My Power Steering is vibrating loud only when i turn the wheel at low speeds or stopped. when i go over 40 and i turn the wheel its barly does it. It only makes noise when i turn the wheel the rest of the time it is silent. The steering fluid is fine and there is no leaks and there is no damage or lose parts the steering rack. so i figured it has to be the pump or a belt. i dont want to order a pump if its just a belt or pully. what does it sound like it is? (my wifes E46 2001 320i)
For me it was the pump, and it did exactly that.
Forum Rules___Info for New Members___Teen Driving School in So Cal
"It's the internet by my rules."--Kevlar
how much was the pump and how much was labour or did you do it your self bro
Pumps are anywhere from $350~ to $500~ depending on the model.
http://www.pelicanparts.com/bmw/cata..._pg2.htm#item9
labor is by the hour and I wouldn't imagine it would take more than two hours to install a power steering pump. I may be wrong. I've never replaced the power steering pump on an E46 but on my e30 it was less than 30 mins to pull it from the other car and place it in my car.
VANE PUMP LUK LF-20 1 09/2002 32416760034 $530.10 +core
02 HEX BOLT WITH WASHER M8X100-Z1-ZNS 1 09/1999 07119901788 ENDED
03 HEX BOLT WITH WASHER M8X70-Z1-ZNS 1 09/1999 07119900265 $0.84
04 PULLEY D=135MM 1 32421740858
05 HEX BOLT WITH WASHER M8X14 3 07119915067 $0.28
06 HEX BOLT WITH WASHER M8X22-Z1-ZNS 1 04/2003 07119900270 ENDED
07 RIBBED V-BELT 6PK X 1538 1 11281706545 $37.67
http://www.realoem.com/bmw/showparts...56&hg=32&fg=15
may be the bolts on the pully that the belt goes on could be lose. as it feels more lose than loss of power in steering.
