Bavarian Soundwerks
Page 5 of 75 FirstFirst 1234567891011121314153055 ... LastLast
Results 101 to 125 of 1854
Thread: Feeler: Open Source OBC Firmware
  1. #101
    Aug 2008
    da joisy shaw
    '99 323 vert, '08 535xi, '95 525, '05 vette cpe, +
    sweet idea ...
  2. #102
    Yorba Linda, CA
    1999 TiAg M3, 2003 E46M3
    Yes and they'd virtually never need replacing either.
    Using RGB LEDs we can "mix" any color we want, similar to how a monitor mixes Red, Green, and Blue pixels to form any number of colors.
    Internally there are separate "light pipes" for the main OBC and the clock.
    We could even have the clock be a different color than the main OBC, or have the display change color to reflect the importance of the message, etc.
    Example: Imagine the "External temp" display being in a color appropriate to the outside temperature, or a radar detector message blinking in alternating red/yellow.
    The possibilities are endless!
    1999 ///M3 TiAg | Heated Power Vaders | DDM Projector36 5000K 55W HIDs | DDM 3000K 35W HID Fogs
    DDM Smoked Corners | DDM Weighted Shift Knob | K&N CAI | Mishimoto AL Rad w/Zionsville AL Shroud
    Stewart HiPo Water Pump | Samco Hose Kit | 16" SPAL Puller Fan | Viper 5701LE Security
    E36 OBC is now open! Join the effort: BF.C Thread | openOBC Wiki
  3. #103
    Sep 2002
    USA
    BMWs
    Any intention to support CAN? You could then feed in a signal from a datalogger or ECU. Would be hot to have "boost" show up on an OBC.
  4. #104
    Nov 2008
    TX - Dallas Area
    3/92 E36 Sedan
    OBC is going to mean a lot more pretty soon. I think there will be a lot more people wanting to upgrade to the 18-Button OBC. hehe
    Boost would be nice to have let alone to see on the OBC. I like the datalogger idea. I would be able to connect my PDA to it.
  5. #105
    Yorba Linda, CA
    Quote Originally Posted by 5mall5nail5 View Post
    Sure, why not... :P
    Do you have any links to documentation on the CAN bus and its protocols/connectors/etc?
  6. #106
    Sep 2002
    USA
    BMWs
    http://en.wikipedia.org/wiki/Controller_Area_Network
    Usually simple two wire twisted pair
  7. #107
    Yorba Linda, CA
    Is this the "Computer Data Lines" I see referenced in the OBC connector and E36 wiring diagrams?
  8. #108
    Mar 2008
    Portland, OR, USA
    1999 M3 Conv.
    According to the schematics, there is a TX/RX pair going to all the modules (including the OBC) and to the diagnostic connector.
    So i think this is a CAN pair, and for the openOBC project we are considering a CAN capable microcontroller.
    I understand you can plug some device to the diagnostic connector to reprogram the boost mode right? If so we need the info on this protocol. Can someone supply this info? If not, then we would have to hack that. Anyone has that boost device ?
    It would definetly be neat to use the openOBC to toggle my M3 from econo to boost....
  9. #109
    Sep 2002
    USA
    BMWs
    The CAN protocol is usually pretty universal. If you look at digital dash displays like the Stack and AIM dashes that support CAN, they usually have a break down. They also display all the ECUs they support. There are some instances of ECU that use a modified CAN format but not many.
    If you grab a USB-CAN adapter you can prob hyperterm or something similar and find out what it's outputting and make sense of it
  10. #110
    Mar 2008
    Portland, OR, USA
    1999 M3 Conv.
    Ok... worst case scenario we install the openOBC and operate the performance programmer while the openOBC is in some "listener mode", relaying everything to the external com/usb port....
  11. #111
    Yorba Linda, CA
    I'm sold, let's do it!
    Along those lines, does anyone know the specific codes for ZKE/OBC/DME that pertain to the E36? I'm curious to see what functions can be performed and what sensors can be read over this bus.
    Thanks!
    BTW, Mefis and I have teamed up to get this project off the ground -- stay tuned for some exciting updates very soon!
  12. #112
    Nov 2008
    North Carolina
    95 325i
    this thread is getting so annoyingly interesting.
  13. #113
    Mar 2008
    Portland, OR, USA
    1999 M3 Conv.
    Yes, but I need a prototype unit. Anybody wants so sell me a 18 button OBC unit? Broken one is ok as long as screen/buttons are somewhat functional
  14. #114
    Yorba Linda, CA
    I picked my "test" unit on eBay for $50.
  15. #115
    Mar 2008
    Portland, OR, USA
    1999 M3 Conv.
    Hi all!
    Here is where we stand on the product selection. These are all the major devices we see included so far. Digital I/O and analog I/O are included in the MCU. The CAN can not be built in, so we are supporting it on a separate chip. The GPS must have external antenna because inside the OBC case there is too much shielding.
    I will not dare to give a budget at this point, but hopefully it will stay bellow 300...the GSM is the most expensive piece, and is totally optional.
    Any comments?
    -MCU:
    PIC18F87J50
    http://ww1.microchip.com/downloads/en/DeviceDoc/39775b.pdf
    -CAN interface
    MCP2515
    http://ww1.microchip.com/downloads/en/DeviceDoc/21801e.pdf
    - Accelerometer
    ADXL213AE
    http://www.analog.com/static/imported-files/data_sheets/ADXL213.pdf
    -GPS Module
    GPS-08146 Copernicus DIP
    http://www.sparkfun.com/datasheets/GPS/Copernicus_Manual.pdf
    -GSM Module
    GM862 Cellular Quad Band Module
    www.sparkfun.com
  16. #116
    Yorba Linda, CA
  17. #117
    Upstate New York
    01 740iL, 92 325i
    This sounds like a great project, why not set up a paypal account in case anyone wants to donate to the project? I'd surely throw in $10 for the cause.
  18. #118
    Yorba Linda, CA
    One the main website is up, we will surely have such a "Donate" link.
    Thanks for the interest!
  19. #119
    Mar 2003
    St. Joseph, Mo.
    e36, e46 ZHP, MkiV Tdi
    subscribed and very interested. if i could gain oil pressure, oil temp, etc. without having to add more gauges in the car; i'm in!!
  20. #120
    Nov 2008
    TX - Dallas Area
    3/92 E36 Sedan
    You need a site, I can build you one. Let me know.
  21. #121
    Chicago, IL.
    2001 330xi, E92
    You should also add a configurable output for a chime or "dummy" light for important or dangerous sensor readings.
  22. #122
    Yorba Linda, CA
    Quote Originally Posted by 12v Electronics View Post
    That will be very easy since there's already 2 outputs from the OBC -> Chime module for the 37F warning and "Memo" functions.
    We could also embed a tiny piezo speaker onboard if there's room.
    We'll have to see after we get the board layout done.
    I will be unsoldering the X1070 and X1071 connectors from my test OBC this weekend and soldering them to some perfboard so I can test further and get a feel for the board layout.
  23. #123
    Mar 2008
    Portland, OR, USA
    1999 M3 Conv.
    Quote Originally Posted by shadowpuck View Post
    Do you know if most E36s have oil temp and oil pressure built in? If not can you suggest after aftermarket/bosch sensors or has someone done this?
    The same for fuel pressure?
    Need some datasheet to design the analog inputs for these things.
    Thanks!
  24. #124
    Yorba Linda, CA
    The only temp sensors the E36 has are coolant, outside air, and transmission. Oil pressure is a simple on/off switch for detecting low pressure.
    It would be really cool if we could find a screw-in replacement for the oil pressure 'switch' that was analog and then have the openOBC drive the low pressure signal to the cluster.
    That way you could get oil temp reading plus still retain the "dummy" light in the dash, without having to tap another sensor into the oil flow.
    Fuel pressure and oil temperature would need external transducers to read the values.
  25. #125
    Mar 2003
    St. Joseph, Mo.
    i'm pretty certain the e36 doesn't have an oil temp sensor of any type and the pressure is a simple too low switch, as you've mentioned.
    i had just figured i would have to add the sensor for that kind of function, i just didn't know if there was a way for this "upgraded" obc to possibly read it. i figured there was, but didn't know the details!
    any e36 i've ever known to have oil temp and a real pressure gauge had run aftermarket gauges. i know there's some kits for this; i'll see if i can drum up a link or two....
