11-42-1-716-192-M67 Oil Filter Kits M44
13-32-1-740-985-M67 Fuel Filter
13-72-1-247-404-M67 Air Filter
51-24-8-399-087-M24 Trunk Lid GAS SPRINGS
Working the Inspecton II soon.
'Sweetness Tres' M44, 1.9L Z3 5-Speed Roadster '97 Boston Green 66K Smiles Mine
'Sweetness Too' M52, 2.5L Z3 5-Speed Roadster, '00 Jet Black 165K Smiles 2022 Gone Ins Co Total in Jan 2022- Right Front Collision - Paid $8850 !!
'Ol' Black Betty' S52, 3.2L ///M3 5-Speed Vert '98 Cosmos Black 265K Smiles Wifeys
M50, 2.5L 525i E34 Tragi-matic '95 Sedan Alpine White III 238K Smiles Was Daughters Mine Again
'Gretchen' M30, 3.5L 535i E34 Tragi-matic '90 Sedan Glacier Blue/Indigo 144K Smiles 2018 Gone & I miss her
'Sweetness' M44, 1.9L Z3 5-Speed Roadster '96 Boston Green 264K Smiles Was Mine Ins Co Total in Jan 2013- Rear End Collision - Paid $4800 !!
Touch up paint.
Urethane trans mounts
trans fluid
Stainless steel clutch line
Just gas.
Stuff. I got stuff.
new... A/C belt, "other" belt, all 3 idler/tension pullies, water pump, thermostat/w/housing, upper radiator hose, lower radiator hose, radiator drain plug, 2 gallons antifreeze, auto tranny filter/gaskets/bolt kit, 8 quarts of Redline D4, touch-up paint, fuel filter, keyless entry system and a Partridge in a Pear tree..
Dave
It's only Tuesday!
Last week I got front rotors, wheel studs, Z3crashuhoh's shift knob and boot, and these Track Graphics (www.trackgraphics.com).
I got a lot of comments on them at the last track event. Some people could recognize all of them, some were trying to figure out what it said.
Craig BricknerClick to Join: BMWCCA # 366493
BMW CCA/PBOC/Chin Motorsports DE Instructor
2008 M3 Sedan Jerez/Black
Black plastic hockey sticks to have covered in leather and a new to me set of black M floor mats with nice fresh looking logos.
12 gallons of premium and an audio adaptor cable....
2002 Alpine White w/ Black 368 (<OO \(||][||)/ OO>)
Power: Custom Exhaust w/ High Flow cats, CSL headers, built, low-compression Supercharged and aftercooled S-54, ViPEC standalone ECU, Vortech V2 Si trim
Driveline: Euro 6 speed, 3.64 diff w/ 40% Lockup, Rogue Octane SSK, UUC Red TME kit, UUC Stage 3 LTW Flywheel/M5 Clutch, SS Shift Knob
Suspension & Brakes: TC Kline True Match Coilovers 500f/500r w/ adjustable camber plates, Racing Dynamics sways, Custom front sway endlinks, ATE fluid, UUC/Willwood BBK 6 piston f - 4 piston r , Slotted E46M3 Rotors, Stainless Lines, Strong Strut, IE Subframe & adjustable rear trailing arm bushings
ICE & Misc: Projector Z's w/DDE & 5k HID, 19'' Gold HRE C20's, Custom Aux pwr outlet, footwell lighting, ACS Splitters, Areo Sideskirts, Custom gauge pods, Z8 Start, Pioneer AVIC Z3, Clarus Components, 10" RE Sub in a Mister-X Enclosure, Alpine PDX 4X150 + 1X600 Amps
Coming soon: and a visit to Randy Forbes
M rear view mirror dimming
Spare M view mirror non-dimming
M Gills
New rear brakes (stock), new belts, oil change, new top that should be done today.
Front pads and rotors (rotors from NAPA, cheaper than anywhere else and last at least as long as stock Brembo blanks).
I like the unicorns.
'99 Z3 Coupe - Jet Black/Black (1-of-114)
'99 M Coupe - Estoril Blue/Black (1-of-82)
'03 540iT - Sterling Gray/Black (1-of-24)
'16 Z4 sDrive35i - Estoril Blue/Walnut (1-of-8)
nothing - spent all my money on the 4-runner.
Tie-rod
radiator
starter
battery
oil change
air filter
Front TCK shocks and *something* rear shocks, from scottdigital, and SS brake lines
3.73 | TCK S/A w/ H&R Sport | M50 manifold | IE Subframe Bushings, RSM, & SS brake lines | Shark Injector | UUC Evo3 SSK & DSSR | Cosmos Strut Brace | ASC, Resonator, CDV Delete
IE subframe bushings, a pair of top adjust rear koni's for a steal, code scanner and some other junk.
TCKline Konis, H&R springs, RSM and all new hardware
VF Supercharger!!!FTMFW!!
Mods: A Few...Rod Bearings, VF Eng. SC stage 1 - 5 lbs, HP Coil packs, Underdrive Pulleys, Organic race Clutch, CDV Delete, Shift pins, Short shift kit w/bushings, Shortened shift lever, Randy's Subframe, IE Bushings, TCKline suspension, Adj. Cast. Camb. (front), Adj. Camb. (rear) 700# springs, RSM, Rogue cover, Metric Mechanix trick variable ramp LSD 3.46, Wilwood Big Brakes, 18" CCW LM's, 315 30R 18, PSII's Complete custom exhaust… Ceramic coated headers ID/OD, Race cats, Eisenmann sport w/83 mm, Custom gauge pod, Custom gauges, Dual Wide band Air/Fuel monitoring, Built-in scan gauge, Becker Traffic Pro, Seat hump removal-both sides, Seat front raise, ACS rare low profile rear wing, Smoked tails, HID's Lightly smoked,
Special Thanks To: Randy Forbes Rocknroad 2Kredz3 MC28REPSOL IslandS62 Clintjg jonesmechanical Ron Stygar and many more on our board!
Sigh... couldn't pull the trigger on the VF SC. Got a UUC short shifter kit from docduvi. Inboard roll hoop gaskets are on their way from Tischer to complete my roll hoop retrofit
Kelvin
Just some 93 octane.
1991 e30 318is Slicktop - Gone
1996 LS1 Z3 - Gone
99 e46 323i - Gone
2003 e46 xiT - Hers
2014 F-250 CC- Mostly stock
Set of Roadstars with Kumho V710 (275's and 245's)...
Some New R888 track tires and an Italvolanti steering wheel. My car is becoming more and more of a track rat.
Oil, some fabric, and a hard top (this weekend).
