Bavarian Soundwerks
Page 63 of 79 FirstFirst ... 1338535455565758596061626364656667686970717273 ... LastLast
Results 1,551 to 1,575 of 1959
Thread: Feeler: Open Source OBC Firmware
  1. #1551
    Dec 2011
    Holland, bish!
    Euro e36 M3 3.2 cabrio
    Quote Originally Posted by pheno View Post
    Question about OEM Tire pressure sensor. Is there a live data screen for that in INPA or DIS ? Also is it E36 M3 only feature or can it be integrated to every E36 ? I'm currently trying to get oil temp display working for MSS50 ecu. I don't even have E36 but daandaman will test it :-)
    This is not a function that was offered on the e36, but it was available under the name 'RDC' (not DWS, that just shows if one wheel has a different circumference by looking at ABS sensor data).
    Here is a screenshot I could find of INPA
    I do not know what model BMW the INPA was connected to.
    The E38 (like the 740i) had it; and quite some other cars as well, like the e46 and e39. The part number of the receiver is 6752127.9 but it doesnt show up on realoem partnumber search...
    It should also send temperature, maybe even battery voltage per sensor
  2. #1552
    Dec 2011
    Holland, bish!
    Ok, so I would say it's possible to get that data into OpenOBC since it works via diagnostic bus but of course it will take some time as it will require reverse engineering of packets and some logging and testing.
    Yeah I thought so as well!
    Here is some more info with part numbers on the system as it lives in the e46
    http://forum.e46fanatics.com/showthread.php?t=966153
  3. #1553
    The Netherlands
    DE-spec E36 328i/M3 cab
    Quote Originally Posted by daandaman View Post
    ...The part number of the receiver is 6752127.9 but it doesnt show up on realoem partnumber search.....
    RealOEM....nuff said.
    It even finds the whole P/N by just using 6752127, but no result.
    On BMWfans.info, no problem. Part is found.
    http://bmwfans.info/parts-catalog/36146752127
    p.s. that inpa screenhot is from http://www.meeknet.co.uk/7sf/..., so that's the UK guy's E38.
    And there were two systems, RDC and RDW (Reifen Druck Control/Warning)
    http://www.meeknet.co.uk/e38/BMW_RDC_Run-Flat.pdf
    IG:
  4. #1554
    Dec 2011
    Holland, bish!
    In the end, if we won't manage to get the OEM module working, there is also the option to use aftermarket systems where we can tap off the datastream. I already found some projects/people that know much about that, and can tell us exactly how data is managed.
    But I have faith in the combination [pheno&openobc&inpa&oem rdc receiver]
    Quote Originally Posted by MParallel View Post
    Thats what I said, we need RDC not DWS (or RDW)
  5. #1555
    The Netherlands
    Well never heard of "DWS" so that's why I posted it.
    IG:
  6. #1556
    Jun 2003
    NY
    95 m3
    Bump for keeping this relevant
    1995 OBD I Cosmos Black M3 - RIP: gone but not forgotten
  7. #1557
    North Carolina
    1988 325 Super ETA
    Ok guys, need some help here. Finally got around to checking my open obc out. I was hoping to maybe just turn it on and set the time. I have a memory card in so I gather it has written its default config file to it as it doesn't show that message anymore. So basically what happens is I plug my power adapter in, shows the open obc message and then turns off. Is there anything I can do with it out of the car? I haven't found much in the way of tutorials, they are a little vague. But I am eager to learn and start experimenting!
  8. #1558
    Vancouver, B.C., Canada
    '97 M3
    If you look at the board there is a small switch that says 'ON' and 'Auto' (I think). Switch it to 'ON' while using it out of the car.
    Sent from my GTX3582R
  9. #1559
    North Carolina
    1988 325 Super ETA
    Quote Originally Posted by chikinhed View Post
    You the man! Okay something I've always wanted to do. on my '95 the OBC could be wither 12 or 24 hour time but on the one I have now in my '96 it is only 24 hour time too, same on this new OBC. Surely I can change this.
  10. #1560
    The Netherlands
    On an OBC, press an hold the time button untill it says "set time" or input time, don't recall. Then with the KM/MLS button you can switch between 12/24h clock.
    IG:
  11. #1561
    '97 M3
    That procedure doesn't work on my openobc.
  12. #1562
    North Carolina
    1988 325 Super ETA
    Doesn't work on mine either. The g force thing seems to be a little wonky, is there a way to zero it out, like calibrate to be 0 at a certain position? So I use windows, what I need to do to start playing around with some files.
  13. #1563
    '97 M3
    It's best you try to follow the wiki.
  14. #1564
    North Carolina
    1988 325 Super ETA
    Well the wiki isn't very clear and I don't see anything about resetting the g force reader.
    Also do none of these work anymore?
    http://www.bimmerinfo.com/E36_OBC_tricks.htm
  15. #1565
    Dec 2011
    Holland, bish!
    So everyone forgot about my manual?
  16. #1566
    The Netherlands
    Oh like so. Well since I'm from Europe, I need a 24h clock. What does the open OBC have?
    IG:
  17. #1567
    Mar 2012
    Renton, Wa
    98 m3
    Oobc has everything.
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  18. #1568
    North Carolina
    1988 325 Super ETA
    Quote Originally Posted by vollosso View Post
    Except a 12hour clock, and also none of the standard OBC tests seem to work. Also what manual?
  19. #1569
    Dec 2011
    Holland, bish!
    Its for idiots. Few pages back. Put some effort
  20. #1570
    North Carolina
    1988 325 Super ETA
    Gee... thank you. I'm so glad there are people like you to help idiots like me.
  21. #1571
    Dec 2011
    Holland, bish!
    It took me much effort, more than you did to read up.
    And its literally written for idiots. See 4 yoursepf
  22. #1572
    North Carolina
    1988 325 Super ETA
    I appreciate your efforts. Do you think maybe you could tell me what page it is on? I've looked at several pages now and haven't found anything.
  23. #1573
    Dec 2011
    Holland, bish!
    On mobile taparalk 3
  24. #1574
    North Carolina
    1988 325 Super ETA
    Sorry what does that mean?
  25. #1575
    Dec 2011
    Holland, bish!
    Hello everybody,
    Here is my manual for the OpenOBC, have a good read and good luck with your first babysteps into getting the most out of your super-awesome-όber-OpenOBC
    OpenOBC teaser picture, courtesy by Benemorius
    This posst
