The RCA cables on that top harness plug picture plug into the rear of the aftermarket radio (preamps), they do not go to RCA cables that run all the way to an aftermarket amplifier. It is plugging the amp integration harness RCA's into the head unit preamps that complete the signal for sound to travel to the factory amp. If you tried to run RCA's from the Metra harness back to an aftermarket amp, the radio would have no way to send any sound signals to the amp, so it would be just like connecting an extension cord to itself, you are cutting out the part of the system that creates the signal and no power will be transferred. Just think of it this way...on the factory harness you have the speaker wires going from the amp to the headunit. When you change the radio to aftermarket and use the Metra harness, it changes those wires into RCA's. If you tried to send the RCA's back to the amp, then you will now have no speakers hooked up to the head unit because you just sent those speaker wires back away from the radio. The whole reason this adapter was made was to simply swap out your factory radio and install an aftermarket radio without having to bypass the factory amp. I know for a fact that this harness is made for keeping your OEM amp and just changing your head unit to an aftermarket one. I've done 2 cars both with a common ground factory amplified sound system using this type of harness and in each case I changed out the factory radio and kept the OEM amp and speakers without rewiring anything.
The harness below that one is for a non amplified system where the speakers are powered directly off the head unit itself and not an OEM amplifier. By using that harness on an OEM amplified system, you would have to bypass the amp and run all new wires from the head unit to all the speakers. That again is why the amp integration harness was made.
As far as having to start from scratch on your 86 535i with the common ground system, if you had a similar radio that I had in my 90 525i where there are several smaller connectors that connect to the rear of the radio, you didn't have to do all that. There are ways of connecting an aftermarket radio to a common ground amplified speaker system without having to "start from scratch" and that is why I posted this information up. The sad thing is if you have a similar system as I do, you didn't have to buy any additional harnesses, bypass the factory amp or run any new wires at all. All you need is the aftermarket radio harness and some connectors.
And just to clarify, I do have the common ground factory amplified system found in older E34's in my car with a JVC aftermarket radio in it now working awesome and I am using the OEM amp and speakers without running new wires to any of the speakers and it took me about 7 minutes to install the JVC radio into my car.
I've installed aftermarket radios into 3 cars now that had an OEM common ground amplified system without having to bypass any amp or rewire any speakers.
Here is a diagram on how you would use the Metra amp integration harness to swap out a factory radio for an aftermarket one into a BMW with the factory 17 pin wire harness without having to bypass the factory amp and rewire any speakers. You need to connect the RCA cables to the rear and front preamp outputs on the rear of the radio because this is what makes the factory amp get the signal to produce sound. Otherwise you will only be running a remote turn on wire to the amp and that's it. These RCA's are NOT intended for an aftermarket amplifier with a factory head unit.
Here is how you replace a factory radio for an aftermarket radio with the older BMW radio harness with many smaller connectors into a common ground amplified system without having to bypass the factory amp and rewire all the speakers. I know for a fact that this works because I'm driving a 1990 E34 with a JVC HD radio in it right now and I didn't bypass any amp or replace any speaker wires.
These are only for BMW factory amplified stereo systems that are the same as the two available in the E34's. The top diagram was used on the factory amplified stereo systems found on the 92 to 95 E34's and the bottom is what was used on the common ground factory amplified systems found on the 89 to 91 E34's.
The bottom diagram was a diagram that I found on the internet. I took a meter to the two 12 volt wires to see which one was the 12v switched and which one was a continuous 12v source. Make sure you connect the two brown wires that are twisted together and have a loop connector that was mounted to the rear of the factory radio onto the aftermarket radio. Unless there is some new adapter out there that I am unaware of, you will have to cut the wires going to the 12v switched, 12v constant, ground, antenna/amp turn on and speaker wires from the connectors going to the rear of the factory radio and connect them to the corresponding wires on your aftermarket head unit harness. Seeing as this is a common ground system, on the diagram where is shows #6 through #13, there will only be 4 wires that connect to the radio and those are all your + speaker wires. On your aftermarket radio harness there will be both the + and - wires, but all you need to connect is the + wires. Tape off the - speaker wires on your aftermarket wire harness, you won't use them at all.
If anyone has a BMW with the 17 pin connector on the rear of their factory radio and they want to upgrade just their head unit while keeping their factory amp and speakers, I am selling the 17 pin Metra amp integration harness I have for $15, and I would be more than happy to help install the new head unit totally free to show the buyer how easy it is to use and show how you don't have to bypass the amp and run all new wires. I bought the Metra harness not knowing that I didn't have the newer 17 pin factory harness.
For anyone who has the older style radio wiring which has several smaller connectors that plug into the rear of the factory radio like mine was with the common ground amplified system and they want to swap out their factory radio for an aftermarket one while keeping the OEM amp and speakers, I would be more than happy to show them how easy it is to install. It took me about 7 minutes to install my JVC HD radio into my OEM common ground amplified system.
If anyone near the Rochester, Michigan area would like to see how easy it is, let me know. This doesn't have to be a huge project to tackle. This is way easier, quicker and cheaper than some people on here make it out to be.
If anyone still doubts that the Metra amp integration harness is designed to allow you to keep your factory amp and speaker wiring in a factory amplified common ground system while letting you just change out your factory head unit for an aftermarket one, I'll be using another Metra amp integration harness in another common ground factory amplified car sometime soon and I'll take pictures of the step by step process and post them up here.
