I got my new pulley today (again)...this time i'm not going to tweak it
the trigger wheel I got with it has a couple little chips and one chunk taken out of one of the teeth. is this going to be a problem for the sensor or can it compensate for small imperfections?
It might effect the operation, do you have a picture? It all depends on how bad and where the chips are.
- Steve
here's a pic of the worst teeth
no, it should be fine.
Bav's Build Thread: http://www.stanceworks.com/forums/showthread.php?t=2498
Yeah, that should be fine. Make sure the center of the VR sensor is aligned so that it sees the unchipped portion of that one bad tooth.
- Steve
sweet, just wanted to make sure...hope you're ready rick!!!!
Remember it's only firing once for every 18 teeth that go by, so imperfections are not a big deal.
It will not make a difference. You can even trigger on the messed up part, the system does not care about that either.
I make cool things for your car.
BMW and Fiat Performance Parts
I also drive italian cars, or own broken ones anyway.
