- weird lighting issues.
1984 633:::okay, my passenger side fog light is not working anymore and my drivers side lowbeam isn't either. They were fine before, and my fog quit working then a week later my lowbeam quit also. I checked the bulbs and fuses and they are good. Is there a separate relay for each side of the cars fogs and low beams? Thanks!
There is a low beam relay, but both lights would go out, they are not individual relays. The same with the fog lights.
The right fog light is on fuse 30 (the left on 29) and the left low beam is on fuse 13 (the right on 14). Read this thread about problems with the fuse base and check the fuses again:
http://bigcoupe.com/phpBB2/viewtopic.php?t=6439
(Forget the stuff about the fuel pump, it's the fix in the fuse box you are interested in)
Thanks man. That's gonna be my first job in the AM. Thanks I hope this helps.
- You may not post replies
- You may not edit your posts
Forum Rules
