My buddy drives an e36 318i, but before we start cracking 318 jokes try and hear out this whole scenario.
So his car seems a bit slower than it should, I used to drive basically the exact same car (both manuals), and really don't recall my 318 being that slow. At the same time it is hard to know whether I have just become so accustomed to the increased power in my 330, which would make the 318 seem slower.
Anyway, I really think his is slower than it should be. I know he needs some clutch work. I can't remember if it was a clutch bearing or disk or what, I don't know much about clutches, but just the slightest press on the clutch pedal yields an awful noise.
Long question short, could this faulty clutch be robbing some of the power from getting to the rear wheels?
Thanks,
Chris
I would say yes... if the clutch is slipping even slightly that would certainly rob the car of power to the road. do you notice the rpm increase but there's isn't any accelleration?
definately a yes...you will lose power...just like said above..youll notice an rpm increase but no pull....
I always tell the truth. Even when I lie.
Every day above ground is a good day.
Need a good mechanic? Look no further!
http://forums.bimmerforums.com/forum....php?t=1352434
If there are no problems with the car except it's just slow, i doubt it's your clutch. If it's slipping enough to slow the car down that much, you should notice the slippage and/or smell it......
IF MY CAPS OFFEND YOU, BLOCK ME.
AND IF YOU NOTICE THE FIRST LETTER OF EACH WORD CAP'ED...... IT'S DONE AUTOMATICALLY BY THE FORUM BECAUSE I TYPE IN ALL CAPS.BUT IT DOESN'T ALWAYS DO THIS, LIKE WHEN I QUOTE OTHER POSTS.AND IF YOU DON'T LIKE THAT, REFER TO FIRST SENTENCE IN MY SIG.
yeah you would smell that and feel it, when it slips the RPM's will climb fast, but the car wont, you'll know it for sure
pretty sure a noisy throw out bearing wont affect clutch grip
you probably forgot how slow 318's are
318s slow? Blasphemy.
yea the clutch isn't slipping, so i'm not sure, i wish i had my old 318i back for a day just use as a reference....
is the noise you here when you put the clutch in almost like a whine?
You dont like norcal?
hater
Wow are you guys serious?
You aren't going to lose power from a slipping clutch, you're not going to be able to put your power down. You'll know a slipping clutch from a loss of power since your revs will rise but the car won't move while you are engaging the clutch, that is not a loss of power since your power is still there.
if the clutch is making a whining noise that mean its on its way out
hater
As RedRibbon said.. the clutch wont be a power issue really. If your clutch is on its way out your car would rev but not go anywhere, not just simply not rev quickly or have less power.
If it makes a whine when you engage the clutch it's probably the pilot bearing/bushing (whichever is in the car.) It's located in the end of the crankshaft and can only be accessed with the tranny removed and the bearing pulled out with a puller of some kind. The bearings are cheap.. I paid like $5 for mine at my local discount auto parts store. I replaced mine w/ the motor out so I didn't have to go thru the trouble of pulling the tranny etc.
Here's a quick rundown of some clutch noises and commonly associated problems.
EDIT: Just to re-iterate unless the clutch is pretty much completely slipping there wont be any real power loss. If the clutch IS slipping, regardless of the reason be it misadjustment, misalignment, or just worn completely.. It will heat up and you WILL be able to smell it. Usually quickly. If the car has been that way.. that 'slow' for a long period of time I highly doubt the clutch is the culprit. They usually go out fast once they go.Originally Posted by http://www.aa1car.com/library/2004/bf40459.htm
is your capslock stuck?
Nice signature btw
