Results 1 to 12 of 12
Thread: No horn, no steering wheel buttons, airbag light on
    Sep 2008
    Holloman Air Force Base
    07 Lariat, 06 mustang GT
    Its been this way since I got it, the power adjustment does work on the steering wheel and I have replaced the ignition switch. Plz help I'd love to have a horn and be able to use cruise control!
    1995 740iA. Dinan DME. Kenwood Exelon system. Kicker Competition subs. DSP bypass. Servotronic bypass. ASA JH9 18" Wheels. Cherry Bomb exhaust. Resonator delete. 99-01 Euro crystal tailights. Xenon angel eye headlights w/ mild facelift. Kidney grills.
    Jun 2008
    Johannesburg, South Africa
    1987 E30 320I, 1995 E34 525I, 1998 E38 740I
    Probably the slip ring if nothing on the steering wheel is working...
    Rawdon
    1987 E30 320I M20 Manual
    1995 E34 525I M50TU Auto
    1998 E38 740I M62 Steptronic
    Sep 2008
    I made sure the ring was still connected which it is, but your saying the ring itself could be bad? sounds expensive and hard to replace
    Chicago/STL
    97' BMW 740iL
    How old is the battery?
    97' 740iL with NAV Mods: Shadowline, Cluster rings, AE's, Lowbeam and fog 6000K HID's, Style 94's, Quad brake lights, 99-00 taillights, 750 grill, rear heated sport seats, Euro MK3(V26)
    Sep 2008
    Brand new, 1000 CCA too, but i think im still runnin on the origional alternator which may be the reason why I have an electrical ghost. Already replaced ignition switch btw car is a 1995 167k
    Randolph NJ/Harrisburg PA
    1999 Ford Explorer Sport
    Quote Originally Posted by m60 makes it go View Post
    I'd get your alternator load tested. They do it for free at most auto parts chains.
    1996 740iL
    Definately the the clockspring/spiral cable. Disconnect the battery, wait 5 minutes for the srs system to loose voltage then remove the airbad, then the steering wheel. The clock spring is right there.
    Sep 2008
    Really? how hard is it to remove the strng wheel
    Oct 2007
    Henderson, NV
    145 cylinders of power
    sounds like the slip ring ribbon is broken. Remove the steering wheel and the slip ring to inspect it.
    Random Sig below (refresh to see new image)
    Jul 2013
    Moline IL
    97 e38
    i know this is old. i did research for the same thing and i found the definate answer (igntion switch)
    il replace mine for i have the same issues...drives me frign nuts
    Feb 2009
    KC North, MO, USA
    1996 740iL
    Whoa. Old thread. Iggy switch is pretty well known on the forum now. Must not have been then. Q's video covers this really well.
    dancerst's Avatar
    dancerst is offline life is a dance... BMW CCA Member
    Virginia Beach, VA
    E36 SC,E31 840ci,740iL
    Bumping this up. I had the same issue on my 2001 740iL
    and the problem was an ignition switch.
