Results 1 to 12 of 12
Thread: How to prevent head gasket leaking oil?
    Dec 2011
    New Zealand
    E30 325i
    So the m20 is common for an oil leak from the oil return on the exhaust side of the block. How do you prevent this leak?
    I have done my head gasket once, and have an oil leak, it absolutely cannot leak under any circumstances when I do it again and I want to make sure I do everything 150% right.
    Resurface head
    Non victor reinz brand head gasket
    Make sure bolts are torqued properly
    Victor reinz head bolts, are they ok?
    copper spray?
    What is the best way to prepare the block surface?
    Jul 2014
    California
    1990 BMW e30 325i
    I've used Victor Reinz head bolt and haven't had any problems, make sure you clean out the head bolt holes, I used a Goetze head gasket and so far so good(10k miles), I used a razor blade to clean the block surface.
    Feb 2015
    Maryland
    325ix, 325ix, 540i
    I can't contribute my winning strategy because I used a VR headgasket and it leaks.
    If your e30 runs bad, switch to Megasquirt first. Then try new spark plugs, cap and rotor, wires, oxygen sensor, crank shaft position sensor, coolant temp sensor, air flow meter, idle control valve, throttle position sensor, digital motor electronics unit, harmonic balancer, fuel injectors, engine harness...
    richardodn's Avatar
    Moderator
    Nov 2008
    Lakewood, CO
    20 440ix cab, 12 X3 35ix
    OE Headgaskets are worth it, Goetz are supposed to be good. Copper spray is unneccessary. Especially with OE gaskets as they are already tacky.
    Resurface head
    I've found the non-abrasive stripping pads good at cleaning the block.
    VR head bolts are fine
    Head bolts are stretch bolts and require a specific rotation when tightening. If you don't have that tool, paint a little direction marker on the bolt head.
    "Howdy, Folks!"
    Feb 2002
    Orlando, FL
    Turbo 97 E36 M3, 99 M3
    Quote Originally Posted by richardodn View Post
    I believe APR now specifies 70-80ftlbs of torque instead of 30*60* and 2 x 90* turns as they did in the past....back in '09, I did the ARP headstuds this way and in 2013, I did it to torque spec.
    1997 Arctic Silver/Black M3
    1999 Techno Violet/Dove M3
    richardodn's Avatar
    Moderator
    Nov 2008
    Lakewood, CO
    Quote Originally Posted by BMWManiac View Post
    You're confusing the issue here. ARP head studs are an alternate product. They are not stretch bolts and so the proper torque method will of course be different.
    "Howdy, Folks!"
    Nov 2008
    Eugene, Oregon
    e30, e34, e36, Cherokee
    What is wrong with reinz I've used them on almost all my rebuilds with no problems
    Slowly climbing the ladder. But never reach the top.
    Click Car 4 Build!
    '86 325es-Turbo m30!
    '94 325iA-Clean DD
    '94 530i
    -6 Spd swp
    '89 Cherokee 4x4-4.7L stroker
    '97 Eclipse Spyder-4g64/63 stroker Turbo.
    '89 535is-RIP 2020, engine now in e30!
    '84 318is-RIP 2016.
    '89 535iA-Parted 2012
    94' 530iA-RIP 2004, engine in new 530i
    '78 530ia-first car RIP 2005
    Dec 2011
    New Zealand
    E30 325i
    Quote Originally Posted by darknezz7 View Post
    I have heard of and personally seen too many failures with them meaning I do not want to take the risk of using one. Also the silicone beading is visibly inadequate compared to other brands.
    Feb 2015
    Maryland
    325ix, 325ix, 540i
    I'm 3/3 for leaking VR gaskets. I've finally learned my lesson.
    richardodn's Avatar
    Moderator
    Nov 2008
    Lakewood, CO
    I'm 1 for 2. I think the issue really is that the VR head gaskets are just more sensitive to prep and condition.
    "Howdy, Folks!"
    Feb 2015
    Maryland
    325ix, 325ix, 540i
    I cleaned the block with a grinder and a green wheel. Flat and clean. I scrubbed the head by hand with a green pad. Double checked flatness everywhere, everything was flat, not even a bit of warp. Followed the torque down procedure carefully. My compression readings are 165-165-160-165-170-165, seals very nicely in the chamber.
    I guess I didn't do enough.
    Apr 2002
    Grand Rapids, MI/USA
    89is,88is,91ic,91i
    the prob with VR gaskets is that they use a very minimal amount of the "sealing bead" on the gasket, making them very sensitive to proper preparation of both the block and the head. I recently used a VR, had a leak in exactly the location predicted, then bought a felpro and did the job again. looking at them side-by-side revealed a generous double bead of sealant on the Felpro, but only and minimal single bead on the VR. But before you go out and get a Felpro, I must say that the one I just received for my rebuild project (different e30) was not as nice as the one I had earlier. So I would simply cough up the dough next time and do OEM. Also take the time to properly skim the head if you really want to be sure.
  1. S54 M Coupe Head Gasket Leaking Oil at 47k Miles!?!?!? Think I'm gonna DIY it.
    By Cloudbase in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 07-14-2014, 10:23 PM
  2. Block test reveals minor head gasket leak - how to proceed?
    By fourside in forum 1983 - 1991 (E30)
    Last Post: 10-14-2013, 11:50 PM
  3. How common is it for S50s/S52s to have head gasket leaks?
    By Andryuha in forum 1992 - 1999 M3 (E36)
    Last Post: 10-09-2009, 04:34 PM
  4. Additive to seal head gasket leak? To stop white smoke?
    By nb1 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 12-08-2006, 07:26 AM
  5. How to combat engine burning/leaking oil?
    By GuinnessDraught in forum 1988 - 1996 (E34)
    Last Post: 08-03-2006, 12:58 AM
