AKA Dinan Stage 2 upgrade.
http://www.dinancars.com/store/produ...3&cat=0&page=1
Stage 2 Brake Conversion
Front and Rear
Dinan offers larger front and rear brakes for improved stopping power and reduction of rotor warpage. The front rotors are increased from the stock 324 x 30 mm to 334 x 32 mm and the rears are increased from 324 x 12mm to 328 x 20mm. The conversion retains the factory brake sensors and does not affect ABS operation. Also uses dual piston front calipers.
Everything I replaced
FRONT
01 BRAKE DISC, VENTILATED 334X32 2 34116757756 $118.30 X2
No. Description Supplement Qty From Up To Part Number Price Notes
01 CALIPER HOUSING LEFT 1 34111163317 $552.42
01 CALIPER HOUSING RIGHT 1 34111163318 $552.42
02 BRAKE CARRIER LEFT 1 34111163319 $176.33
02 BRAKE CARRIER RIGHT 1 34111163320 $176.33
03 CLIP 2 34111163416 $11.38
04 HEX BOLT M12X1,5X41 4 34111156989 $2.44
04 HEX BOLT M12X1,5X41 ZNS3 4 34116767217 $1.02
05 VENTILATION VALVE 2 34111153197 $6.14
06 DUST CAP 2 34111153198 $2.79
07 GUIDING BOLT 4 34111157041 $20.98
08 PROTECTIVE PLUG 4 34111154979 $0.93
09 BRAKE PAD WEAR SENSOR 1 09/1998 34351165729 $18.41
10 REPAIR SET BRAKE CALIPER 2 34111163316 $46.04
11 REPAIR KIT GUIDE BUSH 2 34111163415 $25.11
12 REPAIR KIT, BRAKE PADS ASBESTOS-FREE JURID 187 1 34116761246 $199.76
REAR
01 CALIPER HOUSING LEFT 1 34211163333 $245.52
01 CALIPER HOUSING RIGHT 1 34211163334 $245.52
02 BRAKE CARRIER 2 34211163335 $191.95
03 CLIP 2 34211159963 $13.62
04 COLLAR SCREW M10X26,5 4 34211164125 $2.06
04 COLLAR SCREW M10X26,5-10.9 4 34216772884
09 BRAKE PAD WEAR SENSOR 1 34351182065 $18.41
10 BRAKE DISC, VENTILATED 328X20 2 34216767062 $109.93
11 INNER HEX BOLT M8X14 2 34211161806 $1.34
12 PROTECTION PLATE LEFT 1 34211161531 $20.76
12 PROTECTION PLATE RIGHT 1 34211161532 $20.76
13 HEX BOLT WITH WASHER M6X8 4 34111156427 $0.46
13 HEX BOLT M8X11 4 34211158549 $2.27
14 REPAIR SET BRAKE CALIPER 2 34211163323 $38.50
15 REPAIR KIT GUIDE BUSH 2 34111157038 $15.23
16 REPAIR KIT, BRAKE PADS ASBESTOS-FREE JURID 508 1 34216761250 $99.88
Response feels great, stops like whoa, topped it off with Ate Super Blue and steel braided lines, some pics.
front
rear
Pic of the M5 for good measure
NICE upgrade!
Why didn't you get the stock protection brakes?
They are even bigger and thicker then Dinan
Have a technical question, don't send me a PM but post it on the board so others can benefit from it!
Keep in mind these are 20" rims
After the brake upgrade you have to have 18" wheel minimum.
Smaller rims wont fit
Before
New brackets look how thick
Stock 750 rooter and protection rooter
Are those OEM, and if so what did they come on? Did you just replace the carriers/rotors and not the whole calipers?
Yes they are OEM BMW
They came on a Alpina B12 or an E38 protection
Yep just the rooters and carriers.
Calipers can stay the same
Nice, so I guess I need to put this on my To Do List.
Because my braking suck, specially what it is raining.
if it sucks while raining, swap pads to OEM
Next week, when I swap the driver knuckle, my is bent. But I love the size of those rotors. Now that is what all BMW 7 series need.
How did you get the parts, did you take them off a crash one or you order the parts.
I like that upgrade.
I ordered then at the dealer
May I asked how much?
Rooters 34116757758 $168 348x32mm!!!
Pads 34116761246 $199
Bracket left 34 11 1 166 137
Bracket right 34 11 1 166 138
If you have a 740 you need new calipers
34111163317 $550
34111163318
Wow, $1k for a brake upgrade, that beat the Brembo price. Plus the OEM.
Put that on my to do list.
If I can find one a U PULL IT salvage yard that would be perfect.
thanks doph, it's a Thule
actually they are the same thickness, but quite a bit bigger.
334 x 32 mm 750il
348 x 32 mm Protection Package
I guess when these front rotors and pads wear out Ill be doing this upgrade, the 750 upgrade package stops well enough for me now but Im sure after 15k miles Ill be ready for another upgrade.
Thanks for the info dude.
Yes sir!
That's a great upgrade bro!
[/IMG]
Perfect info! Somebody sticky this somewhere...e38.org?
Yes my post is on e38.org
sorry to bump an old thread, but will 16" style 5s fit over the 335mm brakes? I know some 750ils came stock with 16" wheels so I was just curious.
Wow those are suprisingly larger...I'll need rear brakes in a few weeks, so I'm still throwing this idea and a BBK around as optional upgrades
750IL SOLD....I'll miss you!
regular 750 setup will work with 16's.
the protection model setup would require 18's minimum
Follow me on Instagram @SEVEN40iL
