Page 1 of 5 12345 LastLast
Results 1 to 25 of 119
Thread: The History of the Ix
    Northeast, CT
    '90 325iX, '15 Fit EX MT
    As suggested my kish g and the increase of ix specific threads..im making a thread entirely about the ix. this will include the basic information from the ix registry, ix statistics, ix numbers, links, ix reports and tests scans, etc.
    THE IX REGISTRY, PLEASE ADD YOURSELF: HERE
    here is a very important ix link:
    Gordon's iX Registry: http://home.earthlink.net/~wardellhix/iX/
    [Updated link by richardodn http://home.earthlink.net/~hainesinutah/iX/]
    and a HUGE thanks to 29th light, for compiling all of the 28 newsletters into one convenient pdf file
    DOWNLOAD: http://www.sendspace.com/file/ui5f82
    Section from the BMW factory manual that covers the transfer case installation/removal/tear down/build up/mounts
    DOWNLOAD: http://www.sendspace.com/file/mwq3jt
    from Gordons site:
    The 325iX was produced from '86 through '91 and imported into the U.S. for model years '88-'91. The iX has a viscous coupling (filled with silicone) in the drivetrain to split torque front to rear and another in the rear differential to provide a limited slip function. Handling in the dry is quite satisfactory in stock form and pretty awesome on slippery surfaces. With with a few modifications (like cutting the front springs to lower the front 1-1/2 inches, adding a stiff rear bar, installing Bilstein or Koni sport shocks and a Dinan chip, upgrading bushings and running Dunlop D40M2's), an iX will run with any E30 on a dry track. On a snowy surface, an iX fitted with a good set of snow tires (particularly with studded Hakkapelitta 10's) will absolutely leave any vehicle in a cloud of snow.*
    The iX is really in it's glory in inclement weather. Yes, BMW's Traction Control is very effective in preventing spin-outs and in allowing a mind-numb driver to accelerate gradually on a slippery surface. But there is nothing like all four tires clawing at the snow. Even on the most slippery surfaces the iX can accelerate at full throttle after the first several yards. The ABS which includes a special program (not included in the ordinary 325) for low friction surfaces is also very impressive. Jeeps!, Ford Exploders, ExcuseYous, Chevy Blazeers and Subaru Doubtbacks have no idea what left them at the stop light. If you love BMWs and need a car for all seasons, this is your car!
    The U.S. '88's were available only as a 2-door in the U.S. but a 4-door was available in Canada. The U.S. '88s were loaded with standard features such as Recaro seats (see below), electric sunroof, map lights, full trip computer, truck deck spoiler and upgraded radio with tweeters in the side mirror area of the front doors. The '88 had the "old style" more massive looking bumpers with black mouding on the side, but these can be painted to match the body color. All models came with special body side moulding and 15" wheels. In '89 a 4door iX was offered, but many items which were standard in '88 became additional cost options. The '89 and later models came with a removable rear armrest and skibag and had smaller color-coordinated bumpers. These later models also had a 15" alloy spare rather than the 14" steel spare wheel "featured" on the '88 model. A driver airbag was added in most '90 and all '91 models. Asking prices in December '97 for a 5-speed in good condition in the prime Denver market (where there are always iX's in the classifieds) range from about $10K for '88s to $17K for '91s. Automatics are not as much in demand and are somewhat less expensive.
    Two "limited-slip" Ferguson-type viscous couplings are fitted on the 325iX. These are filled with silicone and are not computer controlled. The one behind the transmission splits torque front to rear (nominally 37/63%). A series of plates with holes and slots turn in the silicone fluid. Some plates are attached to the front axle driveshaft and some are attached to the rear axle driveshaft. Normally the plates turn at the same rate without relative motion. The silicone becomes very viscous as soon as it is heated by friction and shear caused by differences between the motion of the plates. This tends to lock the driveshafts. If the rear wheels and driveshaft are slipping and turning faster than the front, friction between the plates increases, slippage is reduced, the rear wheel spin is reduced and the power from the input shaft is transferred to the front.
    The drive system add only 145lb. to the vehicle and is very reliable. The viscous couplings are sealed permanently and require no maintenace. The only additonal maintenance items required are changes of 1) the front differential oil (GL-5 90 weight, same as the rear) and 2) the transfer case fluid which is ATF. All drivetrain fluids should be changed at "Inspeciton II", nominally at 30K miles.
    The front wheels always have some torque transmitted to them. BMW choose a ratio of 37/63% front to rear because this corresponds to the weight distribution on each axle under full acceleration. This avoids the problem typical of front wheel drive vehicles in which the front wheels spin under acceleration due to weight transfer to the rear. Road and Track (April '88) states that "The net effect of the center differential is to act as a power-management system, transferring engine torque away from the end that is slipping and to the end with greater grip; as much as 90 percent of the torque may be shifted to the front or rear as required. This is done actively, quickly and without the occupants of the car ever being aware of it."
    Another interesting aspect: EPA figures for the iX are 17/23 and for the iS 18/24. One might expect more of a penalty for the AWD, but I recall Audi actually advertising that their Quattro system decreased overall fuel consumption because a driven wheel imparts less drag than a rolling wheel over about 20mph. I've never seen BMW discuss this issue or expliot this in their advertising.
    In it's stock form, the iX understeers slightly more than most BMWs. It is 0.4 seconds slower than an ordinary E30 from 0 to 60, and 0.3 seconds slower in the quarter mile. The rear axle ratio is changed slightly (3.91 vs.3.73:1) to minimize the effect of the added weight on acceleration. Car and Driver specifically notes that on dry surfaces, the iX stops 13 ft. shorter than an 325is, probably due to wider stock tires (205s vs. 195s).
    Although the iX does not have enough power to break the rear end loose in 3rd gear, the AWD system does provide some advantages when the car is 4 wheel drifting through a turn near the limit of adhesion. At the point where a the driver of a rear drive BMW would have to lift off the throttle slightly and countersteer, its likely that an iX would allow the driver to stay on the throttle. Power is transferred to the front axle and the front wheels will pull the car through the turn. This is certainly the case on snow, ice, gravel, etc. and the same principle applies on dry pavement near the limit. It's just at higher speed and more exciting.
    The basic technique used to drive the iX quickly is to "point and shoot". Upon entering a turn, aim to run over the apex, get on and stay on the throttle early, and allow the slight understeer to carry the car out away from the apex to the outside of the exit. Through turn keep the front wheels pointed in the direction you want to go and don't worry too much about where the rear end is going. This provides a high exit speed from the turn to carry you down the next straight. The iX and rear driver BMWs are great performers -- they are just different and need to be driven differently for maximum performance.
    There's no significant difference between the 2- and 4-door models except the 4 door is about 50 lb. heavier due to the door hardware and window motors. The '88 iX seats provide lots of lateral support, are very adjustable, and have the extendable thigh support in the seat bottom. They were standard on all '88's (only 2-door iX's were imported in'88) and were optional in later years.
    Until '90 or '91, the only colors availble were red, black, white and silver. Later, a few other colors were offered, including a beautiful dark metalic blue/purple. From an enthusiasts viewpoint, the '88 iX is very desirable, but if you'd like lower mileage, an airbag, skibag and more attractive bumpers, go for a later model. In any case you’ll have a car for all seasons, weather or not!
    MAINTENANCE ITEMS:
    The drive train on the iX appears to be pretty bulletproof -- no inherent problems. Of course, fluid changes are important every 36K miles -- ATF in the transfer case and hypoid SAE90 (GL-5) gear oil in the front and rear differential. The viscous coupling units do not require any service. The transfer case only holds about 1.5 pint of ATF, so be sure to check the fluid regularly. The transfer case on an automatic can leak into the transmission with no visible sign of a leak.
    The weak link on the iX drivetrain seems to be the splines on the front driveshaft which mate with the chain-driven gear in the transfer case. These splines have stripped on several iXes which are owned by members in the iX Registry (now with about 1100+ members.) Apparently, the moly grease which lubricates these splines dries out or becomes contaminated with water and allows the splines to wear down. The only way to check the condition of the grease is to remove the front driveshaft (not a complicated procedure and is covered in one of the Registry newsletters.) If the splines strip, the front driveshaft must be replaced. If the female mating gear is ruined, the transfer case will need to be removed and the gear replaced.
    Owners are reporting that outer ball joints on the iX seem to need replacement at 120K-150K miles. Replacement ball joints are available (Zygmunt Motors, 215-348-3121) which can be pressed into the lower arms at a cost of about $40 each. BMW only sells the whole assembly lower arm assembly at a cost of $250-350 for parts for each side. Bekkers (800-624-5410) sells the arm assembly for around $180.
    Another potential problem is one that applies to E30 models with the M20 engine -- head bolts which break, causing oil leaks or worse. This is easily cured by replacing the original hex-head head bolts with newer torx-style head bolts available from BMW for around $40. These can be replaced one at a time, torquing each bolt first to 22 ft.lb, then rotating it through 90 degrees, then rotating it though 90 degrees a second time for a total of 180 degrees. There is also a non-BMW head bolt available (Raceware, 800-468-1977) which can be retorqued after installation, but a set of these cost around $190.
    On some early E30 models, the brake lining warning light flashes intermittently. This is usually caused by a broken printed circuit board wire or solder joint on the instrument cluster board. There is information available on BMW web sites FAQs regarding how to fix this problem and also on how to replace the rechargeable battery which operates the service interval LEDs on the instrument cluster.
    Several other items of note:
    • The timing belt should be replaced every 50K miles and if you are buying a used vehicle, the belt should be changed ASAP unless you absolutely know that it has been replaced recently. Valves hit pistons if this belt breaks!
    • Because of the shape and mounting of the front calipers on the iX, stock wheels for the ordinary 325 models and aftermarket 325 wheels will not fit on an iX -- make sure that you buy wheels that are known to fit on an iX.
    • As with all BMWs, regular brake fluid changes will save you money in the long run, preventing rust and corrosion in the master cylinders and calipers.
    • If you choose not to replace the coolant every two years as recommended, at least add a can of anti-ruust/water pump lubricant to extend the life of the waterpump and reduce corrosion.
    Road and Track published an excellent review of the E30 models in their April 1996 issue. The article is titled "Used Car Classic: BMW 3-Series, 1984-1992, Budget Bavarian sport and style" and covers the iX. The article states, "Finally there's the rather rare 325iX. The 2wd E30 cars are poor handlers on snow and ice, and the iX is the answer for motorists who must endure harsh winters. It's almost spooky how much extra grip it has over the rear driver."
    ___________________
    * The rear traction bias of the iX and its balanced front-to-rear weight distribution provide superior traction on low friction surfaces when compared to the Audi 90, the Audi 90 Quattro, and the rear drive BMW325is. Road and Track ("Snow Test", Nov,'88) concluded, "Front-drive cars do not like to accelerate on slick surfaces." R and T also concludes that the 90 Quattro does not perform as well as the iX, saying, "Our acceleration champ was the iX. The AWD BMW was a blink quicker than the Quattro to 20 mph, 4.9 sec vs. 5.1 sec." In the hill climb, R and T says, "Once again, the BMW AWD system proved superior to the Quattro arangement." In the lane change, R and T says, "And again, the 325iX was the best." I've raced an M3 in the SCCA World Challenge Series and currently drive a new M3 (in good weather only). Personally, I really like a neutral handling car. I dislike the understeer characteristics of front-wheel and most AWD cars. To this end, the iX is much more neutral and handles more like a BMW that one would normally expect of a AWD car. No doubt about it both the Quattro and the iX are incredible cars, but my choice is the iX for the above reasons.
    Here are some numbers ive collected..although there not official, or reputable..they can be used as a guidline as to the rarity of the ix:
    Model Total Production: 325ix: 34,862
    Total US E30 325iX sales:
    1987: 297
    1988: 310
    1989: 844
    1990: 699
    1991: 454
    1992: 41
    1993: 2
    325iX/2 door (85-91): 12,557
    325iX/4 door (85-91): 17,032
    Total: 2,647
    Ix Production
    Produced From 10/85 - 01/91
    Total World Wide: 34,862
    2 Doors: 12,557
    1988: 310
    1989: 844
    1990: 699
    1991: 454
    1993: 1,391
    1994: 14
    BMW NA Total: 3,711
    Drive Type Total Production
    4WD: 34,862
    RWD: 2,309,479
    E30 Sales By Model (Worldwide)
    325iX 1985-1991: 83,030
    Pricing:
    1988 325iX $32,800
    1989 325iX 2-door $29,950
    1989 325iX 4-door $30,750
    1991 325iX 2-door $31,100
    1991 325iX 4-door $31,900
    1990 325iX 2-door $29,950
    1990 325iX 4-door $30,750
    BMW 325IX Performance:
    • Power (SAE net): 168 bhp (5,800 rpm)
    • Torque (SAE net): 164 ft-lb (4,300 rpm)
    • Redline: 6,400 rpm
    • 0-60 mph: 7.8 seconds
    • Standing Quarter Mile: 15.9 seconds (86 mph)
    • Top Speed: 126 mph (5,750 rpm)·Total IX sales (worldwide): 34,862
    BMW 325IX Specifications:
    • Engine: 2.5L Inline 6 cylinder, iron block, aluminum head
    • Bore x stroke: 3.31 x 2.95 in., 84 x 75mm
    • Displacement: 152 cu in., 2494 cc
    • Compression Ratio: 8.8:1
    • Engine Control System: Bosch Motronic w./ port fuel injection
    • Emissions Control: 3 way catalytic converter, feedback fuel-air ratio control
    • Valve Gear: belt-driven single overhead cam
    • Transmission: 5 speed (w./ overdrive)
    • Final Drive Ratio: limited slip diff., 3,91:1
    • Wheelbase: 101.3 in.
    • Track, F/R: 55.9/55.7 in
    • Length: 175.2 in.
    • Width: 65.4 in.
    • Height: 55.1 in.
    • Curb Weight: 2,988 lbs
    • Suspension:
      • Front: independent strut by control arm, coil springs, anti-roll bar
      • Rear: independent semi-trailing arm, coil springs, anti-roll bar
    oBrakes:
    §Front: 10.2 x 0.9 in. vented disc
    §Rear: 10.2 x 0.4 in. disc brakes
    §Fuel Economy: 17/23 (City/Highway EPA)
    Colors
    Standard Colors
    Alpine White
    Black
    Brilliant Red
    Cinnabar Red
    Gazelle Beige
    Henna Red
    Lapis Blue
    Savanna Beige
    Safari Beige
    Optional (Metallic) Colors ($395.00)
    Agate Green
    Atlantic Blue
    Arctic Blue
    Baltic Blue
    Bahama Beige
    Bronzit Beige
    Burgundy Red
    Calypso Red
    Cosmos Blue
    Delphin Gray
    Diamond Black
    Glacier Blue
    Granite Silver
    Kashmir Beige
    Lagoon Green
    Lazurblau Metallic
    Mauritius Blue
    Opal Green
    Polaris Silver
    Salmon Silver
    Sapphire Blue
    Sterling Silver
    Fluid levels -
    Front differential:
    Spec: 90W GL-5
    capacity: 0.75 qt
    drain/fill plugs: internal (Allen) head, Size 17MM
    Rear differential:
    Spec: 90W GL-5
    capacity: 1.8 qt
    Manual Transmission:
    Spec: 80W GL-4
    capacity: 1.4 qt
    Autonatic Transmission:
    Spec: Dexron ATF
    capacity: 3.2 qt
    Transfer case:
    Spec: ATF
    capacity: 0.6 qt
    Ix Promo Video: [ame]http://www.youtube.com/watch?v=8nBpDNYPeTQ&NR=1[/ame]
    Some articles and info ive collected:
    more links:
    http://www.tapanen.net/325iAX.html
    http://www.moonlitemotorwerks.com/driveshaft
    i hope to some day create an ix registry and a dedicated ix website...sort of like the baur registry, but until then...here ya go. feel free to add anything or correct me
    Northeast, CT
    Upgrades: (thanks to NHSkibum)
    Suspension
    H+R Springs (iX specific)
    Bilstein's (HD's)
    Konis
    BMW Mtech
    Sachs (stock)
    "Performance"
    Bav, Jim C, Mark D Chips (same as i)
    Can put a lightened flywheel in
    Can put cams in (same as "i")
    Wheels
    et=+41, CB=57.1, BP=4x100
    Can't do a five lug unless you find an E34 iX (Euro)
    Can't do an M50 swap (easily) unless you get the oil pan from that car.
    ix specific items:
    • the transmission hub is slightly wider then the RWD e30's. this means the seat handles, and carpet are slightly modified
    • windshield washer reservoir is relocated
    • different shaped, and sized under steering wheel pattern
    • please add more ix specific items and i will add them here!....
    Stress Bars:
    Bav Auto
    1988 325ix (Fred) also has an uber rare german ix specific stress bar:
    and now a forum member on e30tech makes custom ones, which can also be found on ebay
    BMW Z1: shares the same m20 as in the ix
    Quote Originally Posted by Budget M3 View Post
    The Z1 has the same iX M20 engine with the "pass through" the oil pan. In your case, it's to create extra room for the front axle running gear. In my case it allows the engine to sit behind the front axle, far to the rear of the engine bay, creating a "front-mid" engine layout and near 50/50 balance. At one time, BMW considered making the Z1 AWD as well... Now THAT would have been awesome!
    Apr 2008
    Vancouver
    e30
    Never knew about the OBC alerting you to icy conditions, that's pretty sweet if you ask me.
    Feb 2001
    North Jersey
    Rogue 3 TTs2.5 / Rubicon
    thread officially parked - great job.
    Hey man, I'm a professional!
    Franklin, NC
    Spec E30, 91 318i
    Wow davey your thread got parked, and it wasn't even Tim!!
    Temecula, CA
    E30ic, E39 M5
    Quote Originally Posted by moberg12 View Post
    LOL, we've been talking about doing a thread like this for a while now and I would have stickied it immediately if I wasn't at the beach all day.
    I'll probably clean this thread up and remove a lot of the sticky requests. From that point if you see posts that aren't related to this thread (IX price requests, should I buy this car, etc) PM me and I'll remove them.
    Awesome work, Davey. You're easily one of the most devoted IX fans I know, if not the most.
    Tim
    1987 E30 cabrio | Bumper swap | H&R Sport | Koni Yellow | Eibach Sways | BavAuto strut bar | Cardinal seats | MTech2 wheel | Armrest | Smoked Hella Smileys | 5k HID | Stromung | RS003
    2000 E39 M5 | Stoptech brakes | Refinished OEM wheels w/10mm spacers | Powerchips Gold 91 | Timmay Tips/muffler delete | Functional brake ducts | DICE MB1500 Slimm diffuser | Cubic black trim w/alcantara boots
    Netherlands
    325iX Baur & more
    Another part that is different. I found it out after I tried to replace my cracked on with the one I got from the 323i Baur, B44149.
    The above is the iX one.
    And some figures:
    BMW 325iX Baur TC: 93 pieces
    BMW 325iX Automatic Baur TC: 21 pieces
    Gr Jeroen
    Phoenix, AZ (Scottsdale)
    '96 XJR6, '02 Tacoma TRD
    wow...this is by far one of the most helpful unique posts ive ever seen! Thanks so much man!
    ***Finally have my dream Jag, 1996 XJR6...in search for that perfect E46 330ci...***
    ----R.I.P.----
    '93 XJ6...5 long years, forever be my baby
    '90 E30 325ix
    '98 E38 750iL
    (4) XJ Cherokees
    My Professional Mobile Detailing business: http://www.FullThrottleAutoDetailing.com
    Northeast, CT
    thanks for the comments! glad i can help out the ix community
    and woah...my first parked thread
    and jeroen...what is that a picture of? some kind of panel?
    Exeter, NH
    A BMW
    Nice job Davey! Looks AWESOME!!!
    Netherlands
    325iX Baur & more
    That's the panel under the steering wheel. It's different from all the other panels.
    Gr Jeroen
    Northeast, CT
    Quote Originally Posted by NHskibm View Post
    Specific offset 35
    thanks for the info! ill keep adding any additional info to the above posts. am i crazy or is the ix offset et41 though?
    NJ
    too many bmws
    Quote Originally Posted by Baur View Post
    Gr Jeroen
    sure? i know there's a difference between airbag and non-airbag but i was able to install an undertray panel from an is to my ix.
    '91 SpecE30 #523
    '12 F30 328i Sport Line
    '00 F-350 Dually
    BMWCCA #360858 NASA # 128290
    https://www.facebook.com/COTABBR
    Exeter, NH
    A BMW
    Quote Originally Posted by davey101 View Post
    One of the two of us could be crazy... I honestly don't remember off the top of my head... 35 was my gut... But I could be wrong... It's been known to happen
    I do know that real alpinas fit just fine though... (with 4 fronts)...
    Northeast, CT
    ok, i looked it up and edited it above
    Oct 2005
    St John's, Newfoundland, Canada
    '88 iX 4door
    nice write up ..
    in the spirit of kick starting your registry, +1 to canadian import 4 door '88's
    I'd be curious to know what the import numbers for canada were over the life of these, I haven't been able to find them though
    Northeast, CT
    Quote Originally Posted by HANKK View Post
    nice write up ..
    im still not sure if the numbers above are for USA ix's or NA ix's
    wish i had some friends over at BMW that could supply some numbers
    and im not sure if it would get over filled and hectic, but would a list of ix's (Screen name, year, 2/4 dr, man/auto, color, other ) at the top of the page be a bad idea?
    NJ
    too many bmws
    might be better off on an ix registry thread.
    '91 SpecE30 #523
    '00 F-350 Dually
    Netherlands
    325iX Baur & more
    I have two types of wheels here:
    ET41 and ET47. Depends on the type of wheel.
    Gr Jeroen
    Oct 2007
    East Haven, CT
    '02 325ci '97 NA Eunos
    Stock offser is et41 but you can fit et35 wheels on an ix. Maybe that's where you got confused.
    "Screwed" by ESS Tuning
    Exeter, NH
    A BMW
    Quote Originally Posted by 1988 325ix View Post
    with all the damn wheel options I've looked at in the last year I confuse easily... Maybe my alpinas are Et35?? I don't remember... And the damn Touring and looking at wheel options, with spacers, without spacers, etc etc, I'm just a big mess....
    Oct 2007
    East Haven, CT
    lol
    You're all sorts of messed up hahahahaha
    Oct 2007
    The Falls
    1991 BMW 325iX, 2002 VW Eurovan MV, 2008 MCS
    Davey, can you edit the post to include Lazurblau Metallic as an available color? I don't see it listed.
    nhskibum- www.alpina-usa.com's catalog lists the e30 wheel as et24
    1991 BMW 325iX (4dr, 5spd, Lazurblau)- 4.10 differentials, Slotted rotors (front), EBC greenstuff pads, SS brake lines, Supersprint cat-back w/ DTM tips, Z3 'short shifter', H&R springs, Bilstein dampers, e36 rear shock mounts, AKG poly subframe & TA bushings, MM flywheel (10-12lbs), Bav. Auto Chip, K&N panel filter.
    2002 VW EuroVan MV- Alpine 9833 receiver with iPod adapter, Thule roof rack, Yakima hitch bike rack.
    2008 Mini Cooper S- Showroom stock.. down to the craptacular run flats.
    LOTS OF E30 PARTS!
    Northeast, CT
    Quote Originally Posted by cappa240 View Post
    added..the color list is really vague and missing a ton so thanks
    Exeter, NH
    A BMW
    Geez... you made me look things up...
    You site didn't work but you can go to www.ksk-alpina.com for the sole US dealer of new stuff...
    the E30 M3 Alpina in an 8x16 is et24 and the regular E30 alpina in 7x16 and 8x16 is et 28...
    Now I need to remember what the hell was Et35!!!
