i did a similiar mod but i just use the "foglight" as a regular light so now mines lights up in an l form
This is the easiest and the cheapest mod I ever did. hey dummies! the German manufacturers are v. clever. That blank hole for the fog light has a very thin web around the circumference and about a quarter of it is already cut off. All you need to do is punch this out with a screw driver, you don't even need a hammer because its so delicate. the rest you pull out with the pliers in your tool kit. No mess atall, it comes out clean around the edges.It is meant to be punched out easily.
Then you uncover the plastic melt behind the connecting pins just enough to see that the back of the connecting pins is hollow. Just push the ends of the connecting wire tight in the hollow pins. You dont even have to solder it. THATS ALL & REASSEMBLE IT. SEE ATTACHED PICTURES BELOW.
wow, great! i'll get this done sooner than later!
I got some pictures of how I did it without soldering the wire connection to the rails. See if it's of any help. "CREDIT STILL GOES TO defaz"
Defaz, I saw this post just a few days ago and completed the same project. The results are terrific. the only trouble I really had was securing the new bulb sockets into the plastic housing. The bayonet type clips don't line up and grab correctly. I just put two small screws into each socket, right on the edge, which holds them down nicely. Thanks!
"If she spills anything, she MUST clean it up. After she is done, I tell her to "Tuck and roll" at 65mph." -Gumbi4u
Paul // Oakland, CA // Registry Link // My Ugly Mug
HERE YOU ARE,A CLOSE UP WITH SOME EXPLANATION. YOU MAY HAVE TO ENLARGE THE PICTURE TO BE ABLE TO READ.CONNECTING WIRE PAINTED RED IN YELLOW CIRCLE, RAILS PAINTED BLUE. THE BLACK IN THE FOREGROUND OF THE YELLOW CICLE IS THE PLASTIC MELT OF ALL CONNECTING RAILS. FIRST PICTURE AS SEEN FROM TOP, SECOND PICTURE AS SEEN FROM THE BOTTOM. HOPE THIS HELPS.
Excellent idea and post, just did this to mine and it looks great and its actually practical lol
Euro e39s come with a switch for the rear fog light. Since we don't typically have them in the US, to most it appears like a brake light, hence people behind you will think you are braking if you turn on your rear foglights. Here is the retrofit:
http://www.jadeturtle.com/bmw/
+1 I'd like to know the same. Usually the topic just dies with no confirmed answers. Speculation, yes. Proof, not so much.
Confirmed it will work with the Euro celis tails.
I had a brake light bulb go out yesterday, so I pulled the tail light for a little investigation. It looks very similar to the pre celis with the giant circut board look. It is even easier in that the bulb is already there and connected(at least in my Euro tails they were), so all you have to do is span the two metal contacts, and your done. I just did a mock up with some electrical tape and tested it, but will solder in a wire this weekend.
lunker325,
In case you didn't notice, see post #38 for a very clean, simple, solderless method.
Here are the pics of the completed Euro celis tails. I decided to screw the wire in, couldn't get the solder to stick. I am very happy with the results, no way someone is missing me now when I hit the brakes!
Before, lights off:
Before, lights on:
Jumper wire in place:
After, lights off:
After, lights on:
Darkness!
Another happy convert here I was bored yesterday. Now, I just need to wok on my my soldering skills (or lack therof!).
German Engineering, Astounding Ingenuity, Over 9 Decades of Conceptual Continuity
is it this easy to make this a legitimate fog light instead of a brake light?
http://www.bmwtips.com/tipsntricks/R...g%20Lights.htm
IMHO not as easy as it is to make it an extra brake light.
thanks for the link!
