Bavarian Soundwerks
Page 10 of 75 FirstFirst 12345678910111213141516171819203560 ... LastLast
Results 226 to 250 of 1854
Thread: Feeler: Open Source OBC Firmware
  1. #226
    netherlands
    '02 330i
    still down
    any updates?
  2. #227
    New York
    Red E30 Black E36
    Quote Originally Posted by ganesht View Post
    ETA on the site coming back?
    BTW hows the job hunt? im in a similar situation =/
    Why hunt for a job when you can just sell these things?
  3. #228
    Chicago, IL.
    2001 330xi, E92
    Quote Originally Posted by HiTheNameIsBj View Post
    I really want this to happen, I'm coming to the end of a turbo build which means I A: buy a buch of gauges and have them scattered in the cabin, or B: buy a pox multi gauges and all it's expensive sensors. I would love to have the stock look of the open source obc. I have a sudgestion as well, not sure if anymore mentioned it but, what about the ability of preseting values and using the obc's speaker to chime when that preset it reached. Such as boost level >14psi, once it hits 15 the memo chime goes off.
    Buy the gauges IMO. Even if this ever works, guages are much easier to read ----especially in a turbo build.
  4. #229
    Yorba Linda, CA
    1999 TiAg M3, 2003 E46M3
    November 1, 2009!
    I haven't landed anything full-time, but my contract work is picking up, which is good. Bad for side projects like this, but good for paying the bills.
    Rest assured although this project has been idle for several months, I'm determined to make it a reality and I won't let it die!
    Stay tuned...
    1999 ///M3 TiAg | Heated Power Vaders | DDM Projector36 5000K 55W HIDs | DDM 3000K 35W HID Fogs
    DDM Smoked Corners | DDM Weighted Shift Knob | K&N CAI | Mishimoto AL Rad w/Zionsville AL Shroud
    Stewart HiPo Water Pump | Samco Hose Kit | 16" SPAL Puller Fan | Viper 5701LE Security
    E36 OBC is now open! Join the effort: BF.C Thread | openOBC Wiki
  5. #230
    Sammamish, WA
    95 Hellrot M3/02 MY Z06
    Wow, how did I miss this thread! Subscribed! Not a coder, but was once Nasa Certified in Soldering. (used to be an Electronics Tech with Western Digital in the 80's, then Electro-Optical Laser R&D Tech with Rockwell working on Star Wars stuff, before I got into Boeing)
    Hope something works out for you m2pc!!!
    John
    '95 Hellrot M3 w/Dove
    AA Euro HFM Stage II (w/21# Injectors & Software) W/Gen III Exhaust - URI Crank Pully - FDM w/3 Row M Coupe Rad - 3.23 LSD - Vogtland Club Spec/Koni SA - UUC Red w/Enforcers - TMS Shims/Rear Camber Bars w/QA1 inners/Sways - VMC F/TMS R End Links - X-Brace - Perf Ultimate/SS Brake Lines - GC Tower Mounts/RTAB Shims - ZKW's w/5000K Hid - Fog Delete - Alpine 9847/Pioneer TS-C130R Kevlar Components/Pioneer PRS-X340/Stealth Box's/Wired Zune 120GB - OE LTW CF Sills/Glove Box Plate - Staggered Black M-Spoke II's w/235/40 (front), 255/40 (Rear) Nitto NT05's - Rolled Fenders!
    ***Got a '95 M3? (actually pretty common on all years! Even happened to Racer Seth Thomas! ) Check Your LSD! http://forums.bimmerforums.com/forum...d.php?t=390209
  6. #231
    Sep 2009
    San Francisco
    2001 525i Touring
    Did any of you look at the REV iphone app
    http://devtoaster.com/products/rev/index.html
    which uses this OBDII connector
    http://www.plxkiwi.com/kiwiwifi/hardware.html
    and they have a SDK to develop with
    http://www.plxdevices.com/sdk.html
  7. #232
    Nov 2008
    Portland, OR
    '96 Nissan 200sx SE-R MT
    Quote Originally Posted by m2pc View Post
    November 1, 2009!
    Stay tuned...
    If it helps at all, i have a webhosting account that's basically collecting dust. I can't support php, but i can offer you hosting if this thing is low traffic. Let me know if you're interested.
    '96 328is 5speed - CDV Delete, SPAL electric fan with SPAL PWM controller, weight reduction, Koni str.t springs, H&R OE sport springs, 16" Kosei K1's, ECIS CAI, bored out cupholders.. etc
    Sold 04/27/10 - Now rockin' a 1996 200sx SE-R.
  8. #233
    Yorba Linda, CA
    Pushed back another week but not forgotten. I've got to get a handle on my oil issues ATM.
  9. #234
    Jun 2008
    96 328 saloon
    now forgotten ? bump for what would be a very epic upgrade
  10. #235
    Yorba Linda, CA
    No, not forgotten -- I still have the spare OBC hooked up to my test harness in the garage; just been so crazy busy with work I barely have time to maintain my E36, let alone finish my projects like openOBC and the LED tail retrofit.
    The projects won't die, but are slow moving ATM.
  11. #236
    Detroit Area
    '97 m3, '06 330i
    I'm still interested in being apart of this project.
    sun-roofless artic silver 97 m3, Squid Industries custom SSK, Vogtland club spec springs, Ground Control street camber plates, Bilstein sports, OEM RTABs w/limiters, 8.5 x 17" DSII's, Safety wired oil pump nut, Sway bars (27/stock), conforti tune
  12. #237
    Yorba Linda, CA
    Ok everyone, I landed a real job now, so it's time to really begin implementing this project. I was thinking that a project of this magnitude will require a bit more horsepower than a simple MCU like a PIC, etc.
    Let's start looking into small embedded Linux SBC's. Here's a few I'm considering:
    http://foxg20.acmesystems.it/doku.php?id=:start
    http://www.embeddedplanet.com/products/ep852.asp
    http://www.embeddedplanet.com/products/ep405pc.asp
    Using a real Linux-enabled SBC will allow the most flexibility. We can then program the openOBC using C++, Python, Perl, etc.
    Ideally, a CF card would allow easy upgrading/feature selection. Many SBC's have Ethernet ports allowing for online updates via the web.
    What do you guys think?
  13. #238
    Sammamish, WA
    Congrats on the Job Bud! Here's to a better '10!
    John
  14. #239
    Yorba Linda, CA
    Quote Originally Posted by JETninja View Post
    Yes, definitely! Being out of work for 8 months was not good at all!
    Thanks!
  15. #240
    Detroit Area
    '97 m3, '06 330i
    i like the idea of moving to a embedded board. This is still a new area for me, but i have been looking at the beagle board for a different project. It might be a good fit for this one as well. It uses TI's omap processor.
    http://beagleboard.org/
    there are various 3rd party implementations of this as well. I am in particular looking at this one.
    http://www.igep-platform.com/index.p...d=46&Itemid=55
    for about $215 you get Ethernet, 512meg ram & flash, bluetooth, and wifi. It also has a onboard microsd slot. Basically a full blown PC thats very small.
    If you ever wanted the ability to do full blown nav, mp3s...etc they have had success connecting these to a PSP display with voltage level shifters.
    anyways these boards are probably overkill for this project, but i think they have some appealing qualities.
  16. #241
    Dec 2004
    NJ
    95 525iT/97 328iC/03 530
    Glad to hear you are back in the full time working world and have time for this project again. I am a EE but not an expert embedded programmer. It seems that if you are considering more powerful platforms, you should consider the nano and pico ITX PC compatible motherboards that are out there. VIA has several different models with a good amount of peripheral component capability built in. I am certain that they will run Linux. The limiting factor of those boards is probably the lack of built in analog to digital conversion but that might be offset by easier connectivity to the outside world. A/D boards with USB connectivity are not hard to find. I don't know what they cost today. I bought one several years ago for about $150. The VIA Artigo pico ITX board was around $200 the last time I looked.
    2003 530i Sport 5 spd, 97 328iC 5 spd w/M Lux Package, 95 525iT w/S52 5 spd swap, 2008 R1200GS Adventure, 92 Celica All Trac Turbo
  17. #242
    Yorba Linda, CA
    Quote Originally Posted by Mark185 View Post
    I've seen a lot of info on the web about the Nano and Pico-ITX sized SBC's, but my only concern is the footprint. Remember, this has to fit inside the existing OBC housing to be really useful IMHO.
    I'll do some measuring and check the web for boards that fit.
  18. #243
    Mar 2004
    FL
    '98 328i
    A great addition would be for the CODE to arm automatically every time.
    Tampa
  19. #244
    Yorba Linda, CA
    Quote Originally Posted by benjlv View Post
    Wow I wasn't aware these could run Linux... If the size is small enough, this just may work.
    A CF slot is also a big plus.... MP3s lol, we could program a custom sound for alarms, etc.
    Thanks for the suggestion!
  20. #245
    Detroit Area
    '97 m3, '06 330i
    mp3 playback is a very attractive feature i think. the linux software to make that work is basically already written. Its called MPD (music player daemon). I runs as a service on the linux machine and is capable of playing nearly any format (non DRM). It supports a wide range of clients for the selection of songs. I personally use the software on my media PC with a client from my iphone. There are also some clients that work with LCDs...etc.
    http://mpd.wikia.com/wiki/Music_Player_Daemon_Wiki
  21. #246
    Yorba Linda, CA
    After considerable research, I'm leaning toward this GumStix module:
    http://www.gumstix.com/store/catalog...roducts_id=226
    Cost is $199 USD, includes WiFi 802.11g, Bluetooth, 6 A/D inputs, GPIO, audio in/out, and SDCard slot. Runs Linux.
    Size is only 0.66 x 2.3 inches.
    Coupled with this board, you get through-hole connectivity:
    http://www.gumstix.com/store/catalog...roducts_id=239
  22. #247
    Detroit Area
    '97 m3, '06 330i
    that board seems like a good solution for this project. The 6 a/d channels is a very appealing since the board i listed only has 2. I assume we will eventually have to design a PCB for this project. This module would just plug into that, allowing the PCB design to be much simpler. There appears to be no onboard audio with that particular board. I might be overlooking it though. a USB sound card is a possibility, but adds to the overall cost of the project. Thoughts?
  23. #248
    Yorba Linda, CA
    Yeah I liked the high number of A/D, PWM, and GPIO channels available with this board.
    There's no "traditional" 1/8" audio jacks on the board, but it does list "Headset" and "Microphone" in the features list:
    on-board microSD card slot
    - I2C, PWM lines (6), A/D (6), 1-wire, UART, SPI, Camera in, Extra MMC lines.
    - Headset, Microphone, backup battery,
    - USB OTG signals, USB HS Host
    Wow, I just noticed there's also a "camera in"... this might make for some interesting security/race cam recording possibilities for the OpenOBC!
    UPDATE: This board seems like a perfect fit for the OBC case:
    http://www.gumstix.com/store/catalog...roducts_id=230
    Breaks out audio to standard jacks, includes USB, Ethernet, and HDMI/DVI connectors.
    Plus it has a row of 0.1" through-holes we can use to mount a header to connect to the OBC with.
    I'm ordering this stuff now to get the ball rolling. I'll post back results ASAP.
  24. #249
    Yorba Linda, CA
    Just got my Gumstix order in yesterday!
    The board on the left is the Gumstix CPU module (really is the size of a stick of gum!).
    Linux OS is loaded on the microSDHC card which fits into a slot on the CPU module.
    On the bottom right is the expansion board that the CPU plugs into.
    Left to right on the bottom edge is: +5V in, USB OTG (usb client port), audio in, audio out, HDMI out, USB host port, and 10/100 Ethernet jack.
    Lots of I/O is broken out on the top of that board, with A/D, PWM, and GPIO all available on easy-to-use 0.1" centers.
    More to come!
  25. #250
    iowa
    92' 325i 4dr
    is the signal sniffing done on the display outputs?
    website status?
    donation button?
    bilstein sports - eibach pro kit
