. Boombastic BMW CCA Member
    Sep 2010
    Nor*Del
    '01 740iL (E38) Sport
    What wires would you be tapping into with the LOC, the old subwoofer ones? And are those wires the same color on a 2001 740?
    Quote Originally Posted by My98HellrotTi View Post
    Will you give that fender some lipstick? Cause I bet it at least wants to look pretty the next time you decide to **** it.
  24. #49
    May 2010
    Las Vegas
    05 LS430 UL + 12 FIT SPT
    I gotta do this soon!
    750IL SOLD....I'll miss you!
  25. #50
    Murda1591's Avatar
    Sep 2010
    Nor*Del
    Quote Originally Posted by Murda1591 View Post
    ^ Also, does anyone know how to remove the navigation unit? I cant figure it out haha
