Results 1 to 25 of 42
Thread: I finally did it! (e36 with Getrag 260)
    Dec 2005
    Central Valley, CA
    2011 328xi, E36 LS1
    Finished my 5 spd swap today. Man, the car is 100x more fun now. Thought I'd give you guys some details on what exact hardware I used since I didn't go the conventional route.
    The 260's gearing is great with the 3.91. Lots of pickup in 1-3 gears, good gas mileage in 4-5.
    BMW M50 Engine
    Getrag 260 Manual Transmission, part number 260.0.1346.90
    Manual Driveshaft from the e36
    Manual Flex Disc from the e36
    Differential from the e36, ratio 3.91; limited slip
    Dual Mass Flywheel from the e36 and new bolts
    Clutch kit and Pressure Plate from the e36
    Pilot bearing and throwout bearing from the e36
    Clutch Fork, pivot pin and Clutch slave cylinder from e30
    Pedal box from any manual e36
    Clutch master cylinder from the manual e36
    Brake light switch from the automatic e36 (clutch switch is unnecessary)
    I decided to use stock parts for reliability and cost purposes. Perhaps in the future I will go with a LTW flywheel, but I couldn't justify the cost.
    Here's a few pictures explaining the fabrication required.
    This is the transmssion brace viewed from the passenger side:
    This is before I bent the selector rod and carrier, you can see how it sits too far to the right:
    And here you can see that all the bellhousing bolts won't line up. The major ones do though.
    Ottawa, Canada
    10/96 318IS
    Good stuff, nice to see another who has gone this route .
    Current Mods....X-Brace, Stromung Cat Back Exhaust, 17/225/45 M3 Replicas, HotBits Adjustable Coil Overs, 40% LSD 3:91 Diff, E30 Gearbox, Boosted.
    Dec 2005
    Central Valley, CA
    2011 328xi, E36 LS1
    Yeah, it's fun to do something that most other people don't. Thanks for all your help man, your advice was spot on!
    downeaster1's Avatar
    downeaster1 is offline Expert De-Vanos-er BMW CCA Member
    Carlsbad, CA
    135is #502 of 586
    Remind me to do this one day. How hard do you think the whole process was in retrospect? I might want to do this eventually.
    Dec 2005
    Central Valley, CA
    2011 328xi, E36 LS1
    Really, it's not very mechanically difficult. Just make sure you have everything you need and a few days to do it.
    Oct 2007
    Sao Paulo, Brazil
    E36 325i reving up
    very good..
    The performance increase i think is the best of it.
    but, the diff of auto using 5 speed box is very good to drag performance, itīs uses 4.11 ratio i think.
    Miami
    00 M Coupe
    wow nice job....its about time
    Aug 2008
    Statesboro/Dallas, GA
    M52
    Have pictures of the clutch install?
    NEED SCREEN PRINTING? PM me
    Not Going Anywhere Fast...
    Dec 2005
    Central Valley, CA
    2011 328xi, E36 LS1
    Um...yeah I do. I'll upload them tomorrow, don't have my camera with me right now.
    And Matheus, the diff is 3.91, it's nice.
    Dec 2005
    Central Valley, CA
    2011 328xi, E36 LS1
    Well I lied, couldn't find any pictures of the clutch with the alignment tool in it. Here's the flywheel...
    94 325i, 95 M3, 1997 325
    Major props man congrats
    Washedit1 by thedude60526, on Flickr
    11/10's Racing
    94 325i #36/64 TEAM PENISTON OILS/ LARSENS BISCUITS
    Jul 2006
    Arab, AL
    '97 328i/6, '89f150
    great to see a fellow swapper, but...what transmission did you use? whats the differences here?
    -ducky
    Dec 2005
    Central Valley, CA
    2011 328xi, E36 LS1
    Getrag 260, it's from late e30 6 cylinder cars. 5th gear ratio is .83, so it matches up well with my 3.91 LSD from the auto.
    Jul 2006
    Arab, AL
    '97 328i/6, '89f150
    sweet! i miss my OD from my auto, but i WILL NOT give up my 3.91 rear end..im already spoiled with the false sense of torque ...i'm just holding out for a 6spd.
    is first gear absolutely useless in your car now?
    -ducky
    Wisconsin
    98 328IS 03 325xi
    Quote Originally Posted by RahgBag View Post
    So you end up with an overdrive trans, great idea with a 3.91.
    Gave away my BMWs, driving a VW and an Audi now.
    Dec 2005
    Central Valley, CA
    2011 328xi, E36 LS1
    Really, it's not as bad as I was expecting. But then again, I'm used to driving my Jeep, whose 1st gear is REALLY useless.
    Also, my 1st gear ratio is 3.83, as opposed to your 4.23.
    The 3.91 is great though, makes me feel like I've got like 300rwhp, haha.
    Iowa & South Dakota
    98 Buick Regal :(
    I wanna see some 0-60 speedo vids!
    Mar 2008
    Stoughton, Wisconsin
    1995 325i
    RahgBag,
    What is the large red button just in front of your shifter?
    Iowa & South Dakota
    98 Buick Regal :(
    Quote Originally Posted by dogg325i View Post
    RahgBag,
    You know exactly what it is, you just don't want to come to terms with it now do you?
    Dec 2005
    Central Valley, CA
    2011 328xi, E36 LS1
    Haha. Don't ever press the red button!
    It used to be a push button start, but now it's just there for people to ask about. I don't have another blank piece of plastic to fill the hole in with, haha.
    SF,Seattle,Boise,LA
    ACS e36, e30, 944
    Lets see it all. Show off now...please. Sexy time.
    Dec 2005
    San Diego, CA
    E36 328/E39 530
    Quick question: are the auto and manual engine wire harnesses the same? are they interchangeable? I'm converting from an M50 without vanos to an M52 and picked up an engine wire harness from an automatic vehicle. Just wondering if I could still use the auto harness since I have a manual car.
    Dec 2005
    Central Valley, CA
    2011 328xi, E36 LS1
    As far as I know the harnesses are the same.
    Aug 2008
    M52
    Where'd you pick up your transmission? I would love to keep my current gears when I do the swap, I think these gears with a 5 speed would be nasty, yours sounds like it is.
    www.hidmasters.com HB *OC* So Cal
    98M3Turbo..325turbo
    Quote Originally Posted by RascalKing View Post
    Your freeway mileage will go to poop too.
