Hi, my girlfriend has a 2003 X5 3.0d and the rear tyres have worn out on the inside edge. The rest of the tyre is almost as new but the inside edge is down to the cords. Is this common? Can anything be done to stop it wearing out the new tyres I fitted today?
The wheels have been changed by the previous owner and as far as I know apart rom the wheels the car is completly standard. The tyres are 285/45/19 rear and 255/50/19 front on BMW wheels.
Thanks in advance
Luke.
Define "almost as new". Get a tread depth measurement from on top of a wear bar in the outermost circumferencial groove. If it's around 3mm, your situation is pretty normal.
You can have the rear camber reduced if you get an alignment. Just have them put the rear camber at the closer-to-zero end of the acceptable range and that'll help. BMW's tend to have negative camber in the rear that causes the inner edges to wear out more quickly, especially in lower profile tires.
this is a common problem with bmws
I'd say she needs an allignment or maybe the tire pressure needs to be adjusted.
2005 X3 3.0i
Peter
Thanks for the replys, I will look into getting the alinment checked and ajusted.
Thanks again.
Regards Luke.
I have the same problem with my e34 525i Its usually an alignment problem and since the camber isn't adjustable on the rear you either have to deal with it or get a camber kit so it can be adjusted. I'm not sure if your rear camber is adjustable, if it is then all you need is an alignment.
does she have rear air. if she does than have a shop with a gt1 raise the rear up 3-5mm and reset alignment. it will help this problem. i do this to all x's that have trailer hitches before i align them. it really help the rear tire wear.
if she does not have rear air, than that is normal if align is w/i spec.
gt-1 is the bmw diagnostic computer. any shop with one of those can raise the rear. Even the laptop version from the net can also do it.
some dealer may not do it that way. they will tell you they can not raise or lower the rear. they can only set it to fact ride height. that is BS. i have done it several times and it practically takes 10minutes to do.
over time the bag wear and it does actuatly lower itself. even setting it back to factory spec will help.
Well I spoke to chap I know at BMW today and they can reset the ride height and maybe raise it aswell. Does this sort the camber problem or does the camber also need ajusting by mechanical means.
Really apriciate your help.
Thanks Luke.
Heres a pic of the tyres I took off. Had 5mm remaining on most of the tread and totaly wrecked on inside edge.
i always set the alignment mechanical also. i actuatly put the car on the laignment rack and set it up. i then do my air suspension adj. i try to raise it to where the camber specs are in the middle of your adjustment. it may only take as much as 3mm or as much as 5mm.
i am glad you talked to someone that knows about what is going on. most techs nowadays could care less about customer service and only wants the labor hours.
all you have to do is when the gt1 ask for the measurement from bottom lip of wheel to bottom edge of fender you tell it is 3m lower than it actuatly is. which in turn the system will raise it 3mm. it real easy.
