- Speedometer issues
Speedometer issues
Having an intermittent problem with my speedometer. Sometimes it will work, others it will just sit at 0, and others it will attempt to climb up to the normal speed and then drop down to 0. All other lights and components work on the cluster, except for dead pixels where it shows the OBC information and mileage. What do I need to do to get all of this working again? My first thought was a new cluster, but that sounds pricey. An old cluster won't work though will it? Or is there an easy fix around a new cluster?
What is the year and model of the car?
Sounds to me like an issue with a speed sensor or the wiring of the speed sensors.
Any ideas? I'm planning on taking it in Monday, but I'd prefer to just DIY it. Also recent issue, ASC and ABS are permanently disabled. Unresponsive to the button.
- You may not post replies
- You may not edit your posts
Forum Rules
