yes!
My Website
1982 323i
Under the Hood:
M20B23, Dogleg tranny, K&N Box Air Filter, Hayden 11inch Pusher Fan, redline tranny/diff fluid, Dual Exhaust,3.45 open.
Braking/Suspension:
Steel brake lines in front, front/rear 323i disks, Front and Rear Strut Braces, Lower Alpina(Ken) Bar, Kmac Camber/Castor Plates(Raise the front 1 inch), PolyUrethane Steering Rack Mounts, Rims = RG alloy wheel set (BBS design) silver 6x13“ KBA 40324, Tires: Sumitomo 195/60/13, Struts: Bilstien HDs Springs: Stock
Body:
087-Graphit-metallic, Euro Bumpers, BBS Valance, Foha Rear Spoler, Yellow Hella High Beams
Interior:
Recaro Front Seats, Sports Steering Wheel, Kph 220 Speedometer, Vacuum gauge, Air/Fuel Gauge
absolutely
i'm in...
i too support the notion...
Do it! Really any type of project/DIY is worthy of a thread.
.: M42 Swap Thread M42 Turbo Build Thread E85 Conversion :.
My YouTube Channel: https://youtube.com/c/AdamPE21
Definately!
I'm frightened about my car in the body shop.
Good on ya, fixing all this yourself.
Frighteningly familiar... see my resto thread.
You ever get down to Portland much? a bunch of us are getting together tonight to help a local buddy get some work done on his Koronagelb 320i, prepping his recently emptied engine bay & freshing up a donor m10 with all new gaskets & doing some other odds & ends. look us up next time you are down here.
I would like to see a write up , I tried to salvage the old Headliner but that lasted a few minutes into welding tha rear window frame. After looking at your resto we have very similar cars except for wheels, Do you plan to use a 2.5i top end on that super eta? I have been trying to decide on a motor for weeks, I have a 2.3 liter a 2.5i thats in the car, Or should go for an m30b35, There are drawbacks and advantages to them all. I also could do a stroker eta or super eta.
Super Eta's are great in that they make nice budget strokers. You don't even need a 2.5 top end, becuase the head is the same (885 casting). Drop in a chip and a 2.5I cam (and springs) and you'll pick up some good HP. Add 1.3 Motronic injection from a 2.5 and your even better off. I'm running a 2.5 with chip, headers, lightened flywheel and 17.5 lb injectors and it moves pretty well. Have a second 2.5 sitting in my garage that will become a stroker some day. I'm not a huge fan of the m30B35 becuase in my opinion they put even more weight over the front end.
I'm going to run a custom cam, 2.5L intake manifold, but the head will be the same. I'm building Megasquirt so no Motronic needed for me, besides, Motronic doesn't work well with boost & I will be adding on the Eaton M90 at some point.
The trick to the headliner is to use a good quality adhesive and lots & lots of small binder clips. Get most of the wrinkles out before you apply any adhesive, and get it all stretched into place. then, remove one section at a time and apply adhesive.
joel, what kind of welder did you buy?
-Josh
Marco = 82 320i Hennarot - 95 Porsche 911 Carrera - 95 Red MR2 NA Hardtop
"..Horsepower is a measure of work done over time, or the rate at which work is done."
http://www.cardomain.com/ride/579694/1
well, I'm still somewhat in research/tear down mode. I've got an '88 super eta motor, so I have the lower compression, better for boost. at the present time, I'm slowly soldering up my MS main board. I still need to buy a stimulator (board that simulates engine running condition so you can test) and a relay board.
I have also been compiling a parts list in MS Excel and quickly realized that I need to take a harder look at my budget for this, which has slowed me down. Unfortunately this morning, I realized my Excel file somehow has been corrupted. Not happy, I had some really good info in there, plus a table built on fuel injector sizing, with relation to HP & fuel pressure. I'm emailing it to my office so I can try and repair it on a newer version of the software.
As for a 60 teeth wheel, I'm not sure I know what you mean. I am planning on running a 36-1 wheel to run my EDIS.
My engine is currently dissassembled for the most part in order to inspect. I have a scratch in my # 5 cyl wall, I need to bring it to a machine shop to see how bad it is. IT sucks because I may need a new block in order to run the super eta pistons & my budget definately can't afford new pistons along with the added cost to have the cyl's bored.
Mine will be a slow build as I scratch funds together a bit at a time. For now, I'm keeping the 2.3L k-jet motor running in the car.
Jesse, I have to do something as I have my 2.9 just about built. All it needs is this years tax returns to finish it. I have the custom Weisco pistons, s50 rods, s50 crank, plus 1 valves and ported and polished head. But I need a standalone setup or megasquirt. I would like to use a laptop to tweak it.
You don't think you can just run motronic with a chip? Well, either way MS will be a great way to go.
Well, I typed out a bunch, but we have hijacked this thread enough, I'm starting a new thread just for MS, let's get back to rust repair.
update: Finally got some progress got my genuine bmw shock tower ( not cheap)
and removed the Rocker panel to repair the sill.
