Page 4 of 4 FirstFirst 1234
Results 76 to 93 of 93
Thread: New gauge pod thread
  1. #76
    Batavia, IL
    00 M Coupe, 08 335xi
    Quote Originally Posted by RTCustomz View Post
    thanks for those forums, that i didnt know of. I think i may have found what we all were looking for!
    I have found a M roadster dashboard. Would this work or just a z3 dash? I am awaiting reply on the z3 dash i inquired about.
    dash is the same
    http://images.google.com/images?sour...&q=z3+interior
  2. #77
    Olney, MD 20832
    1984 BMW 318i, 88 vr6 coupe, 2004 4runner
    From my searches on google images the M series and Z3 series dash's are not the same.. Am i wrong?
    EDIT: nevermind.. they are the same!
    What if these were made in Carbon Fiber?
  3. #78
    Apr 2019
    Hagerstown
    Yes
  4. #79
    Boiling Springs, PA
    '02 Z3 3.0i 5 speed
    From 10 years ago, and well worth the wait!
  5. #80
    Apr 2019
    Hagerstown
    Yes
    See below
  6. #81
    Apr 2019
    Hagerstown
    Yes
    Better pic. One more edit left actually
  7. #82
    Aug 2015
    Denver, CO
    1999 Z3M, 1999 2.8 Coupe
    That's a heck of a lot of work for some gauges, but I bet it turns out great.
    My auxiliary gauge "pod" only took a couple hours including routing wires and plumbing.
    Added voltage and oil temp to Z3 Coupe, boost and oil pressure to M (M is coming out of hibernation soon so will grab a photo of that).
    Nathan in Denver
  8. #83
    What about 3d printing?
  9. #84
    Apr 2019
    Hagerstown
    Yes
    Hood mold is now complete.
  10. #85
    Texas
    '02 Z3, '09 Mini
    Quote Originally Posted by s8ilver View Post
    Interesting.... other than the brightness that looks quite good. Think I would prefer this to a carbuncle grafted onto the top of the dash. Can you give the details on these gauges and how they attach? Also what oil temp sensor did you use and where did you put it?
  11. #86
    Aug 2015
    Denver, CO
    Quote Originally Posted by raubritter View Post
    The pod is from Rally Road, $94.95. It attaches directly to the steering column trim and looks factory IMO. Yeah, I just tossed in the bulbs I used in center console (had a 10 pack from Amazon). They are rather bright. I may step down a touch. I tapped the headlight dimmer wire so they do dim with the knob.
    https://rallyroad.net/collections/ga...untedgaugepods
    Everything is run though a fuse block made by...Fuzeblocks (for motorcycles)...tapped constant power at battery terminal under hood and switched power in fuse box in front of secondary air pump and ran wires through firewall grommet. The fuse block I got lets you decide switched or unswitched power based on how you insert the fuses. Cool stuff and the block is TINY...tucked it behind the glove box.
    https://www.fuzeblocks.com/
    Gauges are OEM M gauges (had some spares so why not?).
    I used a Bimmerworld oil distrubution block at the stock oil pressure sensor location:
    https://www.bimmerworld.com/Gauges-D...ing-Block.html
    Oil temp sender was from a VW I think, but any VDO sender that matches the gauge range should work. The VW one I found was really short and looked like a better fit.
    Think I have this one laying around somewhere too:
    https://www.amazon.com/VDO-323-905-T...y&sr=8-1-fkmr0
    Nathan in Denver
  12. #87
    Apr 2019
    Hagerstown
    Yes
    Vuala
  13. #88
    Apr 2019
    Hagerstown
    Yes
  14. #89
    Apr 2019
    Hagerstown
    Yes
    No heating and pushing down the air ducting is required as well.
  15. #90
    Boiling Springs, PA
    '02 Z3 3.0i 5 speed
    Ok, finish it up and let's see the final product!
  16. #91
    Apr 2019
    Hagerstown
    Yes
    One more exit to hood left
  17. #92
    Jan 2015
    Japan
    Z3 2.2 Roadster
    Are you taking these pics lying down? Or have I drunk too much again..... Drunken pods?
  18. #93
    Apr 2019
    Hagerstown
    Yes
    Sorry to bring back something old, but I spent a lot of time on this. Who wants a blank mold? $150 shipped in the USA
