Bavarian Soundwerks
Page 73 of 79 FirstFirst ... 23486364656667686970717273747576777879 LastLast
Results 1,801 to 1,825 of 1959
Thread: Feeler: Open Source OBC Firmware
  1. #1801
    Feb 2004
    Toronto
    S54/E36 ; E30 ; Saab
    what happen to the developers forum?
    #E36-S54 #CSLWannabe
  2. #1802
    Mar 2006
    NJ
    1998 328is, 2006 330ci ZHP
    Developer has clearly moved on to other things and the forum was hacked -- I knew this would happen eventually after I saw tons of comment spam and none of it was removed.
    I would be willing to run the numbers on a fully assembled reproduction of the design if I could find a source for new harness connectors. I recall a source and part numbers were mentioned somewhere in this thread some time ago but the search is worthless and I haven't found the information I need. If anyone can forward that to me here or PM, I'll look into it.
  3. #1803
    Nov 2012
    Lawrenceville, Ga
    1997 Estoril M3
    Please do. Ive really been wanting to do this but im not a coder and it would be great if we could get a base platform or a working unit to start with. I know I could get a good bit of interest in buying more units. Definitely would be a good market for it. Thanks.
    Sent from my LG-M153 using Tapatalk
  4. #1804
    Mar 2006
    NJ
    Quote Originally Posted by EstorilB View Post
    There's a market, for sure. The question is how big it is. It turns out I specialize in prototyping and short runs so it might be a good fit, but I won't front the project. I'll need to do a kick or indy, or perhaps a simple pre-order. But before that happens I'll need to find a reliable source for those harness connectors. Again, if anyone can recall the page on which they were mentioned, let me know here or PM me.
  5. #1805
    Vancouver, B.C., Canada
    '97 M3
    I think a group buy would do it. Quite a few people have wanted on since he stopped selling them.
  6. #1806
    Mar 2012
    Renton, Wa
    98 m3
    Quote Originally Posted by dwvcfii View Post
    There were a few issues with the design that need to be reconciled. Some of us were working on a updated unit but we are all too busy to make consistent progress and it has mostly died off...
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  7. #1807
    Mar 2006
    NJ
    Thanks for the links to the connectors. Good news is they are still available, though with a 3 month lead time.
    The MC33660 is just a kbus transceiver. A 2 minute search revealed at least two possible substitutions from reputable manufacturers.
    I spent some time reviewing the last few years of this thread and I can't seem to find any references to a kbus driver failure. If anyone has their eyes on the associated message(s), let me know.
  8. #1808
    Mar 2006
    NJ
    Thanks for the tip. I found Raddee's posts, and although they reveal some kind of issue when attempting to talk with the DME over the d-bus they are not otherwise helpful in a technical sense. Some further troubleshooting would be in order.
  9. #1809
    The Netherlands
    DE-spec E36 328i/M3 cab
    I know a coder who did extensive testing. There is a design flaw in the chip that is needed to read out the DME. It keeps buring through.
    The OpenOBC designer was informed about tihs a long time ago, but he's never gotten any response.
    Which is a shame as communication with the DME would come in very handy.
    1998 BMW M3 3.2 Cabrio • Alpinweiß III on Schwarz • German spec • 1 of 12
    IG:
  10. #1810
    Mar 2006
    NJ
    If memory serves there were two problems with DME support. First, you had to eliminate the bus terminators in the 20 pin connector and second, the bandwidth of the d-bus was extremely limited and/or the DME took forever and a day to respond to each query, limiting the usefulness of the connection.
    I suppose the good news is the bus transceiver is one of the parts that is no longer available, so it would need to be swapped out for a new part. Assuming the damage issue is indeed related to a bug in the transceiver silicon (highly unlikely, but certainly possible) that problem should go away with the redesign. Of course, if the real problem is noise / voltage spikes on the bus (wouldn't surprise me in an automotive environment) there are ways to address that at reasonable cost.
  11. #1811
    Apr 2015
    Netherlands
    2000 E46 328i
    The weird thing is that the MC33660 is designed to be resilient against spikes, noise etc and was built to automotive specs. The only mistake I found at the time was that the supply voltage to the chip was too low on the OBC side (3.3V instead of 5V). We theorized that this may cause things like overcurrent protection to not work properly and cause the chip to fry.
    Of course if you swap the part out completely it's not a problem anymore.
  12. #1812
    Mar 2006
    NJ
    I don't see a problem with supplying the MC33660 Vdd with 3.3V. Valid range per the datasheet is -0.3 to 7V. Vbb is also quite tolerant of overvoltage by design. So I don't see an immediate issue with the device power supplies (though in full disclosure I have not done a full audit of the design).
  13. #1813
    Mar 2006
    NJ
    Some time has opened up in my company's engineering schedule toward the end of the year and I'm trying to figure out whether I should bother to continue this project in some way. As I see it there are two options:
    1) Simply re-spin the existing board and replace the obsolete components. The would only be sold as a fully assembled product that the user installs in their existing OBC at their own risk. This would ship with a tweaked version of the original developer's firmware with identical functionality. The software would be maintained by the community. Obviously this is the least cost option.
    2) Provide a complete replacement for the OBC involving a new case and a high resolution, color, sunlight readable display with capacitive touchscreen. This would eliminate any dependency on the original units and open the door to lots of innovative control and display options that a single line text display simply can't provide. The downside to this would be cost. The display alone will cost more than all of the other components combined.
    Something tells me the market is just too small to make this worth my time but I'll leave that up to you. If you're interested in either option, let's talk.
  14. #1814
    Nov 2012
    Lawrenceville, Ga
    1997 Estoril M3
    Im interested. I think if you made a complete ready to go unit this would work if you put it to the right markets.
  15. #1815
    busterhax's Avatar
    busterhax is offline Y̝͎̘̍́ͣ̉͑̿̆Ō͎̼̺̬̒ͯ̃̇͗̂ U͈̖
    Jun 2006
    NYC
    e36
    This is the market.
  16. #1816
    '97 M3
    At least make the assembled circuit boards.
  17. #1817
    Nov 2012
    Lawrenceville, Ga
    1997 Estoril M3
    No. Theres way more.FB unfortunately has taken over BF but yes there is way more than this thread for a market.
  18. #1818
    busterhax's Avatar
    Jun 2006
    NYC
    e36
    When he said “market” that’s what he meant. Not bf.c. He meant the e36 market in general. There isn’t much demand for a product like this.
  19. #1819
    Nov 2012
    Lawrenceville, Ga
    1997 Estoril M3
    I highly doubt that. I believe if the price is right in my area alone I could sell the hell out of this. How much exposure has this even had?
  20. #1820
    busterhax's Avatar
    Jun 2006
    NYC
    e36
    Just being realistic. E36 owners are cheap these days. The ones that aren’t cheap, want original parts.
  21. #1821
    Mar 2006
    NJ
    Practically speaking, the E36 market is strong given its size (i.e. this remains a popular enthusiast vehicle) but it is by definition a declining market. Within that market, the set of people who own an E36 AND have the ability to solder or otherwise disassemble their OBC is exceedingly small. The set of people who own an E36 AND would spend a few hundred bucks on a flat panel replacement for the OBC to get lots of cool information delivered via a modern touch interface and a bluetooth interface that talks to a phone app is probably an order of magnitude larger (at least). Which explains why I suggested option 2. It would cost more but more people would buy it by virtue of the larger market.
    I suppose I could do both options, using option #1 to springboard option #2 but I'd have to pick a display and effectively build option #2 first to ensure I could use the same PCB for both options. I might be willing to front the prototype costs but there is no way I'll be on the hook for a production run as I said earlier. This would have to be via a group buy or Indie/Kick.
  22. #1822
    '97 M3
    I love my openOBC. The extra functions and gauges are awesome especially for a boosted car.
  23. #1823
    Nov 2012
    Lawrenceville, Ga
    1997 Estoril M3
    Yes this. A complete unit and sold in a group buy. I think it would be a safe bet and worthy try to get a true feeler for the e36 market. I could certainly spread it around and the boosted market would certainly love this as well. I know my boosted build will be done in the next month and will be bringing more builds to come for my customers and I'd love to have this as an option to offer alongside it. What kind of price are we talking about for a finished unit obc and all? Ballpark figure?
  24. #1824
    Mar 2006
    NJ
    I'm not in a position to talk pricing yet. I will have to do a full design audit and come up with a BOM. I'll also need to determine the quantity I'll ultimately build, as price is strictly dependent on production quantity. If I do a run of 100 it should be affordable by most enthusiasts (though it will not be cheap in any case). If I try to build only 10 they won't be economically viable. It's as simple as that. Which, of course, brings me back to my original request for market interest.
  25. #1825
    North Carolina
    1988 325 Super ETA
    Personally if it were up to me, I would prefer option 1, with a better/simpler software interface on the back end to program it with.
    Option 2 worries me a bit because of added development time, and other possible aesthetic issues or fitment issues etc, there is a possibility of it being really nice, and a possibility of something not being quite right. I would be afraid of the project not achieveing lift off since I haven't heard you express much confidence in the market thus far.
