Can I go any wider than 225/55?
BMPR STKR: Real racers go LEFT and RIGHT.... So tru! Twins at heart.M
'93 325is-Sold/'03 WRX-Sold/'04 RX-8-Sold/'92 525iA-TotaledSold/'90 e30s52-Sold/'96 328i-TotaledSold/'95 525iM-Sold
Zubbie, thanks for the link, but I am already familiar with the site and the info there. That site only lists 225/55 for the 16x8 rim. On our door jamb it lists an optional tire size 240/45/zr15, but can I use up to a 240/xx/16 tire without issues?
Herbert
245/40 seems like a good size.
Pretty sure the E38 wheels are lower offset than that, aren't they? I have E38 weaves for the winter, pretty high hopes for them.
-Denton
search for Q's old posts, I think he covered it, and from what i recall you can't go wider than 225 as they're actually 23mm offset, not 20mm.
No current BMWs.
1994 Roadmaster Wagon
1974 Alfa Romeo Berlina
Yeah, that's correct about the offset.
My winter wheels are E38 16" Style 5s so I'm hoping they won't rub. Tires are Blizzak LM-22s in 225/55-16H so hopefully I'm in the clear. If not then 3mm spacers should do the trick.
A search would have revealed this thread:Originally Posted by http://www.bmwe34.net/E34main/Upgrade/wheels_upgrade.htm
http://forums.bimmerforums.com/forum...php?p=12220102
-Denton
4500, I had the e38 style 5's on my last e34 and had 0 problems.
Cheers
Herbert
