Bavarian Soundwerks
Page 58 of 79 FirstFirst ... 833484950515253545556575859606162636465666768 ... LastLast
Results 1,426 to 1,450 of 1959
Thread: Feeler: Open Source OBC Firmware
  1. #1426
    Mar 2012
    Renton, Wa
    98 m3
    Simple changes can be done with very basic understanding. Even stuff as far as altering button configurations could be accomplished by an individual with some interest and no real experience.
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  2. #1427
    Vancouver, B.C., Canada
    '97 M3
    Quote Originally Posted by vollosso View Post
    Have you done it? Is there a 'Open source obc for dummies' somewhere?
    Sent from my GTX3582R
  3. #1428
    US
    '94 325i / s13
    Quote Originally Posted by MParallel View Post
    Quote Originally Posted by bolloksitsmeee View Post
    Any chance of these getting sent overseas to the UK?
    Why not? The member who posted the pics of his install is from the UK as well. And Dutchman Daandaman also has one.
    Yep, less than half of them have stayed in the states actually.
    Quote Originally Posted by chikinhed View Post
    So, how difficult will it be for someone with no programming experience to go in and change parameters to make the fuel consumption read right with bigger injectors, change what it says on start up and add a temperature sensor and have it read correctly?
    What you have done is amazing but will I be stuck with something I can't do anything with without four years of computer programming under my belt?
    Prior experience isn't necessary. I think the best way to learn programming anyway is to dive in to an existing code base for something that interests you and learn as you go. I don't know anyone who didn't learn this way. Generally getting the code to work is the easy part. The hard part is feeling good enough about your code to post it on the internet for all to see.
    You absolutely should take a peek at the code on github to see how straightforward it is to make your changes. The fact that the code is fairly well organized has the unfortunate side effect of increasing the number of files and making it look much bigger than it really is, so I'll see if I can point you at the right spots in the right files.
    The fuel consumption parameters can be manipulated here. It looks like all that's required is to change the 0.2449 constant. Extra points for making it configurable via the configuration file like I should have done in the first place. A good example of where I took something that wasn't configurable and made it configurable is the changes made to OpenOBC.cpp in this commit.
    The startup text has been made configurable, but if you want more configurability than was made available, you can make it do anything you like right here.
    A temperature sensor will read just like the external temperature does here. I forget how to use the equation in line 71 but I believe I recall getting it straight off of wikipedia. All you'd need to do to add an oil temperature sensor is make another state (state == TempOil) which reads from obc.analogIn1 instead of obc.temperature and adjust the equation for your sensor.
    It's definitely possible to do this stuff without being a programmer or a mathematician. I know because I wrote the whole code base from scratch in a few weeks time and I am neither. In fact writing the openobc code base is how I learned C++.
    Next time I'm able to take a week or two off to work on the firmware, I'd really like to cover my workflow in a series of blog posts to serve as both introductory and advanced openobc firmware hacking tutorials. Unfortunately I seldom have enough time to make things go exactly the way I want them to so I can only guess whether this will happen. The closest thing to a tutorial right now might be one of probably many hundreds of arduino or mbed programming for dummies articles that must exist.
  4. #1429
    Yorba Linda, CA
    1999 TiAg M3, 2003 E46M3
    And once again I've been not getting email updates on this thread. Everytime I come in here I am amazed at all the progress being made.
    Kudos to everyone who contributed to this project -- it's great to see this going somewhere!
    Regarding the E46 applicability, I can speak to that now that I actually own an E46. I really do miss all the "extra" functions the E36 OBC provided from the factory.
    It would be great to retrofit something more useful into the amazing platform the E46 is. There's so much data flowing inside that car, it's really incredible.
    I'm thinking it would be great to modify the E46 cluster and remove the "door minder" indicators and replace that with a dot-matrix LCD of some sort that can act as sort of an "OpenOBC Inside".
    1999 ///M3 TiAg | Heated Power Vaders | DDM Projector36 5000K 55W HIDs | DDM 3000K 35W HID Fogs
    DDM Smoked Corners | DDM Weighted Shift Knob | K&N CAI | Mishimoto AL Rad w/Zionsville AL Shroud
    Stewart HiPo Water Pump | Samco Hose Kit | 16" SPAL Puller Fan | Viper 5701LE Security
    E36 OBC is now open! Join the effort: BF.C Thread | openOBC Wiki
  5. #1430
    Jan 2003
    USA
    BMW M3
    2014 bump....hope anyone who installed this can post pictures showing all the functions and how do they perform, any issues.
    Please see few pictures showing factory OBC hidden functions, this is in addition to regular functions: ext temp, consum, dist, limit, code, speed, check, range, timer and warning messages.
    There are over 20 test hidden functions, I'm showing some of the pictures only.
  6. #1431
    Oct 2007
    sunny QLD, australia
    e21 320i, wide s50 e36
    looking good. im wondering if we can remove some of the oem functions from the menus, and possibly reuse original wire points for new sensors?
    ie. i dont have an 18 button obc yet, and i dont care for things such as the oil level, coolant level and such. can i remove these, and have a screen displaying say oil pressure(from an aftermarket sensor with known values), boost and AFR?
    would i be crazy to think we could repurpose the clock to an afr gauge?
  7. #1432
    UK
    1998 328 convertible
  8. #1433
    Oct 2007
    Quote Originally Posted by Joylove View Post
    It's been a couple of years now, instead of fiddling with the specifications, wouldn't it be better to roll out something to punters?
    look back a few pages, there is a board being made and sold.
  9. #1434
    UK
  10. #1435
    The Netherlands
    DE-spec E36 328i/M3 cab
    Any news? I even forgot about this topic for a while.
    1998 BMW M3 3.2 Cabrio • Alpinweiß III on Schwarz • German spec • 1 of 12
    IG:
  11. #1436
    Dec 2011
    Holland, bish!
    Euro e36 M3 3.2 cabrio
    Yeah well... my selfstudies on C+ are not going as swift as I'd like. That is the progress on my end...
  12. #1437
    Mar 2012
    Renton, Wa
    98 m3
    Quote Originally Posted by daandaman View Post
    Its hard without an in person mentor.. what can we help you with, I'm sure someone here can guide you to faster learning.
    1989 535i - sold
  13. #1438
    Dec 2011
    Holland, bish!
    Well there is a nearly endless supply of websites that try to teach you the language... I'd be happy to get pointed to one that is really good at it.
    Most of them sort of jump into the deep (here we see an example of a program. Now it is up to you to disect it with these pieces of information, and begin to understand it that way).
    Which is actually fine, but so very time consuming to learn from!! (and time to spend on this is limited. I'd rather be working on my engine build for example)
    Oh and it is not like I am incapable of learning stuff like this! Programming PLC's for example is something I did years ago.
  14. #1439
    The Netherlands
    Pfff you slacker you!
    IG:
  15. #1440
    Mar 2008
    UK
    M3 Evo Vert
    Daan - me too buddy - in the same boat as you - progress = zero!
    Vollosso - it is tough without a mentor. I so do want to get stuck into this because the best way is to have a go and learn by your own mistakes. What is holding me back is that there is no basic "how to" to flash new firmware and how to restore to an earlier working version once I inevitably mess it up. Once I know how to get back to where I was then I have no problem experimenting. I just don't want to be stuck with a non-working OBC,
    Hopefully, Benemorius will have some time sometime soon to steer us in the right directtion.
  16. #1441
    May 2012
    Wandlitz / GERMANY
    BMW E36 Sedan
    I actually didn't assembled my boards now, tooo busy with a lot of other stuff, but already bought a second OBC to try
    When the first board is assembled i will try to start programming them, otherwise i can ask my buddy over in Bochum for help, as i told you already @daandaman
    The biggest problem for him was that he didn't understand what in we're talking about in particular.
    He's driving a Compact, so there is no use for the open OBC and he didn't followed up this here.
  17. #1442
    Mar 2008
    UK
    M3 Evo Vert
    Rokiii
    I think that is the problem - if you designed this, then you know exactly what is going on. Much harder to pick up if you don't!
  18. #1443
    Dec 2011
    Holland, bish!
    Quote Originally Posted by Rockiii View Post
    I know he will be of good assistance!! But I want to know what I am talking about and what is happening
    Well... I guess I need a driving e36 first... so its not like I'm in a big hurry...
  19. #1444
    May 2012
    Wandlitz / GERMANY
    BMW E36 Sedan
    My E36 isn't driving yet too, so we both are at the same point now.
    I think at the end of next month i will start and see whats going on
  20. #1445
    Mar 2012
    Renton, Wa
    98 m3
    Quote Originally Posted by m2pc View Post
    Use this board with some of the outputs canged to run an oled screen.
    1989 535i - sold
  21. #1446
    SoCal
    89 325iS, 95 M3
    I'm currently trying to figure out how to take an aftermarket TPMS and route it into my OBC. Once I figure out how to input the signals, I'll design the menu option to check tire pressures.
  22. #1447
    Dec 2011
    Holland, bish!
    That would truly be awesome!
  23. #1448
    Jun 2003
    NY
    95 m3
    Quote Originally Posted by Korath View Post
    Have you settled on which TPMS you will use? It would be great if you choose a wireless TPMS so we have to run less cabling, like this one:
    http://www.amazon.com/Orange-Electro.../dp/B002DYH586
    1995 OBD I Cosmos Black M3 - RIP: gone but not forgotten
  24. #1449
    Dec 2011
    Holland, bish!
    There are tpms that have video output... perhaps these are easier to reverse engineer? Or is it in fact harder to identify the image processing part on the pcb? http://m.alibaba.com/product/5097429...fications.html
  25. #1450
    Dec 2011
    Holland, bish!
