So I started my car Tick Tick Tick Tick louder then the engine it was very odd and it was doing it for about 20 minutes then just quit completely it has done this about 4 or 5 times over the past 6 months and I have no idea what it is, cars driving great atm. When i speed up the ticks speed up if that helps wish i had a recording of it but I didnt have anything at the time. Ticks every quarter to half a second at idle.
im going to guess lifter noise? I've recently gotten this ticking too Try using a thicker oil next oil change, search around for ticking noise. theres a lot out there on it already.
3.5 HFM | 3.5 CAI | jvt racing Headers | 21.5 lb injectors | Rogue DMS Exhaust | Turnermotorsport Chip | DJ Auto HIDs and thinline angel eyes | smoked corners and tails | Carbon Fiber hood (+10 hp at least) | new front end, cooling system, and a/c system | FK fully adjustable sport coil overs
http://www.flickr.com/photos/eze49/
check your oil level, you might be low.
Oils good to go.
could it be the vano's marbles in a can sound, or maybe its the lifter's as others have stated. Which wt oil are you using?
― George Orwell
make sure the oil is up to the dot on the dipstick. I put in a little more, so I don't tick at the track/autox.
|AST4100 w/ Vorshlag CC Plates|UUC Sways|X-Brace|255/40/17 NT01s|M50 Manifold|Dinan Software|PF FCABs|UUC RTABs|UUC Subframe Bushings|Hawk HP+|Stewart's H20 Pump|Mech Fan Del. with SPAL puller|TFX retrofit w/ E46 shrouds|AFE Intake|APEX ARC8 17x9|VM Swaybar endlinks|CDV Delete|Subframe Plates|Poly Diff Bushings|
97 M3 Coupe
06 E90 330xi
02 X5 4.4
93 325i SOLD
Most likely it is the Lifters...it's common for m3 to have ticking noise coming from the lifter upon start up. So long as the noise doesn't continue while you are driving there really shouldn't be anything to worry about. I have the same issue you have, but mine constantly ticks...hence why I am pulling the engine today and doing a complete rebuild.
i get a ticking noise after i shut my m3 off, Is that just the exhaust ?
97' M3 - Borla Exhaust, Conforti Shark Injector, M50 Intake Manifold, Depo Gen IV ( Orion V2 Angel Eyes, Prolumen Digital Slim 55w HO 6000k Low Beam, 35w 6000k OEM Fogs)
If my S50 is even a little bit low and I have been driving like I stole it. I get a lifter tick. I add the extra oil and give it some time and I am good to go.
Z3 - S50 - OBD2 - Smog Legal - 6 Speed - 3.46 - Anthracite
Yeah Im an idiot I just needed to add a little oil. Hadnt checked the oil for 2000 miles duh...Poor old M
