Results 1 to 25 of 65
Thread: Mojo's Quick-N-Dirty™ E38 Subwoofer Installation Guide
    Bay Area, CA
    Not a Ferrari
    1995 540i/6 // Dylan Leff - www.originalplate.com
    Apr 2008
    Golden Colorado
    84,94,95,97 740s/745i
    dude you rock thanks alot! this just made my life so easy man.... I will tell you how it goes... as soon as its warm out
    Oct 2007
    Henderson, NV
    145 cylinders of power
    ghetto fabulous
    Quote Originally Posted by Sasa Ivanovic View Post
    This only works if you have something with a built in amplifier. If not you can use a high to low like I did.
    Random Sig below (refresh to see new image)
    Dec 2008
    Toronto
    1998 BMW 740i, 98 A8
    Really appreciate this one! Lovin the bungee cords lmfao!! Will be doing this as soon as my car reads into the +celcius digits!
    Aug 2008
    Hesperia, CA
    2001 740 i Sport
    I like! I have a 10 inch amplified base tube and the quick and dirty way is for me thanks!
    [/IMG]
    Mar 2008
    Los Angeles
    98 M3/4/5, 97 740iL
    How come you didnt use the adapter everyone else uses, the LOC or something like that?
    Dec 2008
    Austin Texas
    1969 e10
    I have that same backpack
    Bay Area, CA
    Not a Ferrari
    Quote Originally Posted by Am3n View Post
    The who? I am not aware of such technology. Where would it go in my equation?
    Mar 2008
    Los Angeles
    98 M3/4/5, 97 740iL
    Its the box that everyone uses when they hack into the existing sub wires... Its a little box that allows you to use the RCA audio mess.
    Nov 2007
    London, Ontario, Canada
    BMW 733i, BMW 540i/6
    whats does the bmw stock speaker connectors look like??? i'm thinking of upgrading the rear deck woofers...
    1994 BMW 740I E32: SOLD
    1984 BMW 733i E23: Hartge engine, Hartge strut brace, Centra type 7 staggered 16" rims
    1997 BMW 540i/6 sport: polished/ported throttle body & traction control unit, E60 short shifter, ss braided flex lines, 2000 M5 tail lights, genuine Alpina bumper lip, genuine M5 auto fold mirrors, facelifted color matched trim
    Bay Area, CA
    Not a Ferrari
    Hmm, I like my way better. Just simpler. <3
    Quote Originally Posted by ProStreetDriver View Post
    The wires are soldered onto the speaker contacts. So you'd have to cut them and then crimp on spade connectors.
    Mar 2008
    Thousand Oaks, CA
    2007 Alpina B7
    that lil BOX is a Hi/Lo convertor......... ...lol
    2000 740i Sport
    Naples, FL, USA
    1998 BMW E38 740il
    Quote Originally Posted by cazal740i View Post
    care to say more? other than laugh out loud ha ha ha?
    is it for converting speaker wire into the amp?
    Dec 2008
    nashville, tn
    e38, 72c10, 67tr4a
    they hi/lo converter just allows you to run rca cables to a an amp/ subwoofer setup...you still hit the wires that mojo hit, but you'll have an rca connection there now...really easy to hook-up....you can do a clean amp install in no time at all without having to run wires to your head unit.
    here are some examples of converters:
    http://www.installer.com/hilo/
    Central coast Cali
    None. Got a sportster.
    and that's got dsp, yes?
    Quote Originally Posted by Chris V View Post
    Your opinion is based on a mistaken notion and lack of knowledge. It's your right to HAVE that opinion, but it's my right to tell you it's wrong..
    Presiding chairman, founder, and chief complainant of the NAALP: the National Association for the Advancement of Left-lane Passing
    Naples, FL, USA
    1998 BMW E38 740il
    Quote Originally Posted by steve0suprem0 View Post
    reading composition ftl
    Quote Originally Posted by sneakysneaky View Post
    alright, that's what i thought. nice...
    Mar 2008
    Los Angeles
    98 M3/4/5, 97 740iL
    Sweet, so I can just do the same thing Mojo did but connect my hi/lo instead of the amp directly?
    Doph what ever happened with your subs?
    Dec 2008
    nashville, tn
    e38, 72c10, 67tr4a
    yes....no cutting is needed either, just use some fold over connectors and you're good to go...no need to trash the factory harness.
    Dec 2008
    menomonee falls
    89 750il 95 540i/6
    Nice, I did my e32 kinda like this, Except I used the Power off of the CD changer to power my amp, and grounded to the bolt that holds the cd changer to the trunk. ran cables as you did. And isn't It cool how the trim around the center console is almost designed to have amp cable run under it?
    Mar 2008
    PA
    2001 E38
    Super delicious. Your car is coming along nicely. May I suggest, just a suggestion mind you, that next time you have that faded purple rear deck cover off, you grab a $6.99 can of black fabric spray paint (flat black) at the parts store and shoot a couple of coats on it. You will be uber amazed at how different it looks. Just make sure it's good and dry before you have blond chicks in the back seat banging their heads to the beat.
    2001 740iL BI-XENON 3" Projectors LED AE's. Clear corners. EuroDyne tails. Bilstien S&S / H&R Stage 2 springs. Widescreen/Mark4 DVD. Escort 9500ci Radar/Laser.Beyern 19" Multi's staggered.
    Jun 2005
    NorCal
    '00 528iT/ '12 Tacoma
    Just did Sub install today, thanks Mojo for great writeup, should be removing stock sub box tomorrow, all i did today was remove the stock subs...which did nothing....haha
    Mar 2008
    Los Angeles
    98 M3/4/5, 97 740iL
    Just to let you guys know, this works on possessed cars such as mine as well... a bit of modification is needed though.
    Apr 2009
    Cumming, GA (ATL area)
    e38 97 740il
    If my amp will accept wired lines in then do I need the hi-low box? Does it do anything other than convert the line to an RCA cable? Also Mojo mentions using the preamp lines is there a write-up on how to do this? Is it safer (on factory amp) / better than this way?
    1994 325ic - 5spd - Dinan Stage II - CF Intake - Exhaust - Throttle Body - Software - Suspension - M Bumper and Door Trim - Smoked Lights
    Bay Area, CA
    Not a Ferrari
    Honestly, the only reason you'd want to use the preamp lines is if you are running ALL of your speakers off an aftermarket amp. If you are only running subs, the factory subwoofer channel is just fine.
    Apr 2009
    e38 97 740il
    Thanks!
