Results 1 to 12 of 12
Thread: Fuel Injectors o-rings..
    toronto
    94 525i. How difficult is it to replace injector o-rings? How many are needed? Also, fuel feed and return lines may need to be replaced. Any diy links? Im trying to find out where the gas smell is coming from during cold weather. Speaking of cold winter weather here in CANADA, what engine oil viscosity do you recommend. Thanks in advance.
    Great White North
    various
    never done an M50 but you need 2 rings per injector (i.e. 12 in total)
    Baudette Mn
    18 Cummins 3500 00 330t
    If you need some rings i have some. i got some with my new injectors not knowing they came with them already. would rings from a v8 work?
    toronto
    Thanks for the offer but I don't know whether same o-rings are used on in line 6. Maybe someone here knows.
    Oct 2008
    Milwaukee, WI
    1991 535i/5, 1998 Celica GT conv., bikes
    Quote Originally Posted by bimmer94525i View Post
    Thanks for the offer but I don't know whether same o-rings are used on v6. Maybe someone here knows.
    Umm, FAIL!
    The people on this forum are pretty easy going, but you have committed an unforgivable bimmerforums sin.
    *If you live life without risk, you risk wasting your life*
    Baudette Mn
    yea never use v unless it has an 8 after it. offer stands if you find that they will work.
    Great White North
    various
    honestly, based on this sentence alone, I don't think you should be under the hood of your car.
    Baudette Mn
    Jul 2005
    Crook County
    BMW X5, Lotus
    Hey cut him some slack. Maybe the PO did a transplant and installed a V6 in the BMUU.
    toronto
    OOOOOOOOOOOOOps!! I meant in line 6. My mind somewhere else, my mazda mpv. Regret.
    Oct 2008
    Malmö, Sweden
    535i -89 E34, 325ik -88 E30, 323i -85 E30
    Those o-rings are used on virtually every BMW model (same as the oil drain plug for example). Checked with ETK and they are used on most E30, E36, E46, E34, E39, E32, E38 and E31 models.
    For E34 specifially the same o-rings are used on
    518i M40
    518i M43
    520i M20
    520i M50
    525i M20
    525i M50
    530i M30
    530i M60
    535i
    540i
    M5 S38B36
    M5 S38B38
    Great White North
    various
    and they are like 50 cents apiece
