Results 1 to 25 of 35
Thread: Turbo bmw e36 stock differential to 750il diff conversion
    Mar 2003
    NC
    CES Stage 3 Turbo M3
    Hey there all. Been working on another solution to hold more power in our turbo e36 cars, and wanted to share our progress with others who might be interested... It is a complete differential swap from a 750il v12 car and features the bigger 210 ring and pinion (same size as the euro e36 diffs which we unfortunately did not get) but with a 3:15 gear ratio, unlike the 3:23 in the euro diff. I believe the sport versions of the 750il diff have 25% LSD, which is also a plus. Fitment bolts directly up to stock e36 halfshafts and 6 bolt driveshaft, and can be also combined with high hp driveshafts and halfshafts as well... We had to modify the stock subframe by removing the front bushing that fastens the stock driveshaft in place (the notorious bolt that breaks all the time)...and fabricated a new bracket to hold the 750il diff in place. We haven't tested all the specifics yet, but it should hold much more power than stock diffs, which notoriously break their teeth at the dragstrip... Final product will be powdercoated black and will come with two M14 bolts that hold the diff in place. Below are some pics of the overall progress...
    Best Regards,
    john@cesmotorsport.com
    Dec 2002
    Sydney, Australia
    1999 BMW M Coupe
    E36 M3 with 3.0 litre S50B30 had the 188 diff.
    E36 M3 with 3.2 litre S50B32 had the 210 diff.
    E46 M3 have 210 diff.
    .-=[ Kenny ]=-. See the BFc Drag Racing Standings List for BMW street cars. Watch my drag racing movies on YouTube. Some info on
    BMW turbo street car Drag Racing 101
    Mar 2003
    NC
    more pics
    More pictures of the overall conversion... Subframe with bushing removed to make room for the new diff... before and after... also, Comparison shots of the 750 diff versus stock...
    Oct 2003
    Chicago, IL
    16 X5 50i, 97 M3 S54
    Cool project, maybe I have a use for my extra large case 3.15 LSD afterall!
    Also, you need to be a supporting vendor, talking about product releases crosses the line.
    A word of Internet Forum wisdom: Disregard any advice that begins with "I've heard..."
    97 M3/4 - S54, TRM Coilovers, UUC SSK/Sways/LTW Flywheel
    Mar 2003
    NC
    more pics
    more pictures of the 750 diff going back into an e36...
    Mar 2003
    NC
    last pics of bracket
    Here are the bracket pics and how it fastens the 750 diff to the subframe...
    Mar 2003
    NC
    750il diff conversion project
    Thanks for the + response!!
    Just giving some info and showing what we are up to. Haven't talked about pricing or anything. Hopefully moderators will agree this is a post on a good project that people will be interested in? People can come check us out at our website if they are more interested. THanks again... Also, open to feedback so post what you think
    Hagerstown, Md
    1995 M3 Drag C4 Auto
    I did the conversion last winter, Mine works great...
    GDM ENGINEERING
    Oct 2003
    Chicago, IL
    Quote Originally Posted by jgcm3 View Post
    Wow, no bushings on the front mounts? Should be interesting, and probably worthwhile for a track car.
    Queens,NY
    e39
    Subscribed
    Tampa, FL
    97 E36M3 S54
    That's freakin awesome! I would suggest using solid aluminum bushings on the rear of the adapter plate you made. Since the front 2 bolts are directly mounted you will not want them to be bending left/right from the rubber bushings flexing. This could overtime weaken the metal until it fails.
    Besides that, good work. How/where did you have the adapter plate made?
    Are there any clearance issues with the rear swaybar?
    Dec 2002
    Sydney, Australia
    1999 BMW M Coupe
    Quote Originally Posted by zemaestro View Post
    Yep, did it in 2004 and zero issues.
    Louisville, KY
    turbo m3
    Nice to see.
    buffalo ny
    328is, civic
    I wasnt aware of a weak diff issue. hmmmm Thats a part that i havnt broke yet.
    1005whp/831wtq little bit of low boost pump gas magic...
    Atlanta
    M3/4/6, X5 4.4
    I am interested in this information too.....subscribed to learn more
    Mar 2003
    NC
    bracket fab questions
    We designed it based on the mount points of the 750 diff. It actually has three mounting points, but only two are easily accessible when in the stock subframe. Made the bracket at a custom fab shop with a water jet, and is a two piece design. Agree about the solid bushings, but decided to use stock components for now to test them out, and its was just the easiest setup to do first. Also wanted to test vibration differences with this solid mount bracket in case it was too much and we need to do bushings instead.. I think most will not care since it can hold so much more power... No issues with swaybar clearance...
    Next step... beat the heck out of it
    Nov 2005
    Linden, NJ
    97 M3T, 02 M3T, 89 E30
    Looks good. I did the research but I haven't broke another diff since I started thinking about swapping to a 210 diff. That is the next route I'm going to take after another failure. What model years are the sport packages offered?
    97 M3 - 8.94@164.33 - 8 sec street machine, all BMW driveline, factory ECU
    02 M3 - 9.74@145.99 - Maximum PSI stage 2 turbo kit, stock motor, factory ECU
    16 M3 - 9.47@149.22 - MaxPSI downpipes/exhaust/intakes, HCP/MaxPSI flash, Pure turbos, Dodson clutches, EOS intake/intercooler
    BMW SOB's turbo E30 - 8.72@158.39
    follow our latest builds and upcoming events! - facebook.com/maximumpsi - instagram.com/maximumpsi
    Sep 2008
    Australia
    Turbo Euro Spec E36 M3
    Subscribed
    Charlotte
    e36 GT35 Turbo
    Can't wait to check it out in person. I need to come hang at the shop soon!
    Mar 2003
    NC
    Thanks Mike R. I follow alot of your work on the forums (topnotch stuff!) This diff is out of a '92 750il. Chose it because stock halfshafts and driveshafts bolt right up to it with no modifications... I'm pretty sure they can still be purchased new through bmw with the sport package that includes the LSD during those years, but I need to do a little more research. Planning on building it up once initial R&D is done. Going to do a bunch of road testing to see if the design works good, and if it exposes more weak points that need to be addressed... Eventually, I'll probably add a high hp driveshaft and halfshafts, but for now, just going to see how much the stock components will handle... and then go try and stand the thing up at the track
    Netherlands
    Euro S50B30 BEP S372
    i bought a euro m3 3.2 210mm diff from a member off ppf forum,i have seen them for sale on ebay germany for around 800usd
    Nov 2002
    FL
    bmw 325i turbo
    this is good info
    Mar 2003
    NC
    me euro evo diff
    We actually have a euro evo subframe and diff at the shop to compare, but imo, 3:23 is not the best setup for big boosted power. Just too much wheelspin in the lower gears when starting to push 500-600+whp. Also, wasn't too keen on it having only one bolt again that holds the diff in place in the front... I'm actually a big fan of the 2:93 gear set. 145mph in 4rth! Had it on my car until i blew it up at the drag strip about a year ago. 3:15 seemed a decent compromise to be able to use a bigger 210 ring and pinion... and you can find these used relatively cheap $250-$350.00... I'll be posting more results as we do more testing/beating on this setup
    Nov 2007
    toms river nj
    m3
    Quote Originally Posted by mike radowski View Post
    need a test car mike ?
    Nov 2005
    Linden, NJ
    Do any of these diffs come with a ~2.9X ratio and an LSD?
