Anyone ever replaced their fuel pump/gauge sender without the BMW special tool? How did you remove & tighten the retaining ring? I can't budge the thing.
I like the unicorns.
'99 Z3 Coupe - Jet Black/Black (1-of-114)
'99 M Coupe - Estoril Blue/Black (1-of-82)
'03 540iT - Sterling Gray/Black (1-of-24)
'16 Z4 sDrive35i - Estoril Blue/Walnut (1-of-8)
I had to fabricate a tool out of a metal handle I had laying around, cause that ring is a bitch to remove. Randy did the same iirc although his tool looked better.
997 Carrera 2S..the choice of 2 out of 3 Top Gear presenters.
Can you describe what you made? Or, of course, a picture is worth a thousand words ...
I do it all the time, very easy.
Put a hammer on one of the teeth and just hammer it.
Piece of wood and a hammer. It doesn't damage it. You don't have to hit really hard, it's just the shock that loosens it.
Josh
I just used a piece of aluminum against the rib or tooth of the ring and tapped with a hammer. It released rather easily.
Dan "PbFut" Rose
Edit: there's a spec on tightening that ring, which is what motivated me to fabricate a tool I coulde put a torque-wrench on.
That's a little tricky to fake, unless you have a freshly calibrated hammer...
The hammer trick didn't work for me. Seemed like the impact was getting absorbed by the whole tank moving just a bit. I'll keep at it. Thanks for the homemade tool ideas!
The tightening torque value escapes me at the moment (and too lazy to look it up for you), but I remember it being surprisingly high. You'd have to really wail on it with a hammer to get it loose, but how would you know how hard to hit it to tighten it back up?
Given what you'd risk by having that joint fail, I hope that you're planning on torqueing it to spec. Hate to think you'd lose a race
It's 41 ft-lbs. To be honest I don't torque everything to spec ... probably not good, but sometimes I'm lazy, especially when it involves the need to make special tools :-)
But we'll see how it goes. I haven't had a chance to get back out to the garage to wail on the thing with a hammer again anyway.
Josh
Well, I'm giving up. I can't budge it to save my life.
The car will be going to a shop later this winter so I'll leave it for them. Or maybe I should just destroy the thing and buy a new one, it's less than $10.
