interesting article
http://www.minimania.com/MM/BRAKES__..._brake_fluid__
to_use_or_not_to_use___that_is_the_question__785.h tm
EDIT - please copy/paste
The page cannot be found
From what I heard you should only use silicone brake fluid on a track car. I guess it makes it a lot easier to get on the brakes, or maybe it doesn't work well with ABS?
The article Rahul posted says "a number of racers go pale at the thought of using [silicone brake fluid]." Given the reasons outlined, I can understand why.Originally posted by Whatup1049
E36 DIYs: Air Pump | Vent Gauge | E46 Armrest | SmarTire TPMS
E46 DIYs: Hella TPMS | Aftermarket Horns | Window Regulator Notes | Trunk Wire Harness | Trunk 12V Socket
dot 4 only!
Sig courtesy of ///Maniac
'99 Z3 2.3 '97 740iL '90 735iL
'65 Sunbeam Alpine - Pimpmobile
