Page 5 of 5 FirstFirst 12345
Results 101 to 119 of 119
Thread: ABS/ASC Lights On? DIY, sort of.
  1. #101
    Redding Calif
    1999 Z3 2.5L 5sp
    Here is a pdf I made on how to use the NCSExpert program to code a DSC module that has been replaced with NEW or USED using the car's factory settings. 20-Pin port ONLY.
    Click on thumbnail to download file.
    Thanks.
  2. #102
    Nov 2016
    Versailles, Mo.
    1995 318is/ti import
    Thank you
    I purchased a bucket list 99 z3 2.8l with hardtop, for my wife, it has 49K miles. Beautiful vehicle. One of the issues I have is the ABS / ASC lights were and are still on. I read all of the information you folks put it the threads and decided my best alternative would be to get the module repaired as soon as I could. I just received my module back from Module Master and reinstalled it.
    The help these articles provided to allow me to do this job, was immense. Thank you, Hank
    I have not taken the car for a ride yet because of weather issues. Both lights presently came back on, but I have my fingers crossed.
    I will continue to read all the information you folks put here and if I have any worthwhile information I will pass it along.
  3. #103
    Aug 2012
    Kansas
    2000 m roadster 2010 x3
    If all is well then the lights should extinguish after driving a block or less. This is what I experienced when I reinstalled mine. This forum is full of helpful and experienced members.
  4. #104
    Jul 2004
    Houston, TX
    36 Cylinders
    Quote Originally Posted by Hank Humme View Post
    I hope you read the codes before sending off the module. The most common cause of the traction/ABS light is not the module.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
  5. #105
    Mar 2004
    Blue Ridge Mountains, NC
    1999 Z3 Coupe
    I'll bite. What's the most common cause of both lights coming on?
    1999 2.8 Z3 Coupe
    Arctic Silver
  6. #106
    Dec 2007
    Great Dismal Swamp
    E36/7 E36/8x2 E46 F25
    Wheel speed sensors. Of course, the most common failure of the module is to give false WSS codes.
    /.randy
  7. #107
    Nov 2016
    Versailles, Mo.
    You are right
    I based my decision on all of the input I read from the good folks here. The cost of BMW service as well as the potential 1.5 hour trip each way made me take this course of action. Total cost from Module Master was $167. This included return shipping and insurance.
    BMW in Wisconsin told the PO they would have to remove the engine to make the repairs. BMW also failed to check the tires for me. They were still decent but from 1999 and 2001. I had the car checked by them before purchase and had it shipped. They also did not tell me that they had worked on the ABS and ASC lights 4 times and did not fix them. This is why I will troubleshoot the vehicle between myself and a good local mechanic.
    Module Master did have to refloat the board due to the solder cracks. It was a good benefit to get it done anyway. There will be less chances of a bad reading from the code reader.
    I have found a good mechanic locally that has the proper test equipment so I have scheduled an appointment with him for repair of 1 item and the code test. I will pass along his findings.
    I want to get this vehicle to like new condition for my wife. Presently I have it at 95%.
  8. #108
    Redding Calif
    1999 Z3 2.5L 5sp
    Which module is it we have ... I'm assuming your 2.8 '99 is the same as my 2.5 '99 ... ??
    ModuleMaster's abs module page: https://modulemaster.com/rebuilds/abs-modules/
  9. #109
    Nov 2016
    Versailles, Mo.
    The module I have is : Ate Mark 20ei ABS. When you open that item under Module Master's site it indicates that any module that looks like that one is repairable. It also indicates that it is for the 99 to 2002 Z3 with ABS / ATC . My module is located close to the drivers side fender near the top with easy access.
  10. #110
    Nov 2016
    Versailles, Mo.
    Follow up
    After starting the vehicle few more times and driving a little more the lights have reset. In my case the module was the correct answer. Thanks again for all the information. Hank
  11. #111
    Jul 2004
    Houston, TX
    36 Cylinders
    That is very good news. Glad it was fixed, another Z3 stays on the road!
    -Abel
  12. #112
    Aug 2017
    I had the same issue of having no ABS & ASC (wheel sensors measured OK), took my module out and sent it to modulemaster.com. Had it back within one week, put it in and it worked right out of the box. Only had to clear the check engine light (P0500) that came up due to driving the car with the module taken out.
  13. #113
    Jan 2015
    Japan
    Z3 2.2 Roadster
    I'll drag this thread up again....
    My car has been parked up for a month or so, when I started it yesterday the ASC and ABS lights stayed on. Went for a short drive got some gas and a car wash, on the way back the lights went out.
    Could the be the low battery issue I've read about, causing warning lights to appear? Never happened before, car has covered only 27k miles...
  14. #114
    May 2016
    melbourne ,australia
    2000 Z3 2.0 manual
    Hi all, sharing that after experiencing the 113 error and having ASC/ABS warnings on the dash on my MY2000 2.0 6cylinder roadster, I followed the process outlined in various threads and pulled out the module, hacked into the plastic case and re-soldered the 2 connector pins with dry joints. Problem gone. :-)
  15. #115
    Jan 2012
    athens
    1999 BMW Z3 M
    guys anyone has saved the pics from this thread? some links are dead. also dead are all pics from bmwcca site...
    thank you!
  16. #116
    Jan 2015
    Timaru, New Zealand
    Two Z3 Roadsters
    Attached is my file of on the ABS replacement/repair issue. Its information from a number of forum posts. Hope it helps.
    Attached Files Attached Files
    1999 2.8L Z3 Roadster,
    2000 3.0L Z3 Roadster,
  17. #117
    Jan 2012
    athens
    1999 BMW Z3 M
    found two bad solder joints , repaired them. but i made the "window" option , i didnt cut the whole lid..i will try to see if its repaired thank you!
    why i need to bleed the brakes? i didnt touch anything on the hydraulic side of the brakes.
  18. #118
    McLean, VA
    02 MC, 01 MR, 99 Z3C
    I am in the home stretch of refurbishing a 99 2.8 coupe and this error is the last step. Packaged up my module to go to MM in Idaho. I read through some posts about reflowing the solder in the module, but decided not to risk it over $200.
    Kelvin
  19. #119
    Aug 2012
    Kansas
    They do a really nice job opening and resealing. The 5 year warranty is a big plus too.
