Man !!!!!! that is one good looking car E21 Brother!!!
the motor is awesome ,keep up the good work and keep us posted
cheers alpina323c1 ( Horacio)
MOTORS IN!!!!!!
now i have to bolt up all the extra bits, run some wiring, clean up some not needed wiring, and should have it running tomorrow sometime.
got my vacuum manifold bolted on yesterday, got hose for it today
(good shot showing ports into head)
and dummied up the carbs to check clearance of dipstick and other bits.
do you have a crew working on this thing or are you doing all this yourself? your progress is ridiculous!
got the stack filters from http://bills-b-racing.com/ i found his stuff a few years back, and he sent me some fine filter mesh to play with, which i kept blowing out on the old motor. so i decided to do it right and buy some full made filters from him.
theyre real fine stainless steel mesh filter, with larger stainless mesh on either side, in a urethane(i think) moulded surround, which locks onto the lip of the trumpet.
i'm going to add some fine steel wire(probably fishing line traces) just in case they pop off on a backfire.
haha, nah. just me and dad(mostly dad, hes the mechanic).
motors running now, just gotta sort out fuel gauge, speedo calibration, overflow bottle, get lower part of guards painted tomorrow and put them on, then bolt everything else up for driving times
coz of the e30 5spd swap in, with custom tailshaft, its moved the whole motor forward a bit. luckily i went the 2002 water pump, or the fan shroud wouldnt fit. ive had to cut the sheilding bits off the fan as it is, but its got a decent amount of clearance to the fan itself now. will see how it goes though!!
edit: video [ame]http://www.youtube.com/watch?v=I1VIBeJVekU[/ame]
Just found this thread and read the whole thing instead of working on my paper due tomorrow :p
VERY NICE WORK!
Another drive video on the same road as you originally posted on. Sounds very responsive. Cmon man.. Begging.
"The most important thing is balance." - KT
Given you assembled it yourself/with dads help, you'll probably find that your break in period won't be too long. Might be a tad tight for 500-1000 kays or so if you tolerance it for street use (race motors have tolerances which are heaps loose) but it should be fine after the first oil change, perhaps even consider giving the oil pan a clean.
well, this weekend was dedicated to getting my ecu running, which i did!!
first things first, i scraped my bumper for the first time yesterday, forgot and reversed out a parking lot wrong, and it scraped backwards, and took a couple chunks out. no biggie
wired the edis module up under glovebox, only place i could find that wasnt in the way, or in enginebay
wired the ecu up and mounted it beside my cheap ass "headunit"
ok, so the edis kit that i got for the ecu came with coil on plug, but they wont fit with the current brake system where it is(another reason on the list to piss it off :p)
so, knowing i can use commodore coilpacks(the edis system is wasted spark, like vn-vs v6 commodores), i got to work making a pair of coils work.
grabbed a module and cut the end coil area off, ripped the alu plate off the bottom, and gutted it.
i worked out what pins id need(the ones that goto each coil) and removed the rest. soldered up my wires, and globbed a heap of hotglue on it to stop anything coming astray
i drilled some holes, welded some nuts under the wheel arch and mounted the coils to the car, came out pretty good. just need to get some leads made up to suit(using an old set of commodore leads for now, 3 are good, ones mega long)
final setup. will run it as is for a week, and get a spare dizzy housing modified to remove the dizzy hole. was hoping to remove the oil sensor hole aswell, but not enough money to get the remote filter stuff sorted before taking dizzy off. oh well, a bung will do fine.
can spot the fan mount changes i did yesterday too, trialing it for now, but its raised low speed temps, and hasnt really changed higher speed temps. might go back to old shroud and a cooler thermostat.
uploading some vids, will take a while though.
idling and a few revs on the megajolt ecu(moreso to show the lack of leads on the dizzy :p)
[ame]http://www.youtube.com/watch?v=uzjhWR_KOac[/ame]
and a test drive. starts off a bit boring though. no high revs, still running in motor.
[ame]http://www.youtube.com/watch?v=P1rZ2iu8c_U[/ame]
Awesome. Great sound. Makes me want to go for a drive.
ok, monday just gone, went to start her in the morning and nothing, ended up late for work(had to get a lift). got home, messed around with it, turns out i killed my circuit breaker(most likely that night, as it was working in the morning), and the crank sensor(note: dont go grinding any plastic off around the end of the sensor, not enough material, hits coil wires )
so i ordered another sensor(from an aussie car, ford, slightly diff mounting points), and a bigger battery, small one just wasnt cutting it with new ignition system, and bypassed circuit breaker(for now, ordering new one monday)). swapped the wires on the sensor and she fired up without hesitation today.
new battery(moved it to above axle, instead of behind it this time). just gotta clean up the area where the old box used to be. gotta get some cable protective stuff, and maybe reroute the cable somewhere else
went for a drive upto bluerock damn again, and took a few pics
do you know what kind of mirrors those are? do they mount to the stock location? i like those
picked up a replacement muffler today(its temporary until i make a new full exhaust to suit new motor), coz the old one finally decided to shat itself on the way to work, its 90% broken around the back of it, and the mount that the last person put on was on the tailpipe, so it has broken from weight. got a couple new mounts to mount it properly tomorrow.
bye by dizzy, got the spare housing plugged and welded, so will paint that and put it on tomorrow, and that nice big chunk of alloy sitting beside it, well... thats for something else
i like those side mirrors waaaaay better than the stock, giant, plastic, monstrosities. might have to follow your lead...
higires if you want it http://dl.dropbox.com/u/2301805/bmw/Imgp0652.jpg
Wow, I really love this car, from the motor work to the wheels/suspension drop.
Nicely done.
hakhawk - open that bad boy up and post more video.
Tbd
