Results 1 to 25 of 32
Thread: My car runs cold all the time? bad for the car?
    Stuart, Virginia
    91 mitsubishi eclipse gsx, 95 bmw 325i
    My 95 bmw 325i has always been on the cold side since I bought it. I put half water and half antifreeze in it. Sometimes I let it warm up for 15 minutes and the temp gauge gets to the middle. Then I go for a drive and it gets colder. Should it stay in the middle while I drive? Is it possible i have a fail safe thermostat that has went bad?
    ChattaHOOD, TN
    2000 323ci
    It's possible that you don't have a thermostat at all. Take it apart and check, definently sounds like a thermostat is bad.
    Stuart, Virginia
    Quote Originally Posted by IWannaBMW View Post
    cool. I wish it wasnt so cold.
    Dec 2005
    everywhere
    all
    yeah your thermostat is probably stuck open. replace your thermostat. running your car like that isnt too bad for it. it will just burn more fuel.
    Ottawa Ontario CANADA
    21 M3 6MT Dravit/KO/ZPP
    Happened on my e36, thermostat stuck open. Get it fixed, it is not good to run on a cold engine in the long run, at least not for your pocket and definitely not good in cold weather. If I recall correctly, it is an easy fix on the e36, but I didn't do it myself.
    Current Car (delivered 20/10/21): 2021 G80 M3; 6MT; DravitGrau/Kyalami Orange/Black Extended Merino; Permium Pkg (ZPP); 826M bicolor wheels; Black M Compound brakes; Sunroof (yes no CF roof)
    (more pictures here)
    Previous Cars: 2018 F30 340ix 6MT Msport(Dec 2017 - Sep 2021); 2013 F30 335ix 6MT Msport (Nov 2013-17); 2011 e90 328i 6MT ZSP (Aug 10-Nov 13); 07 e90-323i ZSP (May 07 - Aug 10); 97-318ti ZSP (Feb 97 - May 07)
    "Mit der Dummheit kämpfen Götter selbst vergebens", Friedrich von Schiller -- "Life is simple, people make it complicated", Me (About me)
    Feb 2001
    Fort Lauderdale, FL.
    2020 X3M Competition
    If the engine is not at proper operating temperature, it'll burn more gas due to poor fuel atomization and if it's 'too' cold it's revert to the cold run program which dumbs lots and lots of fuel to help heat up the engine.
    Let me get this straight... You are swapping out parts designed by hundreds of engineers that get paid thousands of dollars for something you bought at Pep Boys because your buddy who doesn't have a job told you it was 'better'?!?
    Nov 2008
    Kennesaw, GA
    97 328is, 95 Ford Ex
    The manual says not to let your car warm up. It's better for the engine to just let it warm up while you drive. Just take it easy on the car till its warmed up. But yeah, you sir, have a bad thermostat in your car. It's a very simple fix i just did mine. had your exact same symptoms.
    Texas
    2004-325i, 2005-530i,
    +1
    right on the front of the engine
    Jan 2006
    Las Vegas
    00 E38,01 E38,99 323 is
    You will need to remove the fan. A 32 mm wrench, and remember it's reverse threaded.
    9/2004 Chevrolet Suburban Z71, black, purchased March 2016, 270k miles.
    6/99 740i Cosmos Schwartz M Sport, 214k miles, purchased May 2017
    2001 740i OrientBlau M Sport, purchased March 2023
    1984 MasterCraft Stars and Stripes, Blue/White, PCM Ford 351W, PowerSlot, 912 hours, purchased September 2012 (not a car )
    4/99 323is/5. Titansilber, 211k miles. Straight body project.
    past BMWs: 5/1994 325isa (Arktisgrau), 3/1997 328is/5 (cosmosschwartz), 9/1990 535i/5 (calypsorot), 9/1990 318i/5 (brillantrot) 7/93 325i/5 convertible (samoablau) 2/92 325i/5 cabriolet (lagunengruen).
    SÜNDE REISEN
    Bethlehem/Philadelphia pa
    99 740i,535xi,z4 mcoupe
    Definatly an easy fix and you can think of it one way atleast its not overheating.
    Feb 2004
    Plano, TX
    '96 328; '85 4Runner
    It is an ez fix, but if it's too cold out wait for a good day. I did a 2200 mi trip to go skiing in Col with below 0 temps and guage never got much above blue. Averaged over 31mpg too, so it wasn't dumping that much extra gas in either. Biggest problem was having to wear coats in the car cause the heater was worthless at that temp Fixed it a few weeks after I got back.
    David M.
    '96 328 Sedan
    Stuart, Virginia
    awesome. I have been running the car like this for a year and didnt realize what the problem was until I heard of fail safe thermostats. I just bought a t stat for 17 bucks at advance I hope I can replace it soon. I have a garage with a heater but I dont like to drive threw the yard, we just had it reseeded.. i may still fix it tomorrow. thanks for the help. -Austin
    Oct 2008
    Australia
    325CI manual
    Fix it's bad news. My temperature starterd wandering recently and then slow warm up. Diagnisis thermostat. As car is over 5yrs old then top hose, expansion tank, coolant etc. Getting done 5th January as that's the earlist I could get in. No trips till then unfortunately
    Mar 2005
    San Diego
    E46, RT, Avalanche
    It's not the size of the dog in the fight, but the size of the fight in the dog.
    Stuart, Virginia
    Thanks.
    BINGO. My old thermostat was broken in half. I installed it today but my radiator plug poped out, because I broke it a year ago. Im suprised it likes to pop out now. I order a new one. Thanks for the guides but I never got a chance to use them because I started on it and figured it out by myself. I didnt have to take the fan off, I just had to take the fan shroud out.
    Feb 2008
    Salem OR
    2016 328i Sport
    Ok, not to thread jack, but- Ive noticed in the cold weather we are having in the PNW that if Im just sitting at idle my heater doesnt blow very warm. If I rev the engine it gets warmer.....while Im driving or at idle the gauge reads right at middle. Is this normal?? Thanks-
    Dec 2008
    Oregon
    1998 Bmw 328is
    yup, thermostat. pretty common.
    Utah
    '67 HD Electra Glide
    We're lucky these aren't Subarus (the older ones). Their thermostat design causes them to fail in the closed position. That's a "hot" problem.
    I hated finding that 32mm wrench, btw. Lame.
    1998 E36 M3/4/5 - 1993 Spec E36 325is
    Crew - #52 - SCCA World Challenge TC
    MoTeC Man
    Oct 2007
    Chicago
    E30 & E36
    Running cold does in fact accelerate wear on your engine.
    -Luke
    EFFEKTIV Motorsport
    #189 GTS2 - Ground Control / Motorsport Hardware / Hawk Brakes
    Visit us @ https://www.facebook.com/EffektivMotorsport
    Memphis, TN
    '95 325i & '95 318i (R.I.P)
    Agree: it's the t-stat
    Quote Originally Posted by whiteknight View Post
    '95 325i- My t-stat is dead as well as the heater core leaking and fogging up the passenger side windshield. If change the t-stat yourself, pray that you only have to remove the shroud, otherwise, it's a PITA,,,,or at least, that's been my experience. I ran out of patience and took it to my guy to fix. $132 later, it was doing fine,,,,until this year!
    Dec 2008
    Cape Girardeau,Missouri
    325i,Ford F150
    I took a Standard wrench and ground it to size as it was Sun. evening
    Lleida, Spain
    M3 E30, 325ic E30
    I have the same problem with my M3.
    I change the thermostat, one year old, I replace it for a new one, and the problem still there.
    Any solution?
    May 2009
    Belgium
    '97 328i
    Quote Originally Posted by Taper View Post
    Any solution?
    What problem is that from those posted above, no heat at idle? If that's it:
    - it's normal for the air to be lukewarm until you give it some revs (1.5k or so will do), because the airstream's cooling capacity overwhelms the heater core's heating capacity at the low flow rate at idle
    - you may have air bubbles in the system, causing poor coolant flow through the heater core. Bleed the system.
    Lleida, Spain
    M3 E30, 325ic E30
    If I drive my car in traffic the temperature stay in the middle, but if I drive my car on open roads the temperature drop to the blue zone
    Mandeville, Louisiana
    '95 740IL, '01 740I Spor
    Running the proper temperature also helps with oil proformance, below normal temps will cause sludge to form.
