Since it is still outside, it functions the same.Originally Posted by jhyan
Sent from my iPhone using BF.com
It is an air ambient temperature sensor.Originally Posted by jhyan
Sent from my Thunderbolt using BF.com
I got stealership'd
I just fixed this in my car last month. -40 degrees means you are missing the sensor, +122 means the wires are short circuiting. I paid $92 dollars at the dealer, do yourself a favor and just order it from a reputable site online and wait for shipment. Not having it won't hurt your car so it's not an immediate fix.
^ouch! HERE is a link to the sensors, both the OEM and aftermarket are about half the dealership cost.
James with ECS
Great, informative thread!
Over the last year or so, my temperature has been consistently reading 10 degrees F over what it actually is (as reported by store signs, etc). Any ideas why, before I go digging under the wheel well?
Thanks in advance!
-A
Mine has been reading -35 for the past few weeks. I guess it probably means the same as the -40's? The car is a 1999 328ic.
edit: the display is not on the center dash, it's on the check control display
Mine has been working fine for the most part, but every few days, it will show 37*F when the air temp is 60+. Bad sensor?
2004 330i
2004 330i
I read this post and decide that my dash works not good. All the time it show +50C/122F. I replaced new wires from dash and get same +50/122. Already replaced 2 sensors and no one works. Yesterday i saw interesting thing... My car was standing on the sun all day and it showed +38C, but then i take it go garage it starts showing : 38 37.5 36.5 35.5 34.5 34 and +50 again. I get car outside again and it shows +37... Temperature shows only from +34C/93F. If i remove wires from dash i get +50 anyway than i should get -40. But then i connect + and ground wires together it shows -40C.
what variable resistor i should buy? any links please
I had the sensor on mine ripped off once so I relocated it in behind the front fender liner. Now its well up and away from moisture and other problems.
Ok, back from the dead...
I have a 1998 E38
I've looked under both sides and can't find any blue wires. And I've looked everywhere.... I'm so confused (and uncomfortable). The A/C is fighting this like a prick because it thinks it's -40c and it's actually +35c.
Any other ideas as to where I could look for the wires??
They are in the wiring harness for the drivers side fog light. All you have to do is peel back the electrical tape and there will be two blue wires in there..... not that hard.....
Bodyshop took mine off for painting and reinstalled it with one of the tiny contact pins bent over. I straightened the pin and all was good. Check the contacts before buying parts.
Just want to add another possible cause to this thread that had me perplexed before I figured it out. The horn and temp sensor have nearly identical connectors that will fit if forced! So check if they got swapped if the wire colors don't seem correct. This happened to me recently.
A truck backed into my front bumper and damaged it. While the car was at Caliber Collision having a new bumper installed they somehow swapped the horn and temp sensor plugs. When I got the car back the SES light was on because of the sensor's apparent use by the DME. I read the codes with PA Soft BMW Scanner 1.4 and noticed the IKE error regarding the ambient air temp sensor. I also noticed the cluster displayed -40C. My car is a 2004 330Ci with MS45.1 DME.
While working on the problem I saw the temp sensor plug didn't fit quite right and was pushed on really hard, plus the wire colors didn't match those on pins 1 and 2 of the instrument cluster connector. After probing the wires, reading the WDS, and thinking about it for a few days I suddenly thought maybe the wrong plug was on there and went back to look at the car. That's when I noticed the correct colored wires going to the horn. Bingo!
Need a DME or EGS update?
https://forum.e46fanatics.com/showthread.php?t=1081716
Coding 530i after AT->MT Swap
https://www.bimmerforums.com/forum/s...ter-AT-MT-Swap
Old thread but immediately after coding my E91 today my temp sensor is reading 90 degrees f
Should I restore backup?
