here is print from my today computer diagnostic test (7 times is error recorded):
is this "ventil 2" maybe number 2 here:
http://bmwfans.info/original/E36/Cou...1/ill-11_1304/
what this error mean?
http://www.youtube.com/watch?v=Ocrvaw3d4UM Dont drive over limited speed!!! Drive safely......
i need to learn german lol
I can't read that much German, either, but it looks like the advance or retard oil solenoid valve is bad. Dr VANOS will replace those valves along with refurbishing the rest of the unit. I wouldn't bother opening up the VANOS to replace just one valve, so a completely rebuilt unit is a better choice.
James Muskopf
RRT Racing
DC Metro's premier BMW service and racing facility
It's not speed that kills, it's the speed difference that does. Obviously you aren't going fast enough.
Turning Benjamins into noise since 1997
I read a list of the 100 things you MUST do before you die. Funny, "Yelling 'HELP'" didn't make the list!
Hmm, I don't see that listed under the $300 rebuild price. I'm sure they can replace those solenoids for additional cost, but you just have to contact them. My exhaust solenoid cover just started leaking, great. I should be able to replace that small cover gasket without major surgery, though...
James Muskopf
RRT Racing
You have noticed this problem before I did.
I would highly recommend looking at the following. That Gasket s NOT there to keep oil in, it holds the solenoids in place. There should be no oil in that chamber in the first place.
http://forums.bimmerforums.com/forum....php?t=1103286
I nearly lost my motor over this. You will need to replace the O-Rings on the solenoid.
Details here
http://mukerji.co.uk/vanos/
1998 M3 Evolution Convertible
