Bavarian Soundwerks
Results 1 to 2 of 2
Thread: Whining noise in sound system...
    Jun 2003
    Aurora, CO
    1998 M3
    Does anyone know how to fix the whining noise induced in the sound system as one revs up the engine?
    thanks
    Dec 2002
    Los Angeles
    90 325i
    The only "quick fix" for that problem is a noise filter...but the proper way to do it is to find out where the noise is being induced and fix that. For example, how did you run the RCA wires from the radio to your amp, and what kind did you use, how good is your ground, etc. Also, some amps are more prone to "noise" than others, so you have to be more careful when running wires.
    This is my signature
