Page 5 of 5 FirstFirst 12345
Results 101 to 119 of 119
Thread: The History of the Ix
  1. #101
    UK
    E30 318is, E39 M5
    1988 Monte Carlo Rally, this 325iX was driven by Frenchman Francois Chauche, Francois had many successes driving in the Andros Trophy ice racing series over the years but he was never that well known in rallying, this was a totally private entry, amazingly he finished 6th overall, this was a Group N showroom car remember, although the photo shows the car on an icy surface on one of the highest points of the rally, the Col de Turini, fact was that there was hardly any snow or ice on the 1988 event, can you imagine finishing 6th overall on a WRC event nowadays, you would need a few hundred thousand /$!!!
  2. #102
    dsf
    sadf
    I'll probably clean this thread up and remove a lot of the sticky requests. From that point if you see posts that aren't related to this thread (IX price requests, should I buy this car, etc) PM me and I'll remove them.
    Buy WoW GoldBuy World of Warcraft GoldRS Gold
  3. #103
    Aug 2011
    Fort Worth TX
    1991 325iX
    this post made me start to wonder what i better check on mine
    1991 325iX Grey on Black
  4. #104
    Co Spgs/ Denver CO
    1991 325iX
    Any info euro iX's? late 1985-1988. Motronic 1.0/1.1? Different bumpers, tail lights, gear ratios, grilles, headlights, etc.
    1991 325iX
  5. #105
    Jul 2011
    Somerville MA
    1971 BMW 2002 '90 325ix
    I want to place a 1990 325IX on jack stands using a floor jack, without messing up the jacking pts for the bmw jack. Can I lift from the front? Can I use the diff in the rear? Thanks
  6. #106
    Oct 2007
    East Haven, CT
    '02 325ci '97 NA Eunos
    Quote Originally Posted by JACK2002 View Post
    Jack the rear up from the bottom of the diff and the front up from under the cross-member.
    Be sure to use wood as to not damage the metal.
    "Screwed" by ESS Tuning
  7. #107
    Castle Rock .Co USA
    E30M3 X2 E30 325IX
    e30 IX BMW TIS link
    e30 IX specific link to BMW TIS for changes made to 325 to make AWD
    info on how T-case and viscous coupling work
    http://www.garlington.biz/Ray/BMW/325ixDriveTrain.pdf
    and another from the same site
    http://www.garlington.biz/Ray/BMW/xfercase.htm
    hopefully moderator can add to first page of this thread
    Angus
    88 E30M3 X2 (1 summer/1 racetrack)
    89 325IX (winter)
    92 R100GS/PD
  8. #108
    Oct 2007
    East Haven, CT
    Quote Originally Posted by spdracrm3 View Post
    Why do you have the same avatar as me?
    Good post BTW.
  9. #109
    Burnsville, MN
    1989 325iX
    I just wanted to say thank you to all that have contributed to all the info here in this thread! I have learned a lot while here and am blessed to own my 89ix. It really is an amazing car and will probably never get rid of it. Unless it blows up but then I may end up piecing it back together lol
  10. #110
    Co Spgs/ Denver CO
    1991 325iX
    Well I have not found much info on early ix's or more specifically the European 325iX.
    But then I stumbled upon this website and it has all (supposedly) of the models offered from every car company for every year. Here is a direct link to the 1986 model which confirms 3.64 Diffs for the manual, a higher 9.7:1 Compression Ratio, No emissions control, and some other things compared to the US model.
    http://www.automobile-catalog.com/auta_details1.php
    I looked up 1986 325iX no cat due to the car I just bought which was fitted with an aftermarket 02 module (it looks old) after being officially imported and federalized. You can compare cars so I compared it to the US 1991 model, and it also shows the euro model weighs almost 200 lbs less. If you want to find specs on any cars, I highly recommend this site now. It also shows the 3.73 Diffs were in fact made on automatics and matches all of the information I have heard is 'supposedly' true.
    It makes me want to get back in the garage rebuilding the motor on the 86 iX I've got since it is so rare, particularly in the states.
    Hope that helps anybody else who was looking for more info on the Euro iX and if you want to publish info on the first post.
    Last edited by 02rollin; 12-08-2011 at 12:15 AM. Reason: EDIT Direct Link will not work, you must search for the car yourself
    1991 325iX
  11. #111
    Michigan
    Sexy E21
    not sure why there is not like a picture thread for e30. i am used to the e21 section. sorry
    but i had about 7 ix's this past summer. got ride of 6 of them and i kept the white one for myself.
    just did the heater core on it and off course leaking fuel tank, fixed that, all new tires. brakes. and oil change and spark plug along with radiator hose and fuel filter. still need to do timing belt and water pump sometimes after the new year. its kind of cold now.
    car is clean with minimum amount of rust. the worst piece is the rear valance under the bumper.
    also i made a homemade single headlight grills. some ppl might not like them, it's okay. i don't expect everyone to.
    i hate winter in michigan, but with the ix i am loving it. :-)
  12. #112
    Co Spgs/ Denver CO
    1991 325iX
    The registry is down and the pdf file of the newsletters is down as well. There is a yahoo groups that is still up as well as davey's iX site.
    1991 325iX
  13. #113
    CT USA
    1982 323i Baur & 6 more
    I just stumbled across this. I thought I would post it here in case someone might be interested in it. I apologize if this is a double post, although I didnt see it anywhere else. There was also a thread somewhere about removing the engine from the bottom..... I hadn't seen it done on an iX.
    http://www.r3vlimited.com/board/showthread.php?t=242628
    Tom
    SE Connecticut
    1982 323i Baur, 1977 320i (carbed),
    1978 320i (parts)
    1991 325ix 5 speed, 1989 325ix (winter),
    1989 325ic (summer)
    1973 2002 Malaga (with frosting)
    1975 Mercedes W115 300D (The Departed)
    the late 1979 323i Euro (project, Now Departed)
    Visit my blog: Baurspotting
    http://baurspotting.blogspot.com/
    BWR PWR!
  14. #114
    Nov 2009
    Des Moines, IA
    90 ix, 91 i & ic, 02 325
    "I just stumbled across this. I thought I would post it here in case someone might be interested in it."
    Thanks Tomscat1 !!
  15. #115
    Sep 2012
    san diego
    1991 325ix, 1995 318i
    this thread is awesome!!!!
  16. #116
    Jul 2012
    Chicago
    91 325ic Euro'd, 88ix
    anyone have updated links to the docs on the first post? nothing's working anymore
    91 318is M42 AlpineWeiss (ex turbo, back to stock)
    91 325ic M20 Calypsorot 5 Speed (euro conversion)
    88 325ix M20 LachsSilber Coupe 5 Speed (full suspension, engine, AC overhaul in process)
    03 E46 M3 Imola SMG 28k miles SOLD
    91 325ic M20 Macaoblau "Full MT2" SOLD
    06 Mini Cooper Space Blue JCW 34 k miles (!) SOLD
    BMWCCA #466760
  17. #117
    richardodn's Avatar
    richardodn is offline Old Guy BMW CCA Member
    Moderator
    Nov 2008
    Lakewood, CO
    86 528e, 89 325iX, 98 32
    I updated the link for the registry in the first post. Here's the link. http://home.earthlink.net/~hainesinutah/iX/
    PM sent about the other.
    "Howdy, Folks!"
    1986 Delphin 528e - Wife's car, 270k and still going strong
    1989 Zinnoberrot 325iX Sedan - My winter snowmobile (Deceased)
    1998 Avus Blau 328iC - My topless summer girl
    1999 Audi A4 Avant Quattro - Crap can, but I'm in too deep
  18. #118
    Jul 2012
    Chicago
    It's probably been posted before, but the IX production figures on the 1st post are COMPLETELY WRONG. I really wish someone would update that 1st post. Lots of ads out there with BS data quoted from it... confuses people.
    @nando posted a thread on r3v based on BMW data in 2013. THere's a new thread with detailed info including tables of various option combinations.
    http://www.r3vlimited.com/board/showthread.php?t=364236
    BMWCCA #466760
  19. #119
    richardodn's Avatar
    Moderator
    Nov 2008
    Lakewood, CO
    If you want to create a table for posting, I'll be happy to edit the front of the thread.
    "Howdy, Folks!"
