Looks like it works! Please update us with progress. You've had a harder uphill battle doing a full retrofit, more than a plug-n-play swap. Post a video showing the working features too.
1995 OBD I Cosmos Black M3 - RIP: gone but not forgotten
did a quick video, i really need to remove the check module stuff from the coding, since i wont be installing it, eventual additions will be boost and afr display via the extra inputs, and whatever else i think will be useful to show.
https://www.youtube.com/watch?v=MJl0nxXzfSI
Since I am not a programmer I gave the Open OBC to a friend that is so that he can do some mods to it. I'll post it when he is done.
Sent from my GTX3582R
The stock oil pressure sensor is a pressure switch whereas the one that I have ordered is a pressure switch and sensor combo. It has separate terminals for each function.
Oh like so. Good to hear.
I would be interested in in an open OBC. Will it work on my e23 1984 733i?
Current Cars:
1995 BMW 325i
2013 BMW X3
2017 Infiniti QX30
Past Cars:
1997 BMW M3
2011 Chevrolet Avalanche LTZ
2010 GMC Terrain
1998 BMW 328is
2006 BMW 325i
2007 Saab 9-3ss AERO
2004 Saab 9-3ss Linear
2003 PT Cruiser
2001 Volvo S40
1990 Honda Accord EX-R
Just a wild suggestion and not sure if I have posted this before.
It would be awesome of all the extra special cool functions could be assigned to the "secret menu" the OBC has. This now goes to Test Nr. 21 (reset).
It would be cool to have the extra options under menu #22 - #99
That way the OBC could remain totally stock for the normal button behavior and no need to double, triple quadruple press the buttons to reach new functions.
Having to remember specific numbers for every function is really a horrible user interface. The way it is heading now is a very good one.
Currently the writer of the datalog software Test-O is expanding functionality to monitor other values, starting with engine oil temperature of the S50B32 trough its MSS50
Obviously we are very happy with his help.
Well I'm sure there won't be 23-99 features or at least not that you use.
If only it can display oil temp and pressure in one screen, that alone will make me buy one. Everything else is nice/bonus.
(And displaying ibus messages would be great as well)
Hello everybody,
Here is my manual for the OpenOBC, have a good read and good luck with your first babysteps into getting the most out of your super-awesome-όber-OpenOBC
OpenOBC teaser picture, courtesy by Benemorius
Very cool stuff, thanks for taking the time to write this up. May be a project in the future I'd like to try and tackle, who knows.
Nice! That's awesome. Now the question for us metrics...does the km/mls button switch it to Bar?
Who talks about oil pressure in Bar!?!
Just bugging'.
For those that are going to order a VDO oil pressure sender, don't order from eGauges.com. I ordered from them and never received the sender and he is unwilling to fix the issue. I let it go too long to file a Paypal dispute. Be forewarned.
Should not be needed as Daan is reading straight from the MSS50. Or how is this simulated?
1989 535i - sold
1999 M3 Tiag/Dove - sold
Thanks for the heads up
This is not correct, there is no oil pressure sensor installed in our cars, just an oil pressure switch. This means we need to install one that has both functions. Benemorius found out which VDO sensor is suitable for that, see his site (its under the blog).
Because of this, the oil pressure cannot be fetched from the DME. Oil temperature however can, without any sensors, as the oil level sensor in the sump doubles as a temperature sensor. This information is available over digital line communication, just like INPA/DIS can access. Other e36's should probably have this functionality as well.
Thanks!
Oil pressure sender p/n is VDO 360-007.
Daan, wtf...
You know it's the 18 button OBC. (Or to be perfectly correct: 18 button MID)The OpenOBC can only be installed in the 16 button BMW e36 OBC ...
