Page 3 of 3 FirstFirst 123
Results 51 to 56 of 56
Thread: 6 Disc CD Changer Fix
  1. #51
    Feb 2009
    KC North, MO, USA
    1996 740iL
    It's counter clockwise. The meter I used back then is not designed for precise measurements on electronics. I turned it about 1/3 counter clockwise myself. I don't use it anymore since installed CD43 but it worked up to a year ago when I last used it.
  2. #52
    Sep 2015
    lithuania
    E38 740iL
    Thanks now i need turn counter clockwise i its must help
  3. #53
    Dec 2017
    Iowa
    2001 740IL
    i know this is an older thread but i thought id give it a try im pretty positive now my 01 has a newer charger as im into it and its not looking like the others that have been posted as photo bucket is no longer supported i cannot see other photos... sadly huh sigh
  4. #54
    Feb 2009
    KC North, MO, USA
    1996 740iL
    You just need a browser add-on/extension to see the PB photos. I use Firefox and the add-on I use is called Photobucket Embedded Image Fix. I'm sure Chrome and others have similar.
  5. #55
    Dec 2017
    Iowa
    2001 740IL
    i actually found that out last night right after from another forum user i never even knew about stuff like that! but it sure did help! the white gear on mine was missing two teeth and 4 0r 5 where ready to break off not sure how that happened as the straight cut gear line looks to be in perfect condition lens didn't look dirty at all but i still cleaned that up along with the diode. does anyone have suggestions as to where to find the white gears as a set i mind as well replace them both thanks!
  6. #56
    Dec 2011
    Lancaster CA
    e34,e38,e39,e46,e70,e90
    Quote Originally Posted by tim01740il View Post
    Good luck with that, go to a Junk Yard and find another one that may work or take parts off of it.
