I think you will not be able to notice unless your accelerator is really off such as in my case. If your accelerator is ok, then recalibrating it will yeild no results. Kinda like getting a car aligned that does not need alignment.
As for E-Gas e39's, I believe its 99+ for 540s
'00 540iA Sport w/235k+ Original TCG's, Vanos and transmission.*Trans failure at 244k+...FS Now
If it did do something, it is entirely unlikely it would have effect other than at WOT, and even then you would probably see minimal gains unless your pedal was way out of whack. More likely it would give you a different feel to the pedal, but no HP gain (just like Sport mode on the M5).
d-
Really, I didn't know 1999 and up had drive by wire? How can you know for sure? I have a 99 528, and would like to know if it is dbw.. i know there is a throttle cable.
I have a 1997 528i and a fly-by-wire.The acutaotor is behind the driver's side headlight. So, no, not just 99+ have the fly-by-wire.
**'11 BMW 535i: black sapphire w/cinnamon leather, Night Vision, Active Cruise, Premium 2, Sport Pkg, Driver Assistance Pkg, Dynamic Handling, PDC w/Parking Assistant, 4-Zone Climate, Cooled Seats, Rear Cam, Prem HiFi, Soft Close Doors
**'07 E550: iridium silver, P2, pwr trunk, Sport Pkg, VC, wood steering, 4Matic
**'05 C230 Kompressor: silver metallic.....Deceased.
**'98 C230: black onyx.....Sold.
**'03 BMW 525i: sterling grey.....Sold.
**'07 BMW 530xi: grey metallic.....Sold.
**'02 MB E430: dark turquoise
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car.
Horsepower is how fast you hit the wall, torque is how far you take the wall with you.
“Who really can face the future? All you can do is project from the past, even when the past shows that such projections are often wrong. And who really can forget the past? What else is there to know?”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance
Yea, that's what I was saying----this anti-pinch feature only works if you use "auto-close"...if you hold the button, it will just keep going like on a car with regular, NON one-touch windows
Darn, something else BMW needs to work on...Mercedes has offered this since 1998 on C-class, and at least since 2000 on ALL models, on everything from 4-cyl to bi-turbo V-12!
Ditto deathwarden5...this information will be in either your NAV owners manual or your Business MID owners manual.
If you don't have either...you can download these manuals (in PDF format) from www.e38.org/e39...look at the bottom of the left column.
Or (depending on if you have Nav or the MID) look for and press "LIMIT" button, then press your SET button or whatever button you need to use to enter info (again, not knowing what you have makes it difficult to give you instructions).
On the cars with MID...select the OBC features by pressing the BC button and the display should show the LIMIT button seen in pic below...press the LIMIT button...then to begin to enter data, press the SET button. The display changes to a set of numbers...select the speed limit that you want, then press the SET button again. A "limit" icon should appear somewhere on the display that tells you that the warning is set....press the SET button again, and it turns the warning off...but you the speed you selected stays in "memory" unless you select "CLR"...or press the SET button again until till you see blank spaces. When the "limit" icon is displayed...a warning will then be heard when you exceed the speed limit that you entered (the NAV screen works basically the same way):
You cant lock the drivers side door manually if the door is open.
Just found that out today.
KEVIN
BMW CCA # 416146
Current 2001 525i-5 / 234,000 Miles
///M Weighted Shift knob.
CD43 with AUX retrofit + Bluebus
Auto Dimming Mirror upgrade
H&R Sport / Koni STR.T
OEM Xenon HID Retrofit
The Ex- 2000 540i-6 / 82,xxx miles to 186,xxx miles
CDV Free, 545i Shifter and ///M Weighted Shift knob.
Member of DSC Module Failure Club $$
can someone post how to program the key to close all windows/sunroof when keeping the center-lock button depressed on the key?
all open when unlock is kept depressed
2003 530i...diamond key
and if it is dealer only, how much $$ is fair
it can be done here, there was a guy over on M5 board that used to do it for a fee
